Question about Whirlpool Duet GHW9150P Front Load Washer
Not draining and a buzzing sound. - Whirlpool Duet GHW9150P Front Load Washer
  • 23 Answers
Check the pump. Sometimes the plastic impeller gets stalled out from debris, or the impeller breaks off from the armature. You might have a clogged pump inlet hose, remove it and clean out all of the lint, coins, pins, etc..
Posted on Nov 18, 2013
Frigidaire front load washer that will not start . it just buzzes. when it does start it stops after washing and leaves water in clothes asn buzzes.
it could either be a bad door switch or something stuck in the pump or a bad pump.if you set it to drain/spin will it drain out the water or does it buzz there?if it does drain i'd have to say you have a bad door switch.the model number you sent doesn't come up,you can unplug the machine,remove the hose that goes to the pump or run it before you unplug it and see if it's the pump making the sound or if the center of the pump can be removed to clean out the pump and check the pump for coins and junk,use a shop vac and vac out all the water in the tub and then lossen the hose or center of pump until water starts to leak out and vac it up as it comes out,check the pump and put it back together,add some water with a bucket or something and see if it drains out,if it doesn't drain and it sounds like the pump is making the noise you have a bad pump,if it buzzes and it's not the pump change out the door switch.the buzzing is electrical,things that could make this sound are the motor,the solenoids on the water valve or the door switch,if you can do some checks like see if it drains or try to find where the noise is coming from would be helpful.good luck and i hope this helps you out.
Oct 29, 2011 | Frigidaire ATF6000ES Front Load Washer
When washer turns on there is a horrible buzzing sound, e 20 error message was on before
This is a blocked drain error code (E20) which can be due to a clogged/kinked drain hose, blocked drain filter/coin trap, or a broken drain pump. The link below provides the detailed troubleshooting procedure of this error code. In addition, replace the drain pump after having found no problem with the drain hose, cleaned the filter, and checked the drain pump impeller but the drain pump just hums, buzzes or whirs.
Error Code E20 on Frigidaire Front Load Washing Machines
Aug 25, 2011 | Frigidaire Affinity ATF7000E Front Load...
I have an affinity washer and dryer. The last loand did not complete its cycle. It is partially full of water, but not enough to seap out. Itmakes a buzzing sound and will not spin. It is not the type of...
It sounds like the drain pump has stopped. If it still has water in it and you turn it on (in the spin only cycle) the drain pump should be running and you sould be hearing the water drain. The washer will not spin until the water is out. Depending on how handy you are determines whether you can access the drain pump and remove the obstrustion. There is also a trap to catch debries from going into the pump. This could be plugged, but normally you don't hear a buzz. You hear the drain pump working but no water going out. Good luck
Apr 23, 2011 | Frigidaire Affinity ATF7000E Front Load...
Maytag Model #MAT13MNAGW When the machine gets to the spin cycle it doesn't spin but makes a buzzing sound. Something like the buzzing sound that a welder makes when the rod sticks.
this means that there is something stuck inside your drain pump.if you still have water in the machine you can use a wet/dry shop vac and attach it to the end of the drain hose and remove all the water in the tub.
once that is done check your drain pump for obstructions if there is no obstruction look at the hose that comes down from the bottom of the tub to the drain pump
Feb 08, 2010 | Washing Machines
Me Estate washing machine, when started fills to specified water level then, it makes a buzzing noise then the buzz quits and nothing happens. Machine won't agitate or drain, just buzz then buzz quits.
sounds like you have a problem with your water supply to washer. the buzzing noise sounds like it's the valve opening to receive water but nothing going in. check supply hoses and water taps
Jul 14, 2009 | Washing Machines
Kenmore portable dishwasher not working
is the buzz sound when you ask it to drain or ask it to fill with water? or is the buzz sound when it is trying to wash? IF it is when you ask it to drain either you have something stuck in your air gap causeing no drain or there is something in your pump I would check the easy stuff first by checking the air gap this is if it is buzzing when you ask it to drain. let me know what is the senario.
May 29, 2009 | Kenmore 17252 Free-standing Dishwasher
Kenmore front loading washer won't drain or aggitate, just buzzes
take the front bottom panel off. inside there is a drain pump. you need to remove filter from drain pump its look like a knob. be careful because their is water inside your drain pump so use some big thing for water. clean your filter. put filter back tight. i hope will solve your problem.
May 23, 2009 | Kenmore 43142 Front Load Washer
BUZZING SOUND WHEN RUNNING
It sounds as if there is something in the bottom part of the dishwasher arm (it sprays the water around the bottom of the dishwasher). I would suggest that you take out the baskets and then remove and clean all of the parts that water comes out of as well as the bottom drain. If this works or does not, I would also suggest that you run an empty load using 1/4 cup vinegar. Hope this helps!
Mar 16, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Does not drain & makes a loud buzzing sound(KENMORE 44042)
this sounds like something has gone into the pump, coins or whatever, the objects need to be removed, also check the hoses, remove the plug to work on any appliance the buzzing is the pump trying to work but unable to go round, start there and see how you go if i have helped rate me please
Sep 12, 2007 | Kenmore 44042 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
32 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
