42 inch flat screen tv set only the power button works the on button turnns on but screen stays off
The remote power but responds only no other does
  • 3,904 Answers
Check that the proper input on the tv is selected to match the input you have the cables plugged into.
Posted on Nov 18, 2013
4 Suggested Answers
  • 12 Answers
SOURCE: 42" LG 42LC2D HDTV Will not turn on
Hi, sounds like a power supply problem, most likely needs capacitors replaced, costs about £5 to do it yourself, and a fortune in the repair shop, easy enough if your handy or know someone who is,its worth a try,it'll be going in the bin anyway, cam
Posted on Jul 14, 2009
SOURCE: remote control code for 32 inch lcd EMERSON TV
I succeeded is using the DirectTV remote control for the Emerson 42" plasma TV, by using a Samsung code. On my TV, was 10060. If this one does not work, there are a bunch of others that might work. Good luck
Posted on Dec 31, 2009
toyladi3
  • 597 Answers
SOURCE: My Philips 42 inch flat screen tv keeps cutting
There seem to be a problem with the power panel of the television that is why it does not power on if you leave it over the night without trying to turn it on.
Flashing the green power LED light simply means there is a problem in the unit that is why it keeps cutting.
Run a check on the power panel of the television to see if there is a burnt capacitor in the unit, then replace if you find any, also, a cold joint can be a cause for the problem whereby, you have the lead on a capacitor or component melted off and bridging two wrong ends together. That can be corrected with the use of a soldering iron.
If you are not familiar with technical activities, i would strongly advice you have a repairman run a check and fix it for you. It should not cost you much and if it is still under the warranty period, then you can take it back to the dealer that supplied it to you.
Take care
Posted on Oct 11, 2010
Phillips 40PFL3505D 42 inch tv stuck in channel search mode , continuous cycle
You can try to go back to factory settings.
After that disconnect the power from the TV and wait for about an or two hours. Then put on the power and try to make the installation complete from the start.
Regards GJ
May 25, 2014 | Philips 42PFL5332D 42 in. LCD Television
Sony wega 42 flat screen no remote,turn on button stays red noyhing else happens
Set might be OFF using the remote control's power Off button. If so, you must have a remote control to power it ON. Any remote control to Sony will work.
Sep 16, 2013 | Samsung Televison & Video
Bush 24 inch tv/dvd combi screen went blank as if it's on standby. won't respond to remote control. one week old. is it seroius?
try switching on tv point remote at the tv pressing the menu/exit button and holding for 10/20 seconds hope this works for you
Oct 07, 2012 | Bush Industries IDLCD26TV16HD LCD TV
I have a 42" flat screen. Only two years old.. It just went black during a movie and won't do anything. When I unplug it and plug it back into the wall the light just stays blue... No access, picture, nor...
Try leaving it unplugged overnight; it may have an IC locked up.
If that doesn't work, it is likely a power supply problem, these are all too frequent with our sets.
There are at least two supplies in your set; one of them (a low-voltage section or board) stays on continuously so the set can respond to commands from the remote. The other is turned on when you power the set up via remote or button push.
If the set isn't responding to either remote or local set controls, it is likely that the main power supply has failed.
Your help request is captioned as a 52" model number but your text says it is 42" so you need to add the correct model number before anyone can help you.
Aug 22, 2010 | RCA HD52W59 HDTV Projection Television
Lost picture. When using main power button, the
Tries unplug,replug the tv an hour later might work.But this a temp.fix,must replaced the backlight video board sooner or later.
Dec 22, 2009 | Planar PDP-42BK 42 in. Plasma HDTV
My 42" Vizio LCD Tv Turns on/ wont turn off or display picture.
If you haven't tried it yet, pull the AC plug and let it sit overnight. Your set and most later ones do have microprocessors in them that can have 'lockup' problems similar to a resonal computer crashing.
If it still isn't responding to set-mounted or remote controls, you may have hada power supply failure.
Aug 06, 2009 | Vizio Televison & Video
Brand new LG plasma stuck on test screens
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
Hope it may help you;
Regards;
VOTIT
Jan 29, 2009 | Televison & Video
Hyundai 42" Plasma TV
Try www.hyundai-world.com That is the manufacturers website. Good luck. Ask them if that set can played in the USA without a special power supply.
Nov 19, 2007 | Hyundai HPT-4250 Television
Televison & Video Logo
Top Televison & Video Experts
