Question about Radio Communications
I have a Bumblebee V2.1 BT-B11 Bluetooth headset. I am trying to connect it with my cellphone Nokia Lumia 928, but for some reason I can't connect, is it not compatible?
SOURCE: CANNOT PAIR AOEM BLUETOOTH HEADSET TO LG SHINE KE970 MOBILE PHONE
The mamual says to hold the - and + volume keys at the same time for approx. 2 seconds till the light starts to flash green and red. The pairing code is 1234
Posted on Aug 26, 2008
SOURCE: Unable to Detect the Jabra BT125 headset from any Bluetooth Device
If you hold down the button, it will turn the light blue, keep holding it till you can connect it. It will come up as Jabra BT125, hit connect. Then it will ask for a password. The password is 0000. Then it will connect :)
Posted on Dec 13, 2008
SOURCE: Hi. Can my SBH500 BT Headset pair/connect to a PC?
Make sure the headset is put in pairing mode, to do this, turn the headset off, hold the phone button(big silver round one on the right speaker), then turn the headset on. Hold the button until the blue light goes solid. At this point, your computer should be able to detect it. Be aware, though, that support for bluetooth audio on computers is weak at best.
Posted on Aug 04, 2009
SOURCE: My nokia E63 wont find bluetooth headset
I had a similar problem with my headset.. but found the solution.. I am using Jabra 2010.. ok.. so just switch "off" the headset...go to the pair menu on e63.. then switch on the headset.. and then look for new pair devices option.. voila it came up. hv been trying for almost 3 weeks before i got the sequence right.. somehow if u had switched the headset on beforehand.. it wouldnt recognise it only.. the solution is here at jabra website .. although.. they dont hv e63 listed .. but the same procedure for e71 worked fine for my handset..
Posted on Aug 05, 2009
SOURCE: Got a New Nokia BH-106 bluetooth Headset, i'm
i purchase new Nokia bluetooth headset BH-106 and i want to connect my laptop ( Dell INsprion N5010) plzz give some advise who to connect it.
Posted on Sep 17, 2010
Nokia Lumia 800 Windows Phone 7.8 Bluetooth not work properly
soft reset your phone if problem persists hard reset
Oct 21, 2014 | Nokia Lumia 820
How do I connect a plantronics headset to an NEC DT700 series phone
You can transfer photos from your nokia lumia 928 to laptop wirelessly or wired. Wired transfer is the easiest way when your unit comes with the data cable and the software. Now, if the software is not inclusive you can set your CP's connection settings "Connected as USB memory" however you may have difficulties in viewing since the connection layer platform is not capable of viewing the pictures or images but you can view later after you copied it on your laptop. Now, if your unit doesn't come with data cable and software either you can use the BLUETOOTH connection by simply turning or enabling both Bluetooth device on your laptop and cp which can be found in settings usually, once enabled and set visible you will noticed both devices sees each other with their name if not try to search manually by pressing search and chose paired bluetooth device with confirmed access code or id. Right then, when connection is successful you can start copying pics or images to your laptop. (Make sure you know the directory your pics are being copied, it is usually saved in bluetooth download images directory or other directory, pls manage to locate). Thanks hope this helps... Goodluck.
Oct 08, 2014 | Plantronics Radio Communications
How do I transfer pictures from Nokia Lumia 928 to laptop
You can transfer photos from your nokia lumia 928 to laptop wirelessly or wired. Wired transfer is the easiest way when your unit comes with the data cable and the software. Now, if the software is not inclusive you can set your CP's connection settings "Connected as USB memory" however you may have difficulties in viewing since the connection layer platform is not capable of viewing the pictures or images but you can view later after you copied it on your laptop. Now, if your unit doesn't come with data cable and software you can use the BLUETOOTH connection by simply turning or enabling both Bluetooth device on your laptop and cp which can be found in settings usually, once enabled and set visible you will noticed both devices sees each other with their name if not try to search manually by pressing search and chose paired bluetooth device with confirmed access code or id. Right then, when connection is successful you can start copying pics or images to your laptop. (Make sure you know the directory your pics are being copied, it is usually saved in bluetooth download images directory or other directory, pls manage to locate). Thanks hope this helps... Goodluck.
Oct 07, 2014 | Nokia Lumia 900 Smartphone Black Unlocked
I need the pass code to pair with nokia n70
I see you want your BT headset to be connected to your Nokia N70.
The pass code will be 0000 to be able to get the BT headset connected, Also make sure the phone Bluetooth settings is set to be discoverable in the Phone BT settings OK.
Have nice day.
Jul 25, 2011 | Plantronics Explorer 230 Bluetooth Headset
Hi, guys. I recently bought a Nokia BH-505 bluetooth headset. I succesfully connected it to the phone (s Galaxy S) and used all its features but i cant connect it to the pc. The pcc just doesnt see it. It...
Hi Bogdy_3003,
I see that you are having issue with your BT Nokia headset.
You mentioned that you are having issues connecting it to our PC.
You need to make sure that the Bluetooth settings on the computer is set to allow other devices to detect the computer to be able to get your Bluetooth Nokia headset working with your computer.
Look for the Bluetooth icon on the lower right side of the taskbar somewhere near the time then right click on it then select open bluetooth settings, it should open up a window for the Bluetooth on your computer then look for "Allo other devices to detect this computer" and put a check on it, click on Apply or OK, this should make your computer be detected by other BT devices such as your Nokia headset.
I hope this will help.
Have a nice day,
mvincentc
Jun 21, 2011 | Nokia BH505 Bluetooth Stereo Headset
I somehow unpaired my bt108 headset from my nokia e71 phone and can't get them to recognize each other again. I tried 1234 and 0000 as my pin and am away from my manual to check if it was anythin else. ...
Try completely deleting the BT1-8 profile from your cellphone, turn off the cell and the bluetooth, turn the phone back on and then the BT108 and set it to pairing mode and they should find each other again. One other note, make sure you don't have another unpaired, bluetooth capable cell phone nearby that's turned on or it could be interfering.
Sep 28, 2010 | Uniden BT-108 Bluetooth Headset
CAN'T CONNECT jabra 210 AND nokia e63
Go to this site, and it will walk you through each step to connect your particular Jabra headset with your cellphone. Choose the headset, and then at the next page, choose your phone. Moving your mouse over each step will change the picture to what you should be seeing on your phone at each step.
http://jabra.pairx.co.uk/ Pls come back and let us know if this solved your problem.
Oct 29, 2009 | Genius BT-03A Bluetooth Headset
Didnt connect bluetooth headset to N73
Sometimes what happens is that we keep looking for BT devices without making them visible. Is it so in your case too? Go to settings of the headset and make it visible and your mobile visible to the headset. then you must pair them and also authorize them to connect without pass code etc. Then they will work.
Aug 02, 2009 | Nokia N73 Cellular Phone
Connect headset to nokia 6500 slide
in some of the BT headsets you need to activate a function that makes them available to detection. try to long press the main button on your BT headset and then you should get 1 min for finding it with your phone/
Jul 19, 2009 | Cell Phones
Radio Communications Logo
61 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
