Question about Samsung DMT800RHS Dishwasher
I have a DMT800RHS dishwasher displaying an oE code. How can I fix it?
3 Suggested Answers
Macmarkus
  • 2605 Answers
SOURCE: My dishwasher will not drain
Hello, Welcome to FixYa.
The 0E code as it pertains to your Samsung is as follows according to the Samsung service manual...
ERROR TYPE - High water level detected.
**before proceeding turn the dishwasher power off via the home breaker panel, or unplug it from the wall if that is possible...most are hard wired to the home electrical...safety first**
The first thing to do is remove the toe panel/kick plate and inspect the base for water. There will likely be water present.
With the aid of a sponge, towels, or a wet-dry shop vacuum, absorb the water from the base, that should restore normal operation...it should be known that if you leave the unit for a few days, the water in the base will evaporate hence appearing as everything is fine again...if any other problem/leak does exist it will return.
If the unit works fine after resetting the power/breaker and soaking up any water present, it can likely be chalked up to a drain back-up or obstruction in the drain hose or pump... (it could mean a faulty drain pump so you'll need to pay close attention the next few times you run it)
If you don't think this is something within your scope of abilities please call an authorized Samsung service center in your area.
Let me know what you find and I'll be glad to help you in whatever manner I can. I do have a service manual for Samsung dishwashers ( essentially all the same as for components and repairs) but you'll need to provide an email address for me to send it via pdf attachment. Good luck.
Regards,
Macmarkus :)
Posted on May 02, 2011
SOURCE: 9E error code on dmt800rhs dishwasher
I had same 9E low water level error. Removed the lower nozzle, then the plate at that bottom (lots of screws to remove) that covers the float. On the underside of that plate was a thin round piece of rubber that I think you would call a gasket. It was far to big and excess gasket was outside of the groove made for it. The excess was in the area around the float. I figure it was interfering with float operation. I snipped it and retreaded it into the groove. I have not had a 9E error since and have cancelled service call that would have cost me min $104.
Posted on Jun 16, 2013
Samsung dishwasher code 9E
Internet search "Samsung dishwasher 9e error code". Many videos to watch to show you how to fix the problem yourself.
Sep 05, 2015 | Samsung DMT800RHS Dishwasher
How do i fix "OE"code.
if it is like my dishwasher the oe code means the unit is over filled with water. My dishwasher had a major fault that blew up a circuit board and had a faulty front assembly. Still in repair shop waiting for parts.. I would deduct that the washing machine is not emptying water so I think a water pump could be failing. My dishwasher was not activating the washer motor and came up with the same code but..
Apr 03, 2015 | LG WD-12126RD Front Load Washer / Dryer
Fixed problem after viewing 93 code but now dishes have brown film or white film. Dishes still dried on food. Have a Samsung DMT800RHS. One suggestion was to get phosphorus which is ******* for deterg
look at the arm that has the water nozzles on it to see if some of them are plugged. Also make sure the screen at the bottom of the machine isn't restricted.
Nov 06, 2014 | Samsung DMT800RHS Dishwasher
I am getting a oe code how do I fix it
Open the back and switch the wire round about.
grant
Nov 03, 2014 | Samsung DMT800RHS Dishwasher
Samsung dmt800rhs errorcode 9e
http://www.youtube.com/watch?v=HXHRPd8VisE The water level float switch needs to be cleaned. There is a micro switch on the assembly don't get the switch wet. This video will show you what to do.
May 06, 2014 | Samsung DMT800RHS Dishwasher
I also had the 9E error code on my Samsung dishwasher DMT800RHS mmodel. I had to call Samsung and the nearest authorized Samsung service representative came to my house last Tuesday, January 29, 2013. The cost of the call is $100 which really annoyed me off considering the dishwasher is only 1 1/2 years old. Two South Korean guys showed up and to fix the problem just press down on the Heavy, Delicate and Power button at the same time for a few seconds and a menu will appear on the top left hand corner of the panel. Scroll down the menu by pressing the Normal button until you reach "FT" and the dishwasher will automatically fill up and then autimatically drain. If it does not drain then scroll down to "S" and the dishwasher will drain. Thsi should get rid of the 9E error message and your dishwasher will work fine but if not you have to repeat the procedure maybe 2 or 3 times until the 9E error message disappears. If you constantly get the 9E error message then you may need to replace the part which is about $60. The part is extremely sensitive to either hard water or food particles which is why the 9E error message appears. Therefore, scrape your dishes thoroughly so the food particles are minimized and the sensor does not go off which causes the 9E error message.
Nov 21, 2012 | Samsung DMT800RHS Semi-Integrated...
Samsung dmt800rhs error code se
Thank-you so much I was able to fix the problem. there was a small piece of plastic stuck in the pump house which was connected to the pump. Hopefully no more 5e errors ):
-Abdul
Oct 29, 2012 | Samsung DMT800RHS Dishwasher
LG model # LDS5811st stops and displays OE. What does that stand for
Here is a tip that I wrote about the LG OE Code and the causes and fixes...
Here also is the complete list of LG Codes
heatman101
Aug 22, 2010 | LG 24 in. LDS 5811ST Stainless Steel...
Samsung DMT800RHS Dishwasher Logo
136 people viewed this question
Top Samsung Dishwashers Experts
vince
gbob59
Are you a Samsung Dishwasher Expert? Answer questions, earn points and help others
