(i'VE INSTALLED FREASH ALKALINE BATTERIES AND STILL NOT WORKING
Close the [Memory Card / Battery Cover] securely, and then turn the power on.
Clean the battery terminals with a dry cotton swab that has a fine and soft tip, and then re-insert the batteries.
If your camera uses four AA-size alkaline batteries supplied with the
camera, follow the procedure below. In addition to Alkaline batteries
you may use optional nickel metal hydride (NiMH) batteries.
1. Be sure that the camera power is off.
2. Slide the battery cover lock in the direction of the arrow, and push the battery cover slightly forward. Then open the cover.
3. Insert the batteries as shown.
4. Close the battery cover.
* For the PowerShot S2 IS, PowerShot S3 IS, and PowerShot S5
IS the batteries are inserted in a slightly different order, please
refer to the decal inside the battery door for the correct order.
Installing batteries in cameras with 2 batteries.
If your camera uses two AA-size alkaline batteries supplied
with the camera, follow the procedure below. In addition to Alkaline
batteries you may use optional nickel metal hydride (NiMH) batteries.
Please see the various examples to find which type matches your camera.
Example 1:
ok I put fresh alkaline battaries in ,inserted the memory card and turned it on. NONE of the buttons work and the device is telling me there is NO memory card .Themem card is a SanDisk SDHC 8 GB
