Question about Dryers
Maytag dryer I have a maytag dryer model # HYE3657AYW It will not start at all. I checked the circuit breaker. i found no problem their.
  • 1 more comment
  • mndnng Oct 11, 2007
    Thank You !
    It was the termal fuse. I really appreciate your help.
    mndnng
  • Bryanb1973 Oct 13, 2008
    was working fine, then last nite is just stopped? any idea?
  • april_fairba Dec 22, 2008
    My Maytag Bravo will not strat. All the light come on but will not start. I have check the breakers the plugs the vents. It only lights up but no spinning or heat. I have had this set for three months.
  • 94 Answers
Your door switch might be defective and/or your timer might be defective. If it has a fuse inside it might be blown.
Posted on Oct 07, 2007
SOURCE:
What will cause my maytag dryer to throw the breaker when i try to start it
Not a dryer pro but if the dryer is on a circuit that's already loaded up, or is overloading your current one (amps wise) that could cause it, and especially if the breaker is weak. Could be shorted capacitor or drive motor, or heating coil short situation. (wire melts, ends up shorting against housing). If the breaker checks out, suspect the heater element next, motor last, I'd say. Good luck. Maytag Dryer Trips Breaker
Mar 15, 2015 | Maytag Dryers
Maytag dryer hye3657ayw does not run. When I open the door the light doesn't come on but there is power at the outlet.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 07, 2011 | Maytag Dryers
Need routing for dryer belt on Maytag Dryer Model HYE3657AYW
Hi michaelpalma...
Go to this website for a picture of how to route your belt.
Free Answer...Please rate Me
http://www.applianceaid.com/images/belt-config.JPG
Apr 20, 2011 | Maytag Dryers
Have a Maytag electric dryer, model # HYE3657AYW, stopped working all of the sudden. doesn't do anything when I set the timer and push to activate. I checked the voltage at the plug, and at the back of the...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Sep 07, 2010 | Maytag Dryers
Heating element out, dryers runs
replace element but clothes still wont dry helpppppppppppppppp
Apr 21, 2010 | Maytag HYE3657A Electric Dryer
I have a Maytag Dryer Model No HYE3657AYW and it will not start at all. The inside light does not even come on. I checked the circuit breaker and no luck there either. Any suggestions?
a dryer is not working at all that's not good! But it doesn't mean you need to go appliance shopping just yet. It may be something very simple like a broken door latch, a bad door switch or even a broken door switch actuator, in a kenmore dryer there is a tab thats sticks out of a hole in the wall that allows the dryer to run only if the door is shut, other models may have button that protrudes out of the dryer and when the door is shut, this allows the dryer to run. These switches go out from time to time, also if a dryer is full of lint build-up over time this will cause the dryer high limit or fuse to blow. The fuse is located near where the blower is in most cases. When the air in the dryer gets way too hot the fuse/hi-limit will blow and the house wont burn down.
Dec 13, 2009 | Maytag HYE3657A Electric Dryer
My maytag neptune has no power any suggestions
Check for ~220 volts AC across the two slanted contacts on the dryer power socket. If nothing, check the house electrical panel for tripped dryer circuit breakers(pair)--push the breakers OFF, then ON to reset. Recheck for 220 volts at dryer socket--if ok now, try the dryer. You need to use a voltmeter for this checking. If it starts, then quits, you likely have an internal short (heating element) inside the dryer case that trips the circuit breakers.
Jul 23, 2009 | Maytag Neptune MAH9700 Front Load Washer
I have a maytag model HYE3657Ayw how can I open it up to clean lint inside the cabinet
first pull it away from the wall, then clean out the lint from the vent, then you will need to pull the front panel off, you should find 2 screws inside the door opening, and then you will need to pop loose the tabs from the bottom
Jul 10, 2009 | Maytag Neptune MCE8000AY Electric Dryer
How do I get inside the machine to change the belt? Thanks
most older models you can pop the lid and there should be screws on the inside holding the front
May 01, 2009 | Dryers
Maytag dryer model HYE3657AYW
I assume that your u.s. dryer is the standard 220 volt, and your question is what is the voltage in Mexico where your father resides. Most places in Mexico will have the 220 volt supply available. This should be easily found out with any cheap 15.00 meter. If the receptacle accepts the dryers plug, it is more than likely the proper voltage.
( Maybe your father is really wanting to save energy and realizes that his clothes will last forever when they are hung up to dry! )
Mar 04, 2009 | Maytag Neptune MCE8000AY Electric Dryer
Dryers Logo
474 people viewed this question
Top Dryers Experts
Marvin
Marvin
Craig Butler
Craig Butler
