Question about Eclipse 4gb 2.8" Touchscreen Mp4 Player
Can not turn off built in speaker off - Eclipse 4gb 2.8" Touchscreen Mp4 Player
My speaker makes a realy loud buzzing noise when I turn the power on
Try turning the volume down before disconnecting.
Jan 06, 2014 | Car Audio & Video
Intenal speaker doesn't turn off when headphones are plugged in
try pushing your head phones in all the way. i didnt think you had to push so hard but apparently you do:/ hope i was helpful:)
Aug 26, 2009 | Emerson Audio Players & Recorders
No sound
If speakers are built into the monitor, then there should be an audio cable that connects from the monitor to the green speaker out jack on the back of the computer.
If speakers are NOT built into the monitor, then buy a set of speakers from a store.
Mar 27, 2009 | HP Pavillion s7420n PC Desktop
Emachine computer no sound at all
Built in pc speakers are just for error beeps etc. You most likely have on-board sound. I would try getting a sound card (with drivers) Put it in a free pci slot & connect your speakers to it. :)
Dec 01, 2008 | E-Machines T1742 PC Desktop
The built in speaker!!!
go into the settings, go to speaker and turn it off. have a nice day! :)
Jul 27, 2008 | Mach Speed TRIO Onyx MP3 Player
X-530
Have you switched off your built-in speakers? Go to control panel, click on sound, turn off your built-ins if they are on, and select the configuraion of your speakers--that might do it. If not, check device manager to see if any checks are present, which will identify where the problem is.
Apr 06, 2008 | Logitech X-530 Computer Speakers
No sound coming from speakers.
Did you run the audio cable from the computer to the monitor. If not you must have that for the speakers to work. If yes can you verify computer output with another pair of speakers to narrow it down to computer or monitor. If it is the monitor built in speakers that are the problem reply and we can go through a procedure to get them working.
Jan 18, 2008 | Cornea CT 1700 17" Flat Panel LCD Monitor
Flatscreen monitor with built in speakers
have a tech check your tv must be getting some voltage spike.good luck
Apr 15, 2007 | Samsung SyncMaster 151MP 15 in. LCD...
Eclipse 4gb 2.8" Touchscreen Mp4 Player Logo
27 people viewed this question
Top Eclipse Audio Players & Recorders Experts
Oloyede Monsuru
juanmireles1
Are you an Eclipse Audio Player and Recorder Expert? Answer questions, earn points and help others
