I have Frigidaire Affinity ATF7000EGO washer. i just replaced the door striker but now everytime it goes to start cycle starts buzzing and reads DR....
    Sergeant:
    Champion:
  • 223 Answers
Double check that the mechanism is fitted correctly and all wires are attached as off the top of my head that is the error code for the door not sealed properly. Hope this helps.
Posted on Nov 18, 2013
dblred
  • 68 Answers
SOURCE: my Frigidaire affinity washer doesn't
If the washer fills with water, but will not start the wash cycle or spin, it is 1 of to things. the most common for frigidaire front load affinitys is the door lock assembly. I have had to replace numerous of these. if the door lock indicator is not on when it tries to wash, you need to replace the door lock assembly. if the door lock indicator is on, but wont wash, it is likly that you have a bad motor control board.
Posted on May 06, 2009
  • 4 Answers
SOURCE: frigidaire affinity front load washer doesn't start
mabye there is something keepin the door open, thats usually why most washers dont start
Posted on May 11, 2009
localwonder
  • 6784 Answers
SOURCE: my frigidaire affinity wont start
Yes, the original issue was the control from the beginning. the control is damaged and it cannot register the latch at this point. this is necessary and , it will fix the issue.
Posted on May 29, 2009
SOURCE: I have Frigidaire Affinity washer that beeps and blinks "dr"
Actually don't buy a new door mechanism yet. There is a metal ring that holds the rubber tub to the rest of the washing machine. It has a spring at the bottom of that ring. Pull it down and you will be able to get the ring off. Carefully peel back the rubber tub on the right had side near the door latch. Reach in side and unplug the bottom connector for a few seconds and plug back up. (Do this all with the power on). Then put the rubber tub back around the frame and put the metal ring back on. This should solve your problem. I had the same issue not too long ago.
Posted on Sep 06, 2009
SOURCE: My Affinity Front load washer, Model #ATF7000ES1
I am having this same exact issue, have you figured out what the was?
Posted on Sep 11, 2010
Washer states sensing with a buzz sound?
Hello keisha, thank you for your post!
I understand that your Frigidaire washer is making a buzzing sound until the cancel or start button has been pushed. It sounds like it could be a possible issue within the door either not being fully closed or it could be a defective switch. I would recommend resetting your appliance which can be done by disconnecting power to the appliance for roughly ten minutes. Please comment back if that did not help correct the issue. -Matt
Sep 05, 2014 | Frigidaire Affinity ATF7000E Front Load...
My frigidaire affinity front load washer buzzes and will not cycle what wouldcause that?
Good Morning Friend,
I see that your Frigidaire Affinity washer, model# ATF7000E, is buzzing and will not cycle. Some possible causes of this could be:
-Your washer is overloaded with clothes. Try taking some clothes out and restarting.
-There could be an article of clothing that might have slipped in between the gasket and the drum that might be stopping the drum from spinning. Check to see if there are any clothes that might be missing and possibly stuck between the drum and gasket.
If you have tried the above solutions and are still having trouble, I suggest giving your washer a hard reset. You will do this by either unplugging it or shutting the power off at your home's circuit breaker for 2-3 minutes. After the time has passed, restore power and start a cycle. If your appliance is still buzzing and not spinning, I suggest that you contact your local authorized technician for further assistance. They will be able to diagnose your washer and determine the cause of the buzzing and why it is not spinning. Hope this is helpful.
-Best Regards-
WP
May 05, 2014 | Frigidaire Affinity ATF7000E Front Load...
Door on Frigidaire front load washer loose
have you tried this:
https://www.hunker.com/12000515/how-to-fix-a-sag-in-a-frigidaire-affinity-washer-door
The screws maybe stripping(wearing out) or the hinge bent, should be able to visual look at both. I hope this helps. Tim
Apr 24, 2017 | Washing Machines
May 13, 2010 | Frigidaire ATF6000ES Front Load Washer
Makes a loud buzzing noise when attempting to start cycle
The lock solenoid on the door latch assembly may be hanging up or just noisey. If washer starts and runs then all is ok. If washer wont start, just buzzes, then door latch assembly may have to be changed.
Feb 01, 2010 | Frigidaire Affinity ATF7000E Front Load...
My affinity washer will not close to start a cycle. the buzzer goes off and i get the code "dr" but it seems to close fine
Have a service technician test the sensor in the door jam that senses when the door is closed (this is signaled by the electronic lock).
Dec 14, 2009 | Frigidaire Affinity ATF7000E Front Load...
I have a Figidaire Affinity front load washer. The problem that I am having is I close the door select wash and then push start and dr is on the screen. Can you tell me what is happening?
dr means the door switch is not closed. Thus meaning the door lock assembly is bad and needs to be replaced.part number is 131763245 and price is $48.99
Nov 01, 2009 | Frigidaire ATF6000ES Front Load Washer
My washer door isnt staying locked
Your probably need to replace the door striker (two pronged plastic prongs) thats attached to the door with two screws, or, the door switch. The door switch can be accessed by taking off the top lid and removing the two screws in front of the machine. The switch is a whole lot more expensive than the striker. Be sure to pay attention on how the switch is wired!
Jun 04, 2009 | Frigidaire Affinity ATF7000E Front Load...
My Frigidaire affinity washer doesn't start: the "door locked" button doesn't come on though the door is closed properly
Dec 01, 2008 | Frigidaire Affinity ATF7000ES Front Load...
MY AFFINITY WASHER WONT WORK
It is the door lock that may be broken, that's what happened with my maching last summer. The lock is made of plastic if you can imagine. So if you slam the door it can break. A washing machine gets wear and tear how can closing a door be owners fault?
This is a crappy machine in terms of maintenance, it is a maintenance nightmaire!!
Oct 30, 2008 | Frigidaire Affinity ATF7000E Front Load...
Washing Machines Logo
74 people viewed this question
Top Washing Machines Experts
