Question about Universal NIB LUXPRO PSP511L Digital Programmable Thermostat
Psp511 heat won't turn on
Digits blinking. Heat won't turn on. Fan works.
I have a Big Maxx heater and it won't stop blowing and won't heat. The fan just keeps running! Anyone know what could be wrong?
Your pressure switch may not be activating (ie closing and making contacts) This means you could have a blocked flue, clogged pressure switch tube or a bad pressure switch. The pressure switch is a safety feature to ensure your exhaust is not blocked and operating correctly. Find owners manual. Look at trouble shooting section. Open cabinet and look for error code light. If blinking 3 times, try "jumping" the pressure switch. To jump pressure switch you need to clear code be turning off power. When the unit/thermostat calls for heat the power vent fan starts first, this is when you need to jump the pressure switch. You need to do this in sequence. That is the unit first starts the power vent exhaust thus activating the pressure switch allowing the ignition cycle to the burners and heat. So the power vent fan needs to start first BEFORE you put the jumper on to bypass the pressure switch. Once the jumper is on it will call for ignition after approx 30 seconds. If ignites your problem is one of the 3 stated at the opening of this paragraph
Mar 21, 2013 | Mr. Heater Natural Gas Garage Heater -...
Compaq presario cq62 won't start but the caps lock led blinks continuously and the wifi led remains on continuously, tried new cpu, worked for a while and started same problem again.
those are blink codes, learn to count them.
if you pulled the CPU i bet you that you used the wrong heat sink compound.
The CPU shuts off all by itself if too hot. your job is to get the fan working and the heat sink working and that thermal compound right.
hp.com
as the blink codes we are not HP here, ever
https://support.hp.com/us-en/document/c02222922
Jun 01, 2017 | Compaq Presario CQ62-209WM
No heat till you start driving and then fan will kick on and not shut off but it doesnt overheat
You won't get heat right away. The heat has to have time to reach the heater core. That's where you get the heat for the passenger compartment. But if the fan isn't turning off, then I would have it checked for an electrical problem.
May 05, 2012 | 1999 Dodge Caravan
My Luxpro psp511 ca is locked and I don't know how
TO LOCK THE KEYPAD: Start with the System Mode switch in either the
HEAT or COOL positions, and the Set Slide switch in the RUN position.
Perform a single press of each button, in the following sequence: NEXT,
NEXT, NEXT, HOLD.
TO UNLOCK THE KEYPAD: Start with the System Mode switch in either
the HEAT or COOL positions, and the Set Slide switch in the RUN position.
NEXT, NEXT, HOLD. The padlock should no longer be present, with the
thermostat now unlocked. If the padlock is still on the screen, please try
to enter the 4-button sequence again.
Jun 01, 2011 | Heating & Cooling
My lux pro psp511 unit is not heating and blows out cold air, i let it sit for about 10 minutes to see if anything changes, still change, my apt community sent out maintenance and he said lux pro psp511...
To getproper heat, keep your temp setting at 30+ degree and also mode in "heat"position. If still no heat, check your heating sensor for closed circuit by anOHMs metre.It it's with RV, check power to RVHelpful?
Dec 30, 2010 | Heating & Cooling
Fan will not work
mcdevito75 here, Most likely yes, Check the fan by carefully turning it just a liitle by hand, also check for heat at the fan motor base, close to the ceiling. If heat or fan won"t start by hand, replace it.
Jul 25, 2010 | Hampton Bay 24002 Ceiling Fan
The heat will not turn on
If the fan is blowing with no heat, it is an indication you have an error code. Check the control board for a blinking light. If you find one, look on the wiring diagram that is pasted on the reverse side of one of the panels for a diagnostic chart. It will give you a starting point where to look for the issue. You can always jump the red and white wires on the thermostat and if the furnace starts, it's a bad thermostat. If not, look to the blinking light.
Mar 07, 2010 | Honeywell Electronic Programmable...
Ruud achiever 90 plus won`t start at times
sounds like you have a heat pump heat pumps dont work below 30* temps you should have some type of backup heat
Feb 05, 2009 | Ruud UBHC Air Conditioner
Universal NIB LUXPRO PSP511L Digital Programmable Thermostat Logo
74 people viewed this question
Top Universal Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you an Universal Heating and Cooling Expert? Answer questions, earn points and help others
