Question about Alpine CDE121
Installed Alpine CDE-121 in May, has worked great up until now. System works, but no sound comes out
I installed my Alpine CDE-121 into my car in May. The system has been great and working properly until now (November). Everything lights up and I can switch from Tuner to CD etc. but no sound comes out. I don't know much about electronics, help please!
    Top Expert:
  • Alpine Master
  • 36,569 Answers
Some models of some vehicles have a power amplifier that is separate from the head unit. You did not specify what you have your Alpine installed in but you may find the "no sound" issue involves a separate power amp.
Posted on Nov 17, 2013
Testimonial: "It is installed in a 2000 Pontiac Grand Am"
KaeZoo
  • 156 Answers
SOURCE: CDA-9885 Alpine No audio from Ipod - CD Playback not working
Disconnect whatever is attached to the BLUE wire at the back of the Alpine deck. Re-connect it to the BLUE/WHITE wire instead. This should solve your problem.
Posted on Aug 13, 2007
sir fixalot
  • 146 Answers
SOURCE: alpine 9881 cd will not play sound
If you had to connect the remote amp turn on lead from the headunit to the factory amp turn on lead you may find your problem there.
On many headunits there are 2 blue remote wires 1 for antenna and one for amp turn on. The antenna remote only supplies power when the radio is playing not when playing CD's. If you hooked the antenna wire to the amp trigger then the amps shut down when you play a cd. If that's not it let me know and I will research further.
Posted on Jan 04, 2008
  • 111 Answers
SOURCE: No sound from front speakers during CD operation.
I think you are using an external amplifier,if this is the case,you may be using the wrong remote wire for the amp.
Alpine use two blue wires,BLUE (only) this wire is for the pwr antenna and every time you insert a cd, this pwr line cut out.
BLUE/WHITE STRIPE this is the remote wire that you need to connect the remote of the amplifier.
thanks for rating
Posted on Feb 12, 2008
physicistFL
  • 34 Answers
SOURCE: cannot operate Alpine CDE 9881
Hello!
Hopefully this will help you out.  The manual for the 9881 can be gotten here:  http://vault.alpine-usa.com/products/documents/OM_CDE-9881.PDF
Copy the entire line into your browser, and you will have it.  Don't forget to save it to your system.  It is in PDF format, so if you don't have a reader, pick up one for free here: http://www.adobe.com/
Good luck with the "new" car and radio!
Ken
Posted on Jan 08, 2009
SOURCE: alpine cda 9884 has no sound in cd or ipod mode
actually, chrysler/dodge has factory Infinity sound systems installed. The nice part about these systems is that you dont have to bypass the amplifiers in order to put a new radio in, but simply power up the amp by hooking up the amp turn on wire at the harness. The alpine should have 2 blue wires coming off of the back, one that is solid, the other with a white stripe. The one that is solid only has 12v when the fm/am radio is on (used for power antenna) but cuts off when other sources are used (cd,aux,ipod). My guesses are, you have the amp wire on the vehicle harness (blue) tied into this wire, instead of the BLUE/WHITE wire on the alpine which has 12v as long as the radio is on. i hope this solves your problem, 9 times out of 10 on a chrysler this is it.
Auto Tech
DA2 (Supa)
Posted on Aug 31, 2009
Hi I have an Alpine CDE-125T and everytime I get back into the car I have to pair my phone with the radio again. Anyway I can fix this?
Sounds like the constant power memory wire (usually red or blue?) is connected to "switched" power incorrectly? Just a guess, but I have installed hundreds of radios...
Oct 30, 2014 | Alpine CDE-125BT Car CD/ MP3 Player
Pontiac grand am wiring diagram
You will need the wire harness that is designed to connect to the stock stereo. Another option is to just install your alpine stereo in the car since you have the wiring harness for that. You will not be able to wire the harness for the alpine unit and have it match the plug type for your stock stereo.
Dec 12, 2013 | Alpine CDE-121 In-Dash CD/MP3/WMA/AAC Car...
No sound coming from speakers
check wiring that goes into speakers or your main speaker wires at back of stereo
Jan 21, 2013 | Alpine CDE-121 In-Dash CD/MP3/WMA/AAC Car...
Alpine CDE-102 w/usb port: will not
Hello desoren,
The receiver may not be set to recognize MP3 files.
Press and hold "sound setup" until the unit enters setup mode. Rotate the volume knob to "play mode" and press "enter". Check that the setting is CD/MP3 (not CD/MA), or rotate the volume knob to change the setting to CD/MP3 and press enter again. Press and hold "sound setup" again until the unit exits sound setup.
If the files are still not recognized, I'd try using a different USB drive, a different computer to write the MP3's, and/or a different application to download or rip the original music content.
Hope this helps.
Sep 23, 2009 | Alpine CDE-102Ri CD Reciever, iPod and USB...
How do you hook up a subwoofer to Alpine CDE-7858
go into the menu of the radio make sure sub output turn on
Aug 28, 2009 | Alpine CDE-7858 CD Player
After installing the alpine CDE 9870 car stereo there was no sound... although the car speakers work.Maybe the audio in the stereo?Can thatbe fixed?
In this situation 8 times out of 10 the problem is not with the radio, it's that there are factory amplifiers. Many cars have them, and most require a little work, or an adapter to get going. Tell me the year, make, and model of the car, and perhaps I can give you more info.
Aug 09, 2009 | Alpine Car Audio & Video
I'm having trouble connecting my alpine cde-9852 to my 96 jeep cherokee. is there a wiring diagram online for this? thanks
Constant 12V+ Pink Switched 12V+ Purple/White Ground Black Illumination Light Blue/Red Dimmer Orange Antenna Right Front Front Speakers 5 1/4" Doors Left Front (+) Dark Green Left Front (-) Brown/Red Right Front (+) Purple Right Front (-) Dark Blue/Red Rear Speakers 5 1/4" Rear Deck Left Rear (+) Brown/Yellow Left Rear (-) Brown/Light Blue Right Rear (+) Dark Blue/White Right Rear (-) Dark Blue/Orange
Jul 11, 2009 | Alpine CDE-9852 CD Player
Equipment not turning on!???
Have you tried checking the remote wire yet? Because it could very possibly be that. Without a remote wire hooked up, you cannot get any power. Try that and see if it works.
Apr 29, 2009 | Alpine MRP-M500 Car Audio Amplifier
Alpine CDE121 Logo
168 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
