Question about Brother MFC Office Equipment & Supplies
My BROTHER MFC -2770 won't scan
Won't scan
SOURCE: my brother mfc 210c won,t scan or copy
I just called Brothers product support and found out that these machines WILL NOT scan or copy or do anything until the ink cartridges have been replaced. So there is no other solution.
Posted on Jul 28, 2009
Patzky
  • 240 Answers
SOURCE: Have MFC 5890CN Brother. How can I scan legal documents?
To scan legal documents you need to set the scanner to legal. GO to Start menu / all programs / brother / scanner utility and set the size to legal.
Thanks,
Pat
Posted on May 12, 2010
whammy45
  • 84 Answers
SOURCE: brother mfc-7840w won't receive fax
The first thing that I would try multiple people to ask them to fax you.Sometimes the 2 machines don't "sync".This is a toll free fax test number that I always use to check my machines..1-888-473-2963.Just write the words "FAX TEST" in large letters on a blank sheet of paper..fax it to that number...leave the line open...you should get a fax back in about a minute.If you get a fax back...your machine is fine...let me know if this was helpful....thanks.
Posted on Dec 14, 2011
alicantecoli
  • 22156 Answers
SOURCE: Brother mfc-6890cdw won't turn on. No power at all. Is there a fuse?
I would imagine their is a fuse inside somewhere ,open it up and look around where the power cable comes in but first pull the power cable out and check for power on the end with a multimeter
Posted on Feb 14, 2012
  • 29 Answers
SOURCE: BROTHER MFC 230 will not feed paper after a jam. unjammed paper. reset. still won't feed. help!
Had a similar problem with a HP laserjet and after much searching discovered a tiny piece of paper stuck in the printer. When you remove jammed paper make sure that you follow the manufacturers instructions, and verify that no torn off bits remain in the printer. A piece of paper 2mm wide or less could be the cause of all your problems and can be very hard to find.
Use a torch.
John
Posted on Oct 26, 2012
My brother mfc-7420 will print but won't let me scan and i can not find my disk
Go to the Brother web site and put in your MFC info and you may download it for free. If you find it to be difficult you may call Brother for support and they will walk you through it. Do not have to be under warranty. Hope this help you out.
Aug 28, 2012 | Brother MFC 7420 All-In-One Laser Printer
Brother mfc-7840w won't receive fax
Dec 14, 2011 | Brother MFC 7840W Printer
I just want to scan. I can't find ink locally and I don't need it, yet Brother tech support says to correct the problems that come up on the lcd screen. The only error is "Replace...
From past experience and current research, you can not scan with an error on the LCD screen. Therefore you would have to replace the ink before the scanner will work.
Sorry to be the bearer of bad news.
Aug 29, 2011 | Brother MFC-620CN All-In-One InkJet...
I have a 210C and it won't work with my new Windows 7?
Use the Windows Update to install your MFC 210C AIO printer drivers.
Refer to this link @ http://www.brother-usa.com/lp/windows7compatibility.aspx#WinUpdate
Hope it helps.
Aug 12, 2011 | Brother MFC 420CN All-In-One InkJet...
My MFC290C printer will not print in black. I changed the ink and it still won't print black. I changed the color of the type and it will print in colors, just not black. I ran the cleaning cylce...
You need to call Brother at 1-877-brother and tell them your mfc is "missing black". They will tell you where to take it to get the print head replaced under Brothers' warranty. This is a VERY common problem and Brother will cover the cost to repair it.
Aug 10, 2011 | Brother MFC-290C Printer
Press the scan button on MFC - 255CW and it lights up but screen says Replace C ink. Why wont it scan.
The machine won't scan unless both cartridges are installed and have a good supply fof ink in them. I know the ink level has nothing to do with the scanning procedure, but Brother has them coded to where they will not work unless both cartridges are present and full of ink. Replace the cartridge and it should scan just fine.
Apr 22, 2011 | Brother Computers & Internet
My brother mfc 210c won,t scan or copy
Nov 26, 2007 | Brother MFC-5840CN All-In-One InkJet...
64 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
