Question about Air Arms S410/S510 Magazine, .25 Cal, 10 Rds. airgun magazines
Airarms s510 not hitting accurately
Pellet was stuck in s510 barrel.anyhow I cleared it after dismantling the barrel with a rod.now the gun is not hitting accurately.is the barrel damaged or something else?? can I replace the barrel ,if so from where?????
Pellet Stuck in barrel daisy 880 rifle
You should get a thin dowel or gun cleaning kit with a small rod. And drive the pellet out from the long end.
Apr 01, 2017 | Optics
The gun fires but the pellet will not leave the barrel. The barrel is clear and black smoke comes out when fired.
Assume this is a conventional air weapon powered by a spring.
I suspect the main pressure washer is defective. The gun will need dismantling and a new washer fitted. It could be wise to also replace the spring and the breech seal.
May 21, 2016 | Optics
Can't find the specs in ftbs. my Gamo .177 Bone Collector is rated a 1300ftps. How far can expect to shoot accurately with this break barrel pellet gun?
Depends on who is shooting. But just test your skills on a 75 yard range. Shooting competition, with the special competition guns are shot at 10 meters (about 30 yards) Without a scoop, they easy shoot 80 % of all pellets through one .177 hole on 30 yards.
Mar 12, 2015 | Gamo Bone Collector .177 Caliber Hunting...
Crosman 760 Pumpmaster air gun
You need to use a rod to knock out the stuck pellet. A brass rod, available at your local hardware store can be used to good effect. Use a small hammer to tap it out.
Jun 20, 2014 | Optics
Pellets jammed in the gun's barrel
The best way I found to fix this is to break the gun down. Once you've done that you can slide the barrel out and use a push rod to remove jammed pellets. To stop this issue, I've read to not use short skirted or pointed pellet.
Jan 02, 2014 | Gamo Pt-85 Blowback
I'd like to know how can clearing pellets that were retained in the barrel of the 85-pt
The only way I found to fix this was to break the gun down and remove the barrel. Once you do that you can use a push rod to remove the pellets. By sure to push them out the way they went in.
Crosman 1377 single shot pellet air pistol-how do i remove pellet from barrell?
if you dont have a cleaning rod for it you can go to your local bass pro/cabelas/outdoors store and get a cleaning rod for a .17 caliber for fairly cheap. you should be able to push the pellet out or clean it if there is dirt or grime in it. and make sure you use the right caliber pellet! (:
Dec 24, 2011 | Crosman 1377 177 Single Shot Air Pistol
Point of impact changes with every shot
Mount the rifle with the scope and make a mark on the backstop right where the crosshairs are pointed at
Shoot several times, several shots will surley jolt the scope some.
If the crosshairs have moved much past your mark then this would indicate the scope is the issue.
If the crosshairs are still pretty well centered to the mark, its not the scope.
If at the same time your grouping looks terrible, and your scope still is on the mark, and the gun is WELL mounted, then the issue is with the accuracy of the rifle.
Make sure the rifle is mounted good for this to ba accurate .
Hope this helps
Jul 30, 2009 | Tasco Target/Varmint 6-24x42mm Rifle Scope...
Every time i set the scope the pelets hit ese
I would check your pellets.
Light pellets typically perform horrible in break barrel rifles due to their tendancy to fly around
Make sure you have a stiff, tight fitting pellet. Smaller soft pellets also will contribute to accuracy issues as they deform much and can let air escape from around the skirt when fired (called "blo by")
Jun 26, 2009 | BSA Air Gun Scopes
Air Arms S410/S510 Magazine, .25 Cal, 10 Rds. airgun magazines Logo
Top Air Arms Tools & Hardware - Others Experts
Are you an Air Arms Tool and Hardware - Other Expert? Answer questions, earn points and help others
