Question about LG LFX25960ST Stainless Steel French Door Refrigerator
Panel you push to get ice is sticking - LG LFX25960ST Stainless Steel French Door Refrigerator
    Champion:
    Habit-Forming:
  • 279 Answers
Seems to be a regular problem with these, please call LG & complain loudly, you may get a positive response.
Posted on Nov 22, 2013
Ice maker is not making ice. what could be the problem?
The two most common things that happen: the ice piles up too high, which pushes up the bar that tells it the bin is full and stop making ice. OR the ice sticks to the ice cube maker. If the ice pile is too high, knock it down or empty the bin. If the ice is sticking to the cube maker, try melting it and then spraying it with a non stick spray. Sometimes the water supply line is clogged, but that is not usually the problem.
Feb 28, 2015 | Refrigerators
Dumping ice
If heater element is open the newly made cubes will stick to the tray and not be pushed out by the fingers doing the ejecting.
Apr 08, 2014 | Whirlpool 2198597 Ice Maker
Ice maker not pushing out cubed ice makes funny sound also has a chlorine taste even after changing the water filter
The ice cubes may have melted somewhat and are sticking to the bottom of the ice bin.
Take the ice bin out and dump the ice. Wash and DRY the bin. Put it back in and wait for more ice to make,then try your dispenser.
Let us know the outcome.
Dec 01, 2009 | GE Refrigerators
Hooked up water line and ice maker, water working notice maker. Any ideas?
Make sure wire loop extending out from the ice maker over the ice bin is pushed down. Up turns the ice maker off.
Without more info, I can't diagnose further.
Stick finger in ice tray where ice freezes. Is there water in there. No, check solenoid valve and water line to ice maker (kinks). Is there ice cubes in ice tray? Is ice maker pushed fully in? All wires to ice maker on back and underneath connected?
If this information was useful, please select YES to the first two rating questions. Good Luck and thank you!
Oct 24, 2009 | Maytag MSD2756G Side by Side Refrigerator
The ice dispenser chute sticks open allowing warm air into the freezer. Once the chute sticks open, you have to reset it manually but sticking your hand into the ice chute in the door.
There is a solenoid that operates the door that could have stopped working. Can you hear it?
The hinge on the door could be broken or the bracket it goes in could be broken. You'll have to look to see what's wrong.
Remove the dispenser cover by gently prying starting at the bottom going round and round a little at a time to prevent from breaking it. When it's off the screws will be exposed to access the other components.
Aug 15, 2009 | Refrigerators
My ice maker just stoped working when i open the freezer door i can hear what sounds like a scratching sound by the ice maker.
arm could be stuck help it along by pushing on the arm to move ice. some times a small ice will stick the arm
Jul 28, 2009 | Refrigerators
Ice that comes from the door is always crushed
empty out all of your ice than wait for it to fill up a new tray and than it should be cubed if it doesnt change you might end up sticking with it because you will need to change the control panel behind the buttons your pressing
Jun 08, 2009 | GE Refrigerators
Switch sticks for the ice and water. It wont shut off
Remove the water drain and the two screws behind it and lift up to remove the push button panel,unplug the push button panel. remove three screws holding the dispenser unit in place,sliding the water uotlet out of the way as you do. Next get to back of rubber cover and put a little lubricant(silicone lubricant would work,not too much, then test.Then test and reassemble.
Burkes of Byron Ga and Orlando Fla.
Jan 29, 2009 | Maytag MZD2766GES Side by Side...
LG LFX25960ST Stainless Steel French Door Refrigerator Logo
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
