Question about Cameras
Moultrie m88 game camera no video mode,loud buzzing noise,bright flash on night pictures
  • 5 Answers
SOURCE: Moultrie Game Camera pictures come out white
call 1 800 653 3334 and talk to a service tech
Posted on Apr 21, 2008
SOURCE: Need plastic cover for Moultrie Game Camera model DGS-160.
Called Moultrie Feeder toll free number 800-653-3334 and ordered part.
Posted on Jun 19, 2009
SOURCE: moultrie game camera won't flash
we get beutiful day pics, but totally black pics at night
Posted on Aug 23, 2009
  • 296 Answers
SOURCE: moultrie I40 will not go to picture mode
are you pressing mode in setup window?
Posted on Mar 14, 2010
SOURCE: moultrie I40 getting error code 480 and wont go into auto mode
I lightly dropped my I40,about 24" off the ground,in grass.Thought I broke it.I had a 480 code. Opened battery compartment to reset and that fixed the problem.If your lucky this will fix alot of your sensitive electronics. Kill the power for 10 seconds or so and your cured.
Posted on Aug 23, 2010
How do you get the m100 to take pictures by motion only?
Search Results
    [PDF]Instructions for M100 GameSpy Digital Camera - TrailCamPro
    www.trailcampro.com/manuals/2012/m-100.pdf
    THANK YOU for your purchase of the M100 GameSpy Digital Camera. Please ... The Mode Button selects the 3 modes of the camera - Camera Setup Photo Review or ...Accepts the Moultrie PowerPanel accessory (sold separately) only. ... Camera operates in Plot Cam mode during the day and Trail Cam Mode during.
    Moultrie Game Spy M-100 IR Mini 6.0 Megapixel Digital ...
    www.walmart.com/ip/Moultrie-Game-Spy-M-100/16386230
    Walmart
    Rating: 4.5 - ‎21 votes
    MOULTRIE Game Spy M-880 Low Glow Infrared Digital Mini Trail Game Camera ' 8 ....You can easily hold this mini IR camera in your palm. ... MFH-DGS-M100 .... Will ittake pictures only on motion detection? ... can get any size you want but don't forgetyou will have a lot of photos to delete. ... A. Will do video clips and stills.
Dec 25, 2015 | Moultrie Game Spy M100 Game Camera
Why is it not taking pictures at night?
do you have it set to Infra-red mode, if not, black images in pitch black. Game Spy 80XD
Sep 04, 2015 | Moultrie 2012 M-80xd Digital Scouting...
No night pictures
You cant see infrared flash, but it is not working. The only way to check this is with special equipment. If the unit is new, send it back.
Nov 18, 2013 | Moultrie Game Spy M80XT
Resetting the Moultrie A-5 Game Camera
HARD RESET TAKE OUT BATTERIES SD CARD PUSH THE ON OFF BUTTON FOR ABOUT 5 SECONDS LEFT EVERYTHING OUT FOR 2-5 MINUTES. THEN PUT THE BATTERY BACK IN TURN THE CAMERA ON IT SHOULD SAY NO CARD. THEN TURN IT OFF THEN PUT THE SD CARD BACK AND TRY IT IN THE DARK AREA TO SEE IF THE FLASH WILL GO OFF. IF THAT DOESN'T WORK WILL NEED TO SEND IT IN FOR REPAIRS.
Nov 07, 2013 | Moultrie A-5 Game Camera
Won't take night pictures
Two possibles: either the IR flash is bad,or the day/night sensor is bad.Unless you have parts from another M80,best bet is to try Moultrie support and send it in. However, they may tell you to buy another camera.
Dec 28, 2011 | Moultrie M80 Game Spy Digital Hunting...
Moultrie D50 game trail camera won't take pictures in dark
Does the flash work? Could be flash circuit or day/night sensor.If you have another D40/D50 camera that flash works but has other problems,swap out the sensors.If not the sensor but the flash circuit then most likely one of the large charge capacitors which has to be soldered in.I use a digital multimeter with I/O capacitor test function..these caps should be about 250mfd.
Nov 21, 2011 | Moultrie MFHDGSD50 Game Spy Camera D50
It doesn't take all the pictures at night, i get some, maybe 1 or 2 then it skips and might take 1 more. takes great daytime photos. is there anything that can be done to fix it?
Hi mmcgee6,
You need to check the settings in the camera , as to whether it's selected on night mode or not , when you use the camera at night , and particularly if the light is not as bright as day light.
There should not be any problem with the night shoots from the camera if there is no problem in the day , it's just the settings that needs to be changed to night mode.
Also a good idea would be to set the flash settings on Auto instead of Off , or other settings , this will adjust the camera as per the environment in which you are clicking your pictures.
Hope this helps ....:)
Sep 01, 2011 | Moultrie D55 Digital Camera
My D40 camera will not make night pictures consistently. About 90% of the time pictures taken at night are just black. From what I have read on the forums this must be a very common problem.What is the...
D40s are well known for flash failures...in 3-shot burst mode, due to charge time of flash circuit, 1st pic good; next 2 black. Battery life greatly reduced in this mode.
Feb 26, 2011 | Moultrie GameSpy 4.0 Digital Camera Deluxe
My camera is set on autoflash but it flashes even in the bright day- light resulting in over expose, what could be wrong? It takes good pictures at night.
Yes I believe I fixed my problem. I shined a bright flash light at
the light sensing photocell and took pictures with it (no flash).
Then I darkened it, took pictures (it flashed). I did this back and
fourth and it seemed to work although I have not tried it in the
field yet. Thanks for your offer of help and I do think your
rates are reasonable.
Anthony 12-6-09
Dec 06, 2009 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Moultrie game camera won't flash
Jan 26, 2009 | Moultrie MFH-DGS-200 Digital Camera
Cameras Logo
23 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
