Question about Samsung YP-U3 MP3 Player
Usb mp3 undetected - Samsung YP-U3 MP3 Player
Undetected in mac
The interface in the case would seem to have failed. They are usually not the same standard as those used in a computer.
May 01, 2013 | Toshiba Computers & Internet
Ipod shuffle undetected in itunes devices
check your cable cord... or pin connection..... that is only a problem
Mar 24, 2011 | Apple iPod shuffle MP3 Player
USB device is undetected
In order to connect it to your computer, you will have to install the software for your MP3 player. The setup CD should have been included in the box. Once you install the software, it will recognize your device when you connect it and you will be able to add songs.
Mar 07, 2011 | Coby MP-610 MP3 Player
Undetectable capacity
try pluging it in after you sign in to windows if you are using windows xp or newer if undetected restart the computer and login then try pluging it in it should show up in my computer as a removable Device the same as a:\ if tis dont work or you are useing a older vertion of windows or a Mac plz resubmit with Operating system included and metion this didnt work but it should
Jun 21, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
My broadband stick has become lose, i have to hold it to be connected to the internet, is that repairable?
I assume you are talking about a USB port that is loose. A usb Port is repairable but unless you have a hot air station I do not recommend you try it yourself. If you have another USB port try the broadband stick there if you have the same problem it is the stick that is the problem not your port. Good luck.
Oct 12, 2009 | 3G Technology GM-170 Monitor
How to solve undetect usb device? (using
Go to link
http://www.troublefixers.com/my-computer-does-not-detect-pen-drives-and-other-usb-devices-like-ipod-or-external-hard-drive/
Here u will get root of your prob
Sep 14, 2009 | fedora Linux Operating System
Device is detected, but I can't add music, because it undetects
Problem Solved: My MMP8567 screen read ''boot error shutting down''.
Everytime I plugged it in to the computer the computer would find it but then it would disappear almost immediately.
I downloaded the Updater program from Memorex but it couldn't find the player.
The directions from Memorex said ''Hold down the play button and plug in usb cable.'' Another set of Memorex directions said, ''Hold down the power button and plug in usb cable.'' Neither worked for me.
SOLUTION: I finally held down the LOCK/UNLOCK button and plugged in the usb cable. My computer found the player immediately and a software driver window popped up asking for a driver. I let windows search the internet and it found and installed the driver. The driver it was looking for was: ''player recover device class driver'' After windows confirmed it recognized my mp3 player I started up the Firmware update program and was able to update the player.
I tried to be clear and detailed. Good Luck ;-)
Jan 31, 2009 | Memorex MMP8567 MP3 Player
M-Audio Keyboard 49e disfunctions after some time
Sounds like it might be a power supply issue. Unless it is mains powered.
Try removing all other USB devised. If that doesn't work its worth try a Mains Powered USB hub.
Feb 26, 2008 | Computers & Internet
Not downloading
first make sure that it syncs in your computer. Does it show up in your "My Computer" or is it undetected. second you should be able to do that with a CD that comes with it when you purchased the item.
Jan 30, 2008 | SanDisk Sansa e250 MP3 Player
Samsung YP-U3 MP3 Player Logo
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
