Question about Samsung YP-U3 MP3 Player
Lcd no light in call - Samsung YP-U3 MP3 Player
Nokia1616 no lcd light & no kepad light....
To fix this you need to contact a mobile technician.Anyway if you can do follow this link and see the emage.1616 light ways - Google Search.Good luck
Mar 13, 2012 | Nokia 1616 Cell Phone
The LCD not light fine ,ave a smoll under light...I dont know how the LCD ave failure. ....what i'm doing?
its not a lcd complaint, its a complaint from lcd light
so you need to change the lcd light ic
contact any service center to change the ic
May 13, 2010 | Nokia e65 Cellular Phone
Lcd light
More than likely you will need to replace the LCD screen. The backlight may have burned out making it blank.
A new LCD screen runs about 15 dollars shipped from ebay2.gif.
The W580i LCD screen is very easy to replace. Probably one of the easiest I have ever done.
Check out the following link for instructions on replacing the LCD display and links to buy the screen.
Sony W580i LCD Screen Replacement
I hope that helps you out
Jul 24, 2009 | Sony Ericsson Walkman W810i Cellular Phone
ViewSonic LCD (VA1912w) Went Blank
I am using this great LCD for about an year. But few times in the past my LCD didnt show up the display though the Green light was still ON, turning off the LCD and opening it again always solved the problem. But now My LCD completely went blank. Turning off/on didnt work at all now. I've tried couple of other tweaks mentioned on this site but they didnt work. I am just seeing a blank screen with green light ON. and ya theres a very low hissing sound coming from the LCD.
Feb 18, 2009 | ViewSonic VA1912w 19" LCD Monitor
Does a LCD TV have a light bulb in them? If so, how long should it last?
There are 2 kind of LCD vision, one have Bulb (its bit older ersion) and 2nd LCD have Back-Light for illumination. LCD with Bulb calls "LCD Projection" and back-light LCD calls "LCD TV".
If you need further info, please post back here.
Aug 19, 2008 | Televison & Video
My samsung 52" flat lcd hd tv
yours DLP TV not a LCD.
LCD has on one light with red.
If the DLP likes that.
1st -- check the thermostat
2nd -- check the power board.
Jun 10, 2008 | Samsung 52 in. LCD Flat-Panel HDTV
The LCD screen is hard to see. What should I do?
If the LCD screen is too bright or too dark, adjust the LCD Brightness setting in the Setup Menu. If you are shooting photos outdoors in bright light, move the joystick to the icon showing the sun over shaowed area to turn on Outdoor mode and make the LCD screen easier to see in bright light.
Sep 12, 2005 | Epson PhotoPC L410 Digital Camera
Low Lite LCD Use
The LCD is completely WYSIWYG and if you can't see anything through the LCD then the picture you take will be black too. If you are outside and open the shutter really wide you will see the LCD go white as the light overpowers the exposure. The best thing to do is to increase the ambient light in the area by turning on every light. You will still use the flash for the picture but you need to get more light on the scene to see through the LCD. For what it is worth, an optical viewfinder probably wouldn't do any better job in those situations.
Sep 11, 2005 | Sony Mavica MVC-FD88 Digital Camera
Samsung YP-U3 MP3 Player Logo
16 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
