Question about Panasonic Televison & Video
Cleaning VCR Head
Older, analog with built in VCR. What exact cassette head cleaner should I look for and where should I look for it
    Problem Solver:
  • 14 Answers
You can buy it on amazon, specific for job, look for video head cleaner... it will likely be alcohol based from memory
Posted on Nov 17, 2013
Panasonic 13" TV VCR Combo Unit White PV-C1332W put tape in and plays sound but just static shows on all movies?
You need to clean the video head. With these types of sets it's best to use a tape cleaning cassette. I should get a Scotch Head Cleaner Plus tape currently on sale on Amazon for around 4 pounds.
Nov 22, 2012 | Panasonic PV-C1332W 13 in. TV/VCR Combo
How do you get to the head to clean it?
Google for CD/DVD cleaners and VHS cleaners. A CD/DVD cleaner is like a CD, but has a small built in brush that'll clean the laser head. A VHS cleaner is like a VHS cassette tape, but instead of magnetic tape, it's a cleansing tape.
Jul 18, 2011 | GoVideo DV2150 DVD VCR
When i try to record a yellow arrow then a message saying need head cleaner but sony doesnt make that model head cleaner what do i do
Greetings Jerry - You don't need a Sony head cleaning tape. 8mm is a standard that was used by many manufacturers.
Head cleaning cassettes for 8 mm and Hi8 are exactly the same, there is no Hi8 head cleaning cassette except one that Sony used to sell for almost three times as much as a regular 8mm and offered nothing special.
Sony also made a bit of a big deal that you can't use "wet" cleaners inside your Sony Hi8 camcorders...also not true and Sony was just trying to part you from your wallet.
I can understand if you have some concerns about these things so I suggest you Google around something like "head cleaners for 8mm and Hi8."
Good Luck,
Mikeywaf
May 12, 2011 | Sony Hi8 CCD-TRV138 Camcorder
Hello. Where can i find a head cleaner (cassette) for my viewcam. aSharp vl-ah1511u
This is the head cleaner that you would need for your camcorder. These are the best! We use this particular one in our repair shop and they last a really long time. I have some that are over 5 years old and they still work.
http://www.amazon.com/Sony-V825CLD-Camcorder-Cleaning-Cassette/dp/B00005TQKQ
When using a head cleaner, play it for only 5 to 10 seconds at a time. If there is improvement, but it still doesn't look exactly right, run the head cleaner again for another 5 to 10 seconds. Repeat as necessary. The reason for this is because the tape is semi-abrasive and will wear down your heads (over time) if it is run for long periods of time.
Hope this has helped
www.austintelstarservices.com
Sep 09, 2010 | Sharp Viewcam VL-A10U Camcorder
I'm getting lines and mosaics on the video tape output of my Sony DCR-HC40, and a message on the viewing screen to use a head cleaning cassette. After a minute or so the lines go away and the video is...
NEVER try and manually clean your heads in your camcorder. The drum assy and heads are much more fragile and easily damaged than that of a VCR. NEVER spray any type of liquid/chemicals in or on your camcorder. A Sony miniDV head cleaning cassette is what you need. There are other brands out there, but Sony is hands-down the best. When using a head cleaner, play it for only 5 to 10 seconds at a time and then try your tape again. If it has improved, but still has problems then play the head cleaner for another 5 to 10 seconds. Hope this has helped. www.austintelstarservices.com
Sep 01, 2010 | Sony Handycam DCR-HC40 Mini DV Digital...
Sound but no picture
Most likely the VCR needs a head cleaning. This is common when playing older or rented tapes as the oxide recording surface can flake off and clog the video heads. You can try a head cleaning cassette. Make sure to get a wet-type cassette which you moisten with the included cleaning fluid.
Unfortunately this is not always successful for severely clogged heads. It may be necessary to remove the cover and clean the heads with a chamois cleaning swab moistened with head cleaner. Hold the swab flat against the round drum that holds the heads and move the drum back and forth while holding the swab steady. Repeat this for each of the heads. The heads are fragile and can be damaged by incorrect cleaning, so you might want to see what a shop in your area charges. (The shop I worked in used to charge $20, but that was several years ago.)
There's also the chance there's been head failure or some other problem has developed, but dirty heads are very common.
Jan 08, 2009 | Panasonic Televison & Video
Emerson vcr #vcr755
have you tryed to clean the ace head??? The ace head means audio-control-erase. and is on the right side of the mechanism. this head looks like a big cassette type head and is statioary. This head can be cleaned just like an 8-track{remember those??}or cassette head by applying rubbing alcohol to a q-tip and clean the head from top to bottom. this head also may need cleaning if your tapes seem to speed up and slow down for no reason and at random. Thats because the lower part of the head is the control head and that gives the machine pulses to tell the machine what speed the tape is recorded in then the capstain motor has an fg sensor(freqency generator} and they all go thru a comparitor and the sum of both pulses gives the machine the proper speed setting. Hope this was laid out in understandable english. Good Luck
Apr 26, 2006 | Emerson EWV403 VHS VCR
Televison & Video Logo
44 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
