My Sylvania portable dvd player was working fine in my car with it plugged into cig. lighter plug then today it was playing a movie & halfway it stops turns off & I can not get it to come back on at all even in a different car!!! It's only a year old!!! What could be wrong?
SOURCE: DVD player reloads after 5 minutes into the movie
I have a K715 that was having the same problem. The "line select" had been switched from "in" instead of "out". Once I switched it back to "out", the player worked normal.
Posted on May 12, 2008
SOURCE: Looking for a replacement battery for Durabrand PDB-702, does not hold charge
Hi... I have a battery from a unit that has an unrepairable AC power connection on the DVD player.... Interested?
Posted on Mar 05, 2009
seabelow
  • 95 Answers
SOURCE: dvd player won't work when plugged in with car adapter
1 st Check and see if you have power coming out the power plug.
2nd. Ckeck and see if the fuse is ok in the unit.
3rd Check and see if your cig ligter works in your power outlet.
Posted on Jun 10, 2009
  • 44 Answers
SOURCE: what adapter can we buy to plug the venturer
What I did with mine is check eBay for a 12 volt, DC LCD monitor adapter. These normally have sufficient amperage to handle these players.
I did a search on eBay today using search phrase:
"new power supply ac adapter for LCD monitor 12v 5a"
and came up with one for about $14.00 with shipping. You will need to check the plug when you get it and, if it does not fit, get one from Radio shack or, as I did, cut one from an old adapter I had laying around.
Most of these units require that the positive side goes to the center conductor of the plug (check the diagram on the player case over the plug to be sure) so make sure you set it up the way the diagram shows or very bad things will happen to your player.
You may be able to find a 12 volt adapter at Radio shack or somewhere else but these units need (according to the specs) about 1 amp from the supply to work and charge correctly. You "may" be able to get by with an 800 milliamp supply but I have not tested this.
Good luck
Posted on Apr 18, 2010
SOURCE: insignia dvd travel theater (IS-PD040922) was
I am having maintaining power problems with my PD040922 when I try to use it the system clicks and goes back to LOADING option. I have tried to work through this problem by removing battery and just have mains power connection. Then I just use fully charged battery with the same problem occuring. Is there a solution, other than buying a new player?
Posted on May 25, 2010
My Sylvania portable dvd player is havving issues where when I plug it in and put a movie in it will say loading and start blinking in and out but if I take the movie out it stays on the main screen no...
Easiest and most obvious answer is clean the dvd off. Toddler, fingers touch everything. Fingerprints on the dvd and the laser can't read enough of the disk to start playing the movie. Try a dvd that works in a home unit. If it still doesn't work then would suggest that the laser lens needs to cleaned or else the unit has gone bad.
Aug 19, 2014 | Televison & Video
Venturer psv 1371 dvd player will not charge any
It exists, my brother has that one--I'm looking to buy the same one! Where did you buy yours so recently?? We don't charge his, just plug it into car cig.lighter.
Sep 01, 2009 | TruTech PVS12701 Portable DVD Player
Insignia car dvd player car adapter doesn't work
Your power adapter for the car is not working. Check if there is any voltage output while plugged in.
Aug 11, 2009 | Insignia Dual 7" 16:9 Widescreen LCD...
Dvd player won't work when plugged in with car adapter
Jun 10, 2009 | Zenith DVP615 Portable DVD Player
Cig power/3.5 jack problem
You have to be using the wrong cable, my friends cable comes with 4 tips , i believe the 3 tips give you this problem
May 27, 2009 | SanDisk Sansa e260 MP3 Player
Cigarette lighter plug not working
hopefully nothing serious. if you can, make sure your wires did not burned or got too hot.Visually inspect them. Then, if you have a voltmeter check to see if you getiing power to it. no voltmeter? Go to your nearest auto parts store and ask for a test light. Back to the lighter, if you have power on the wires or wires leading to the back of the lighter, more than like it you lighter burned out.  No power on the wires? make sure wire did not get fryed or burned, all wires look good? check fuses again.  worst case scenario, can't find problem ? you can run another wire from your fuse box to the lighter.
May 13, 2009 | 1994 Toyota Celica
Insignia ns-pdvd8
You might have cooked it.  Do you know the power ratings on the car lighter adapter you used and do they match what's on the bottom of the DVD player?
Sep 17, 2008 | Insignia NS-PDVD8 Portable DVD Player
2nd screen and car charger
the only thing u can do is replace the light sockets with factory or some type of after one that u would have to rewire yourself instead of cutting the cord to the devices
Aug 05, 2008 | Durabrand Portable DVD
Portable tvs in car
check that your cigarette lighter connections are not rusty or corroded. If they are, take a fine grain sand paper and sand the metal connectors to remove the corrosion. good luck!
May 27, 2008 | Durabrand Portable DVD
Dvd players not working
i went to radio shack and bought an DC to AC converter (plugs into your cig lighter and has a DC plug at the other end) and just use the other DC provided plug. it works much better. I bought one by "powerline" that has dual plugs and a usb port. it has a long estension and the unit can sit away from the cig lighter.(great for lap tops and other stuff to be used in the car as well!) its also fused. solved all my problems. it cost about 30$.
Sep 01, 2007 | Durabrand Portable DVD
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
