Question about Kitchen Appliances - Others
Hygena hotplate shows L on all controls No power available
All controls show L when switched on .no power available for cooking.
    Champion:
  • 252 Answers
This is the wrong section for ranges. There is a Popcorn popper called Diplomat made by Cretors,
Posted on Nov 19, 2013
Creda Cooker
It is under the ceramic top. Fixings are at the rear.
Dec 18, 2014 | Cars & Trucks
Fan motor is slowing down and not keeping the desired temperature
The circuit diagram for the standard control model shows the blower has a two-speed motor, connected directly to the power line in "Cool" mode, or connected to the temperature control in "Cook" mode. When the blower slows down during cooking, switch it temporarily to "Cool" mode. If it goes to normal speed, the problem is with the mode switch contacts or the wiring terminals between the fan mode switch and the temperature control board, or the control board itself.
If the speed does not change, check the wiring terminals at the speed switch common terminal (I assume your problem occurs in both low and high speeds). If you find tarnished, loose, or burned terminals, clean, repair or replace as needed. (In extreme cases, a loose terminal will cause the wire to overheat, damaging the insulation, oxidizing the terminal and causing a high-resistance condition that will reduce the voltage available to the motor.) If the connections are all good, the motor bearings are probably getting sticky at high temperatures. Let the oven get hot enough for the blower to slow down, then shut it off and check the blower bearings while wearing oven mitts.
May 12, 2014 | Southbend SLGS-22SC Gas Double Oven
JVM231WV001
It sounds like instead of an overheated magnetron thermostat tripping the power, you now have a defective door switch.
Our door switch help file is here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Nov 27, 2012 | GE Profile Spacemaker Over-the-Range...
Hot plate just wont turn on...switches checked in meter box and no iscolating switch. baumatic ceramic cook top. BA 13.2 ( i think) house just been sold. Hotplate wked thurs. House sold Fri. new owner...
Hello, is this a two electrical filament hot plate? Also, is this range stove/oven? I'm a little confused here on what exactly what you are referring to hot plate or cook stove with electrical burners and oven. If it a really old hot plate with one burner look at the plug there could be a fuse in it. If it is electrical range then check the control board and see they a fuse on. If not, check the voltage with a volt meter. Be very careful here there two phase that is 240 Volts AC. The voltage will be split between the two l20 hot legs AC which is 120 degrees out of phase in respect to each other; in other words, don't both of them don't let them touch each other.
If it a kitchen stove I'm fairly sure that the control board is shot and with this not operating it will not open the current/voltage relays for the electrical burners. REMEMBER YOU ARE DEALING WITH 240 VOLT AC...BE CAREFUL.... GB....stewbison
Aug 26, 2011 | Baumatic Microwave Ovens
The left front burner will turn on for a few seconds then turn off then back on and off. It would not heat the pan on it. This is a glass top range. Are there any tests that I can do to find the problem?...
If the rest of the hotplate elements are working correctly and you are performing the same tests with all of them then you have a problem. We know that the hotplate works. When hotplates are faulty they don't turn on and off, they just don't work. This would generally be a hotplate controller problem. It sounds as if the controller is faulty and requires replacing. If you are handy you can switch the suspect hotplate controller with a good one and see what happens. This will confirm our suspicions.
Mar 04, 2011 | Kenmore 96412 / 96414 / 96419 Electric...
When you punch in the time to cook for, shut the door, the clock counts down, but nothing happens. When you lift up on the door, the fan and light comes on, but it doesn't appear to acutally cook any of...
This is usually caused by either a bad door switch, a loose door switch mount (which are pretty simple problems to fix) or occasionally a problem on the control panel.
Actually, I would say the bottom door switch is bad.
The service manual is here. Also see our file on door switches here.
If you only need a switch, you can order a universal type here for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases with a one-year guarantee.
Nov 21, 2010 | Frigidaire FMV156DC Microwave Oven
Hello, I have a 7 year old GE Advantium oven that the microwave has quit working on. The power and timer come on but the actually cooking element of the microwave is not working. When testing the oven...
I would first suspect the primary interlock (top door switch) or maybe that switch's mount is loose or broken.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
We have the service manual and have uploaded it here to help you.
Aug 19, 2010 | GE Advantium 120 Convection/Microwave Oven
I have a neff T1.D20 dual circuit hotplate but although the inner lights up and gets hot the outer part doesnt. Is the outer part supposed to?
I have a T172 model which also has a dual circuit hotplate.
In the control area you should find a dual circuit control pad - this has two concentric circles on it. With the hob switched on, pressing this button will chnage the mode of the dual circuit hot plate bewteen:
1. Just the inner part
2. Both the inner and outer together.
When the hob is switched off using the Standby control pad, it remembers which mode was selected and will therefore work the same next time it is switched on. However, it is worth noteing that when the mains power to the hob is interuppted, either by an isolator switch/breaker, or a power cut, the hob defaults back to just the inner ring mode.
Oct 03, 2009 | Neff T1323 Electric Cooktop
Have a baumatic ceramic hob displayin letter 'L'
Got the same problem, and remembered I've kept the manual book
L means locked. I dont know how Ive managed to do this as well
Anyway it says:
Cancelling the key lock
After switching ON the control the child safety feature can be deactivated. Here it is necessary to simultaneously operate the front right cooking-zone-select-key and the MINUS-key and then operate the MINUS-key alone. If all steps hae been carried out in the right order within 10seconds the key lock gets cancelled and the control is OFF. Otherwise the input will be considered incomplete, the control remains locked and switches-OFF after 20 seconds.
After a renewed switching-ON/OFF key all displays show 0", the display dots are blinking and the control is ready for ooking. If a cooking zone is "hot", "H" will be displayed instead of the static 0".
Followed their instructions & still not worked. ,I am still confused and baffled after these instructions........................
Mar 28, 2008 | Zanussi 23 in. ZKT641H Electric Cooktop
Kitchen Appliances - Others Logo
54 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
