Question about Black & Decker B2300 Bread Machine
Doesnt start number 8 setting
I have the same problem. Try using setting 2 and take out the dough ball before it starts baking. I tried number 1 but that didn't work either.
Posted on Feb 02, 2014
Write a 5 number set in which the mean, median and mode is 8
There are an infinite number of solutions. One solution is {7, 8, 8, 8, 9}.
Mar 28, 2014 | Computers & Internet
How easy is it too fix an F100 problem on a Toshiba E Studio 3511
f100 indicates hardrive problems.
power off machine,
power back on while holding down 0 & 8 on number keypad until beep is heard,
enter 690 on number keypad,
press start,
enter 2 on number keypad,
press yes on display and wait for machine to ask for reboot.
be patient may take a while and if it doesnt work could be hard drive failure.
if it is the hard drive it could also mean updating firmware on hard drive and machine.
Feb 10, 2010 | Toshiba E-Studio 3511 Color Copier
Unable to clean 46
Unable to Clean or Machine Error 46 means your purge counter is already full. Please refer below for the instructions on troubleshooting your machine.
1. To enter MAINTENANCE Mode: Press MENU, MONO START, 4X on ARROW UP. (within 2 seconds).
2. Using arrow up button look for the following:
a. 8 then press SET or OK
b. 0 then press SET or OK
3. Using MONO START, just press it until the word "PURGE XXXXX" comes out.
4. Using arrow up button look for the following:
a. 2 then press SET or OK
b. 7 then press SET or OK
b. 3 then press SET or OK
This is to reset the purge counter. Then press stop
5. Using arrow up button look for the following:
a. 0 then press SET or OK
b. 1 then press SET or OK (To reset unit)
a. 9 then press SET or OK
b. 9 then press SET or OK (To exit Maintenance mode)
Nov 10, 2009 | Brother DCP-350C InkJet Printer
Samsung dvd-85k unlock code
Samsung DVD-V8500K
1. The player should be powered on, the tray closed without any disc inside, the logo "DVD Video Samsung" visble on screen and the message No Disc must have already appeared.
2. Press the "Subtitle" key on the remote - "No Disc" should disappear.
3. Using the remote control, key in the code
"5, 3, 8, 1, 4"
4. A number should appear - this is the player's region number that was last programmed.
5. Press the number of the region you require, or 9 for region-free.
6. Press the "Subtitle" key on the remote - region number should disappear.
7. Press Standby on the remote control.
NOTE:
Origin of this player is Region 5 so it`s a default setting
If code "5, 3, 8, 1, 4" doesnt work try this codes:
Region 1 - 2, 9, 3, 3, 4
Region 2 - 3, 8, 7, 6, 7
Region 3 - 5, 6, 7, 3, 2
Region 4 - 7, 6, 8, 8, 4
Region 5 - 5, 3, 8, 1, 4
Region 6 - 2, 4, 4, 6, 2
please rate me. its most helpful
Nov 07, 2009 | Samsung DVD-V85K DVD Player / VCR Combo
New Konica bizhub C351 copier with only 58 copies. It will make copies but it has a 6 1/8" x 8 5/8" BLACK area in the center of the 8 1/2" x 11" copy if you make a copy from the platen glass. It does not...
Gray box after installation.
Solution
CAUSE: Installation procedures were not completed properly.
SOLUTION: Complete the installation procedures thoroughly:
1. Adjusting Touch Panel - Press the Accessibility key, Touch Panel Adj.
2. Setting Gradation Adjustment - Go into Service Mode, Image Processing Adjustment, Gradation Adjustment. Service mode- ulilty/counter, check details , then(Stop00 stop01)
3. Touch High Compression Mode and press Start [perform 3 times].
4. Touch Gradation Mode and press Start [perform 3 times].
5. Touch Resolution Mode and press Start [perform 3 times].
6. Date/Time Setting - go into Service Mode, Press Stop, 1, 1, 4, 4, Clear.
7. Go into Utility/Counter, Administrator Setting, System Setting, Date/ Time Setting.
8. Install Date - go into Service Mode, System 1, Install Date.
9. Serial Number Input - go into Service Mode, System 1, Serial Number [If Serial Number is already there, Clear and re-enter it].
10. Unit Change - go into Service Mode, System 2, Unit Change.
11. List Output - Please Load 8.5x11 Landscape paper on Tray 1, go into Service Mode, List Output, and Touch Machine Management List and press Start.
12. Press Adjustments List and press Start.
13. Press Service Parameter List and press Start.
14. Press Fax Setting List and press Start.
Sep 04, 2009 | Konica Minolta Office Equipment & Supplies
Computer turns on and beeps
Have you recently changed any hardware or BIOS settings? Is it one beep for 8 seconds or 8 beeps? If it's 8 beeps then that indicates a bad video card. If you are not using the on board video then try re-seating the video board or try a different video board.
Mar 13, 2009 | Microsoft Windows XP Professional
I need a serial number for Nero 8
hi there!
please check these websites that could help you:
nero-8.en.malavida.com/d3948-free-download-windows
www.download.com/Nero-9/3000-2646_4-10028984.html
www.softpedia.com/get/CD-DVD-Tools/Data-CD-DVD-Burning/Nero-8.shtml
thanks and regards!
pls rate my solution. thanks again!
Feb 18, 2009 | Ahead Software Nero 6.0 (60045) for PC
1996 ford ranger 2.3L 8 plugs single overheadcam
belt was broken set crank on tdc on compression stroke set timing mark on com set timing mark on oil pump gear? try to start it cranks but wont run check for spark and its gettin but still seems to be out of time starter doesnt crank smoothly replaced starter cranks better but still doesnt run
tried turning crank 1 turn and reinstall belt with same results have any ideas
Dec 02, 2007 | Timex (T307S) Clock Radio
Black & Decker B2300 Bread Machine Logo
Top Black & Decker Kitchen Appliances - Others Experts
Greg Cann
Greg Cann
Irene Tulloch
Are you a Black & Decker Kitchen Appliances - Other Expert? Answer questions, earn points and help others
