System freezing every 25 minutes after reboot
The keyboaeds controlling the cameras and monitors are not working. The CC1 at the matrix (HUB) is stating system management is off line. and the master keyboard is stating 'Keyboard off line'. When i reboot the system it is fine but in 20 minutes exactly it fails again. the camera are still giving an image but the overlay that stats the time and camera name freezes.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 41 Answers
Your system is going into standby mode or hibernating i suspect!...go into control panel,click on power and set it to never sleep
Posted on Nov 21, 2013
5 Suggested Answers
SOURCE: Smartdisk Firelite usbflb80 stopped working
My Smartdisk Firelite 80 gig Mini-Drive will not power up when plugged into the front or rear USB Ports (Windows XP Pro System). Last used successfully on 4-Apr-08 with no issues. Any suggestions?
Posted on Apr 07, 2008
SOURCE: Seagate Free Agent Problem
i have the exact same problem... not sure what caused it... there was a massive power spike here, and that could be it... of cource most of the electronics fried by that do not even turn on, while that turns on just fine and flashed the yellow light...
the drive sounds fine itself, so the problem is most likely in the Seagate FAP case itself, probably the internal circuitry, as when i turn it on the drive spins up normally and does not make and noises that are the tell-tale signs of a dead drive... my suggesgion would be to crack open the Seagate case (i know i know, i thought it looked nice to, but would you rather have all your data or a nice-looking doorstop) and take the hard drive out, then connect it either 1) directly into your computer or 2) into another external hardrive case. As this hard drive has eSATA, it is probibly a safe bet that it is a SATA drive, so that's probibly the connection you need. Again, i have not tried this, but i will attempt it soon... what's the worst that can happen? my drive will not work inside the case, my drive will not work outside the case... same thing really... but this is the last time i buy seagate...
Posted on Jan 14, 2009
  • 15 Answers
SOURCE: I have a Maxtor 3200
You very likely have a power supply that has failed.
View my post on the Seagate Knowledge Base website.
http://forums.seagate.com/stx/board/message?board.id=PersonalStorage&message.id=1258
Posted on Sep 16, 2009
  • 83 Answers
SOURCE: My mouse and keyboard freeze up momentarily
need more input to isolate the problem... does this occur when on power... does this occur when not on power... if ur system is old then is there lint settled within ur fan vents... all remaining the same seeing such a precise count i would suggest get the mobo cleaned up and checked for dust and i would conclude that u either need a BIOS update a BIOS reset or a hardware assistance... hardware assistance in any form for laptop would be to replace the MOBO costly!
Posted on Sep 02, 2010
My asus universal 3.0 docking station will not show monitor with my ux32vd Zenbook
Ok It would help if you mentioned what operating system you have! Windows 7 or 8 or MAC
In windows go to display then resolution you will have a choice to duplicate displays or extend displays, make sure the external monitor is plugged in to the VGA or HDMI port.
Apr 05, 2014 | ASUS Universal Docking Station
System Initializing
Have you tried unplugging the monitor from the 120 volt supply for a minute or two then replug and turn on. Like computers and some flat panel TVs they can freeze-up after an unplanned power loss and need rebooting
Jan 12, 2014 | Samsung SMT-190 19" Flat Panel TFT LCD...
When the Pentax USB cable is connected to the computer USB outlet pictures do not appear on computer
make sure camera is in the play mode and powered on. If this does not work, sub out the cable to make sure it is not the cable. The last thing is to reinstall the usb ports - this is almost never necessary - but to do this start/control panel/system/device mgr, find usb root hub and right click uninstall to each. reboot and they will reinstall automatically.
good luck
Jun 16, 2011 | Pentax Optio M60 Digital Camera
I have a rebranded HP monitor that has a usb hub, camera, and card reader built in to the frame. TS-25W8HC is the rebranded model, the HP model is HP w2558hc. Problem: when I reboot computer system hangs...
This is normal for a lot of USB devices that draw current such as monotors, external hard drives, etc.
There is no cure except moving around USB cables, which MIGHT work.
Aug 15, 2009 | Computers & Internet
Windows xp is freezing when trying to start
Go into Safe Mode navigate to Accesories then go to System tools
Select System Restore pick a point before you installed the new monitor and let it roll back.
Re-start the system normally
Did you get a CD with the monitor ?, if you did then I suggest that you load that once you are back on line.
Once it is loaded try for a re-install
If the new monitor is a fancy one then it is possible it needs to have some communication with the PC on a regular basis to keep it happy
Jun 12, 2009 | Computers & Internet
Hi what is the matrix
A large scale security system that can have many cameras,. monitors, recorders , and sound. The matrix is the box that connects everything together.
Jan 15, 2009 | Matrix CM9760 Video Output Card 8 Outputs...
Monitor goes to sleep after 30 minutes vl1919
Welcome to FixYa! The default power saving feature is turning the monitor off. To change the settings go to the Desktop>Right click on it>Properties>Settings and you will see power saving settings where you can choose "Never turn off" or a longer time interval. These settings can also be found in your Control Panel for all of the Power Saving features for the computer, monitor and hard drive. Steve
Jan 03, 2009 | Princeton Digital VL1916 19" LCD Monitor
Acer monitor AL1916W
start up windows in safe mode and see if you still get the problem. did you use the same vga cable???
Aug 26, 2008 | Gateway FPD2275W LCD Monitor
Analog Power Saving Mode
I need more detail. Can he get into an operating system (Like windows?) Does he ever see a picture? At what point does it freeze? Can he access the system bios?
More detail please
Mar 27, 2008 | Computers & Internet
Memory upgrade
I like all the information you gave. However the information you are looking for is in the manufactures web site. goto search engine and enter your computers manufactures name followed by the word "support" find the site and then look up the details for your computer. The reason I say this is because each slot can only control a certain amount of memory. The manufacture will tell you what each slot can control and also the type of memory supported by your motherboard. THIS IS VERY IMPORTANT> never mix memory. Make sure of speed and capacity. If you mix diffrent speed and capacities the results could end in total failure.
Sep 19, 2007 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
