Question about Lionel 027 Left Hand Remote Control Switch 665121
027 switch repair
Repair
Valve repair kit for Schroedahl leak-off valve
Usually, the rubber gasket parts had become brittle. Just replace these parts and the entire component is now "refurbished" and good to go for another 5 years.
Nov 12, 2013 | Valve Repair Kit
Scan error 027-519
unable to scan doc error 027-519
Apr 19, 2013 | Xerox Phaser 3635MFP/X Multifunction...
Switches
Make sure you have the insulation pins in place.
Mar 11, 2012 | Lionel 027 Left Hand Remote Control Switch...
I have a pair of vintage 027 remote switches (right & left hand). When I flip the lever on the remotes, the track will only switch in one direction. I can't get it to go back.
First reverse the remote wires and see if the switch track throws in the direction it didn't before. If it does then there is something wrong with the remote switch. If not, then you can wire the switch terminals directly to the power source and turn on the power and see if the switch throws. First do center and right terminals and then center and left terminals. If no sound or buzz the solenoid may be bad. If buzz then see if the rails are stuck and can't move. May need grease.
Jul 30, 2011 | Lionel 027 Left Hand Remote Control Switch...
What remote code I can use with Unoversal remote Sony RM-V202, to be compatibe to 13TVR62 GE.
Hello
Remote codes with Sony RM-202 to GE Telivision are:-
002_018_003_007_045
For GE TV/VCR combo:
TV:027 & VCR:024 or
TV: 027 & VCR: 025
OK
Dec 22, 2010 | GE 13TVR62 Combo
Whenever a piece of rolling stock sits on any portion of the switch track, the solenoid begins to vibrate. This happens with all 6 of my Lionel 027 switches. How can this be stopped? I sometimes have to...
You must use insulator pins on the inside rails than come off the frog. Also make sure each track after the switch is wired with the same polarity. Keep power to center rail and ground to the same outside rail.
Nov 16, 2010 | Lionel 027 Left Hand Remote Control Switch...
Code need for tv matsui
Here is a list of the codes for that brand. All are 3 digits.
003 004 009 013 019 025 026 027 028 030 051 062 068 091 123 147 148 164 169 173 180
Sep 10, 2009 | StarTech.com StarView SV211K 2-port KVM...
Lionel 027 Left Hand Remote Control Switch 665121 Logo
51 people viewed this question
Top Lionel Crafts & Hobbies Experts
Jeff Hogancamp
Jeff Hogancamp
J.D. Browning
J.D. Browning
ray gallant
Are you a Lionel Craft and Hobby Expert? Answer questions, earn points and help others
