Question about Matsonic MS9158E+ Motherboard
Speakers and headphones
I would like to know if it is possible to plug speakesr in the back of the pc and headphone boom mike in the front and operate simultaneously. I would also like to know how to get the connections in the front of my pc to work as when I connected my mike up there I couldnt hear a thing
  • Anonymous May 15, 2008
    I have aproblem with sound device I have no sound
  • 91 Answers
Give your board to the hardware vendor and tell him upgrade the BIOS . if you were using the same board with win XP for last four year then problem is with your BIOS.
Posted on Oct 08, 2007
Speakers do not work. Headphones do. Tried adjusting volume but nothing changes
Possible causes are:
faulty conections on speaker cables, check all conections.
cable damaged, replace cable
speakers faulty, replace speakers
Feb 03, 2016 | Dragon Touch Touch7 Blue Dual Core Y88...
Why do I only hear static
Hi Cathy.. it sounds like you might be connected to the wrong jacks instead of the output that the headphones need.
Most high quality stereo headphones have a single 1/4" stereo plug that would readily plug into a 1/4" jack on the front of the stereo labeled "PHONES" or HEADPHONES".
Many lower quality "computer headphones" or headsets have two 1/8" plugs. One is often black or red and is for an included microphone that may be a boom type (shown below) connected to one of the speakers or an "in-line" type built into the cord itself. The headphone speakers in the headset get their signal from the other plug - which is usually green; but could be any color really. There should be 3 metal parts on the stereo headphone plug. The tip, the middle ring and the bottom ring. Many times the mic is mono (not stereo) and only has only a tip and a bottom ring on the plug. You can see stereo headphone and microphone plugs he picture below:
Computer Headphones or "Headset" with mic and phone plugs.
Your Yamaha stereo will probably NOT have 1/8" jacks to directly plug the headphone into. You can buy an adapter that you would plug your headphones into and then plug the adapter into the 1/4" jack on the stereo. One is pictured below:
Front and rear views of a "1/4" to 1/8" Stereo Adapter Plug" The front plugs into the stereo and the the smaller 1/8" headphones plug into the rear.
I hope this helps & good luck!
Jan 21, 2012 | Sennheiser Audio Players & Recorders
No sound from headphones. Speakers work. Win7
Please clarify, Where is the Headphones connected? Front or back? if you tried it on the Front port without success, Plug in the speaker jack to the port where you did connect the Headphone and verify it's working or not. You can also try the headphone on the port where the speaker is connected.
Awaiting.
Nov 03, 2010 | HP Pavilion m7480n (882780389410) PC...
Using headphones
You can get a set of speakers that has a headphone jack on front (it will shut off the speakers when headphones are in) or you can unplug the speakers and plug in the head phones. Some PCs have a red and green jack in front - plug in headphones to the green, you should have the speakers shut off till you unplug. All else fails they make a headphone/mic extender that sits like a hockey puck on the desk, has cables to the mic and speaker jacks on back of the PC and on the puck part has a jack for speakers, mic and headphone - some switched manually by you, some switch when the headphones plug in. If you had posted the model I could see if your machine has front red and green jacks.
Jun 19, 2010 | E-Machines eMachines Desktop PC
Dimension 4700 my headphones work fine but i cant
Are you have the headphones and speakers both pluged in? When you plug in headphones the speakers get muted. You need to change your sound settings back to your sound card if you use usb headphones. The plug on the front of the 4700 also automatically mutes the speakers.
Dec 13, 2009 | Dell Dimension 4700 PC Desktop
Speakers work in the front headphone jack on my Dell PC, but not in the audio jacks in the back of the computer
I think most computers do not have headphones in the rear, just LINE OUT, which has no enough volume to be used for headphones.
Dec 03, 2009 | Bose Companion 2 Computer Speakers
I need to add outdoor speakers,and the headphone
I would run the headphone jack to an amp then hook up you outdoor speakers to the amp.
Oct 07, 2009 | Sirius SUBX1 Universal Plug and Play Boom...
Logitech system where do you plug in the earphones there are sides on goes in the speaker where does the other go
Plug the headphones in where the speakers are plugged in. You use either the Headphones or the speakers. Plug the headphones into the green jack and if it has a mike, plug the pink mike jack into the the pink jack.
Hope this helps. Bud
Apr 27, 2009 | Logitech QuickCam® Chat Web Cam
Can't get headphone jack on front of computer to work
The headphone jack up front may not be connected to the PC's integrated audio on the motherboard (or to the PC's sound card if you purchased one with the system instead. There'll be an audio cable running from the front of the computer to a port on the motherboard. If you look at this motherboard diagram for the Vostro 220 (not the 420 or 220s), it'll be the port numbered "15" that's the opne for the audio for the front panel. You don't need the speakers plugged on the back to have the headphones work, but having them plugged in will at least tell you if the sound is working or not.
Mar 27, 2009 | Dell Vostro 220 Desktop Computer
Matsonic MS9158E+ Motherboard Logo
56 people viewed this question
Top Matsonic Computers & Internet Experts
David
David
Computer Links
Are you a Matsonic Computer and Internet Expert? Answer questions, earn points and help others
