Question about Kitchen Appliances - Others
Problems candy cm1146
Very loud on spin cycle, bounces round like it going to take off! part of seal torn away, is this just caused from that? do i just need new seal? (seal door to drum)
    Champion:
  • 252 Answers
This is not a cotton candy machine.
Posted on Feb 21, 2014
My problem first started with my maytag LAT9416AAE making terrible sounds and the smell of burning rubber. We replaced the belts that were loose and thought that fixed it. Now it is leaking water unde
Tub seal should take care of the leaking water sounds like you have a bad spin bearing from the water leak this will make a loud noise and put a drag on the basket trying to spin this will cause the belts to slip giving you the burning smell since you have it torn down remove the lower pulley lift out the transmission and change the bearing below it this is the spin bearing.
Jan 18, 2014 | Maytag Washing Machines
Drum is loud during spin cycle
A loud whinning or rumbling sound when it is in the spin cycle means that the bearings in this washer has failed. It is an expensive repair since the washer has to be torn complete apart to get to the bearings. Also, the manufacturer does not sell you just the bearings and seal but, you must buy the rear tub with the bearings which raises the cost of the repair significantly. For example the rear tub for this washer can cost $250 not including the shipping. So get a few estimates before deciding whether to repair or replacing the washer.
But, if you have the mechanical ability to do the work yourself and you are interested in getting the bearings and seal parts to get your washer going again. There is this site that has videos describing what it will take to fix this washer and will sell you the neccessary parts. The link to this site is: http://www.hometask.com/washerrepair.aspx
Feb 22, 2011 | Frigidaire GSTR1670A Front Load Washer
During spin cycle washer is making loud noise
If it is making a sound like a loud rumbling sound similar to a jet plane taking off, it probally due to the seal has failed causing water to leak into the bearings. The bearings begin to rust, and no longer round and the noise gets progressively louder. It can be rather expensive to fix. Get a few estimates before deciding whether it is worth fixing.
Aug 30, 2010 | Maytag Neptune MAH6500A Front Load Washer
I bought a candy washer 2 days ago and when it spins it bounces around n is very loud. also it makes a squeaky noise when drum turns as if the seal is to tight against the drum, please help . sal.
Make sure the shipping bolts have been removed, and make sure there is no polystyrene packing that needs to be removed.
Make sure the washer is absolutely level as well.
If all else fails, then I would recommend you contact the supplier, and relate the problem to them, more so as it is a new washer.
Hope this helps.
Jan 18, 2010 | Candy Washing Machines
Water leaks from under during spin cycle
There are multiple reasons why your washer would leak during the spin cycle. The wash tub seal could leaking, The tub bearing could be leaking, The carbon seal on the top of the tub boot could be worn. The water injector tube where it connects to the top of the tub could be torn from age. Even the tub to pump hose could have a hole in it. These are the most likely causes. There is one more item being the stem seal could be shot but this would cause water to leak all of the time.
Jan 06, 2010 | Maytag Washing Machines
When entering spin cycle, making a loud noise. I
Check your belt it may be lose. A lose belt will cause a squealing noise and the machine spin slower or take time to come up to full speed
Oct 09, 2009 | Fisher and Paykel GWL11 Top Load Washer
Dishwasher making loud noise during wash cycle
It's noisy If your dishwasher seems noisy, check these:
Water-inlet valve
Motor
Heater fan
Pump
Water-inlet valve An aging water-inlet valve can sometimes fail slowly, rather than all at once. It can shudder on and off rapidly, causing the incoming water lines to shake, rumble, and rattle--sometimes violently. If yours is doing this, replace the inlet valve.
Motor If it's the motor that's noisy, either of these may be the "culprit:"
  • As motor bearings wear out, they can become quite loud when the motor runs. They wear out quickly if they frequently get wet, because the water washes away the motor bearing grease. Bearings can get wet if the spin seal is defective. Then there will also be water leaking onto the floor beneath the dishwasher. Replace the seal if it leaks (read about the main tub seal in the "It leaks" section, later).
  • If, from beneath the dishwasher, you can see a round, plastic disc that's mounted to the top of the motor (a "slinger"), it may have broken free of the motor shaft. If so, it could be rattling around the shaft while the motor is running. If that's the problem, you need to replace the motor.
Heater fan If the heater fan bearings are rusted or worn, they may squeal, or scrape loudly during the drying cycle. If this is the problem, replace the fan motor. Alternatively, the fan blade may be loose. If so, you need to replace it.
Pump Small fruit pits, toothpicks, and fragments of glass sometimes get stuck in the pump. When this happens, open the pump and remove the debris. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher.
To get to the pump, you usually need to remove the lower rack, the spray arms, and the spray arm support from the inside of your dishwasher. A dishwasher pump isn't obvious. Look for an impeller--a round, plastic fan blade-type device that spins around and pushes the water toward the drain. When you can see the drain impeller, you should be able to see the clogging debris.
thanks and accept the solution accordingly
Apr 03, 2009 | Kenmore Dishwashers
Kitchen Appliances - Others Logo
1,337 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
