Question about Vehicle Parts & Accessories
1996 olds achieva passlock sensor, replaced it and still doesn't run
Need to by pass it?
  • 975 Answers
Can but it's a bit involved ,there is a relearn procedure after the replacement,did you do that? Try to start,leave ign. on for about 1 min, try again,repeat once more.
Posted on Nov 17, 2013
I have a 98 Olds Achieva SL. My Key has no chip and I was told I do not have a passlock system. I have read everything because the security light is flashing and the car will start and shut right off. I...
Your car has a pass lock sensor made on to the ign. lock cylinder. It reads it from the cuts in the key. You may try another key that is not so worn or you may have to get another lock cylinder. Anti-theft computer requires reprogramming procedure with installation.
Sep 11, 2011 | 1998 Oldsmobile Achieva
Can i use a 1997 Olds Achieva O2 sensor on a 1996 Olds Achieva?? both are V6 3100 motors..
Yes pretty much all the parts on a 96 and 97 olds Achieva will interchange with out any problem, and the o2 sensor is no exception. Hopefully this answers your question, and if you have any other questions please feel free to ask.
Aug 27, 2011 | 1996 Oldsmobile Achieva
98 olds acheiva won't start, replaced starter and solenoid and tried the turn key on for 10 minutes then turn off and start, did not work I see no chip in my key but security light stays on and car...
If the security light is on, then it can only be one thing. The security system is failing and immobilizing your car. Go to this link and read up on the problem. The security light is a dead give away that the security is messed up. If you have no little black chip in the shaft of your key, then this means you must have a passlock that runs on the transponder. You need the PERMANENT fix from this site. http://vatspasslockpasskeysecurityhelp.yolasite.com/
Jun 16, 2011 | 1996 Oldsmobile Achieva
Where is my crankshaft position sensor on a 96 olds achieva 2.4?
On your 1996 olds achiea the crank sensor is located on the front of the engine , its near the crank pulley,look on the front area on the backside of the engine.
Apr 11, 2011 | 1996 Oldsmobile Achieva
NEED TO OVERRIDE THE PASSLOCK SYSTEM ON MY 97 ACHIEVA
go to search on computer and type in- 97 olds passlock when page comes up click on first link, this page should help you!
Sep 27, 2010 | 1997 Oldsmobile Achieva
Want to replace the computer on a 1996 olds achieva is it easy?
ECM IS LOCATED ON THE RIGHT SIDE OF THE INSTRUMENT PANEL ITS NOT HARD OR EASY BUT WHEN REPLACING ECM IT HAS TO BE REPROGRAM NOT A HOME FIX UNLESS YOU HAVE A GM TECH 2 SCANNER TO REPROGRAM ECM WITH.YOU HAVE TO REPROGRAM IDLING - CRANKSHAFT SENSOR - AND THEFT SECURITY SYSTEM.
Aug 20, 2010 | 1996 Oldsmobile Achieva
Have a 96 Olds Acheiva. It starts and runs for about a second then quits. It will only start when the gas pedal is half way pressed. Any other position and it will not start at all. Is this the fuel...
If the security light is blinking, the car thinks its being stolen and has engaged the antitheft, passlock system. All you have to do is leave the key in the ignition, in the on position for about 30 mins... this will reset the passlock system, then your car will start.
Aug 19, 2010 | 1996 Oldsmobile Achieva
The car fires but stops immediately
I had a problem with a 97 Achieva recently.Someone else replaced the PCM/ignition switch and passlock sensor.I replaced the ICP.Engine would turn over but wouldn't start and the security lamp was dim and flashing and then it would go solid.I tried the wait 10 minutes thing but,the light would never go off! I put the original passlock sensor back onto the lock cylinder. But this is what fixed the problem.I cleaned the contacts on the black wires and green on the ignition switch with tv tuner cleaner! After I cleaned those contacts the security light was flashing brightly.So I turned the key to run and left it there.After a few minutes it stayed on solid.I waited about 10 minutes but the light never went out.So I turned off the switch and then tried starting.It started right up and the security lamp flashed and then went off.Has started every time since.Note:I also scraped the pins that I cleaned with the cleaner with a knife.
Nov 11, 2009 | 1997 Oldsmobile Achieva
Security light flashing and car won't start now
does it start at all, or does it run for about 1 second and shut off? if the latter, then it's the passlock system, and he could have a defective key or security module. the keys have a predetermined resistance value which activates the passlock system to prevent hotwiring. If it is the passlock system, then sometimes you have to wait 15-20 mins for it to reset before starting the engine.
Jun 20, 2009 | 1998 Oldsmobile Achieva
Vehicle Parts & Accessories Logo
46 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
