Question about KitchenAid Architect Series KEBC208KSS Electric Double Oven
Fan makes noise turn noisy - KitchenAid Architect Series KEBC208KSS Electric Double Oven
    Problem Solver:
  • 3 Answers
If this noise is happening when the oven is off as well, it is a problem with the cooling fan that draws hot air out of the oven. These fans go bad after a few years and need to be replaced or repaired. Not a difficult fix, but the oven unit needs to be removed fromm the wall cabinet which is a two person job.
There are several web sites that sell the part. Try www.appliancepartspros.com or www.partselect.com.
The part number is either PS992856 or PS2348323 so I would call one of these companies and ask for help on the exact part you need.
Posted on Nov 20, 2013
Top oven (Grill) makes a noise when turned on
It will not be the grill that is noisy, but more than likely the top oven cooling fan located under the top cover of oven
Mar 27, 2015 | Ovens
Noisy fan
Only graphite lubricants are heat resistant. The fan could be worn out, bearings just well done. (oven humor).
Nov 28, 2013 | Ovens
How to fix noisy fan in chef fan forced oven
Possible fault in the bearing bushes , in the first place you can spray a WD40 or even some light oil into the fan's rotor ends where the bearings are located. If the sound reduces clean and wipe off excess oil from the shaft side. Also make sure that the fan leaf is not making the noise due to any dirt accumulation or obstruction.
Jan 09, 2012 | Ovens
My whirlpool oven (model rbs305) makes a loud noise whenever it is on. I can't figure out if it's the fan, or just extremely loud.
I would suspect that the blower is noisy its what i would expect to potentially make noise ...if fits in the back of the control panel and it comes on to cool the control board each time the oven is on.
In case it turns out to be the blower thats noisy the part number for it is W10176670
GENE
Sep 10, 2011 | Whirlpool RBS305PD Electric Single Oven
Noisy oven
Probably the fan bearing is worn out, looks like you will need a new fan.
Make sure there is not any obvious visual obstruction.
Jan 10, 2010 | Ovens
Candy oven noisy fan
Noisy fan means bushes are worn. cant be repaired. needs replacement. Quote model of oven to spare parts supplier and replace. Make sure power is unplugged and not just switched off before repairs are done.
Sep 14, 2009 | Candy FP855 Electric Single Oven
Oven blown up??? Is it a simple fuse or is it a big job???
sound like fuction switch has blown apart quite common and the noise is prob coming from cooling fan and not the main one inside.
Sep 14, 2009 | DeLonghi Ovens
Very noisy fan
Hi
you need to replace the fan as this will be the cooling fan which cools the oven down. and can not be disconneted .
regards
Mar 21, 2009 | Kenmore Ovens
Oven makes a noise when I turn it on.
If it is a fan assisted oven , then it sounds like a noisy oven fan.
It could be a worn or dry bearing in the fan motor. if you open the oven door , you should be able to tell if it is the fan by listening to it carefully.
The other possibility is if it has a cooling fan in the back or on the top of the oven, it could also be that causing the prob, these are about the only things that could be making a noise, as there are no other moving parts that could make a noise.
PLz rate my solution.
Thanks.
Jan 08, 2009 | GE JKP30WMWW 27" Built-in Single Electric...
Zanuisi top oven making noise
Yes , there is a cooling fan located at the top of the oven
It could be the fan blades catching, or a noisy fan bearing.
You would have to access it by removing the top oven cover to check., and yes it could be as a result of having it cleaned.
Plz rate my solution.
Thanks.
Dec 31, 2008 | Zanussi ZDF490 Electric Double Oven
KitchenAid Architect Series KEBC208KSS Electric Double Oven Logo
174 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
