Question about Maytag MVWX700XL Top Load Washer MVWX700XL
Maytag Bravos washer model #mvwx700xl0. Was making some noise while washing clothes, then last load washed seemed really wet afetr done. Tried to run the Drain/spin cycle but washer only drained, won't spin. Lid lock light flashed instead of steady on and I had to actually unplug the machine to get the lid unlocked, just turning off the machine or cancelling the load did't unlock the lid as it should. Now machine doesn't really do anything.
  • 219 Answers
SOURCE: maytag sav365zaww agitates straight through wash
would say it would be the timer if it was the lid switch it wouldnt vspin or agiatate
Posted on Mar 18, 2009
dh1200s
  • 335 Answers
SOURCE: washes but won't spin or drain completely unless no clothes in
Hello screenman780
I will assume you are taking dc or UC errors to the display in spin cycle. Just need the first two digits of your machine serial number, ie. 10,12,16 etc. That information is located on the right back side of the machine console. If you are taking those errors I recommend removing the clutch inspecting the clutch roller bearings and clutch spring. There is a test to perform for the Tub Displacement Sensor that we could check first but 10 times out of 10… so far it’s the clutch. Most of the time a cleanup with WD-40 and re-lube of the clutch bearings with some light bearing grease will get you back in service. If the clutch bearings are rusted up beyond clean up or the clutch spring is broken then a clutch replacement will be required. I recommend this clutch as a replacement. I put that clutch in my machine (1st two digits of my s/n are 16) just to make sure it would work, my original clutch was cleaned up with WD-40 alone and worked as the day delivered on 7/05. Take a look and read thru the post in the link below. In that post I go thru a step by step process to replace the clutch (comment of 3/18). I can also offer some phone support no charge; I'm a DIY'er owner of the machine. I believe the repair cost (from previous post on this forum) to replace the clutch and labor will be around $300 if you don't DIY the repair/maintenance for this issue. Most of the clutch malfunctions are resolved with the clutch maintenance. Anyone can do this with only basic mechanical skill sets. If you can change the spark plug on a lawnmower you can deal with this, the work area is just tight. Here are some folks that had positive results with this maintenance. Unfortunately I feel many of these machines end up at the curb for bulk trash pickup when a $10 fix for some WD-40 a squirt of bearing grease or worse case a $50-$60 new clutch replacement. Good Luck and let me know if you need additional support, Rich.
http://www.fixya.com/support/t527875-maytag_neptune_tl
Here are some folks that did this maintenance with positive results.
Positive Fix1/19
Positive Fix 1/18
Positive Fix 3/4
Positive Fix 3/4 different Forum
Solution #4 posted on Mar 17, 2009
Posted on Mar 27, 2009
SOURCE: Maytag washing machine skips rinse cycle
Don't know how to solve it, but I do know that the Solution #1 is WRONG.
I have a 5 year warranty on my washer, but I hate people coming into my house. Background check or not, people are people.
Any ways, when they do fix my problem I will let you know. It's an electrical problem.
I know our electric meters are running, but all you have to do is put the washer on "SPIN" cycle, and it will spin and the water will come out. Or you can put your washer in RINSE cycle, since it did not actually rinse.
I was standing and I watched my washer fill 3/4 full with water, and the skip to "COMPLETE" all on it's own. It was suppose to fill all the way to FULL.
Thinking though, I have well water, and I have rust in my water, and I noticed that my water is pouring slower into the washer, maybe there is a clog with rust or something I'll have to clean the filter, but any ways, maybe the washers have a timer, and when it's to the time it should be complete, it skips to complete. It does take DOUBLE time for my water to go into the washer. I was standing there for several minutes.
Any ways, I hope that will help. My washer first did that a few months ago, it didn't do it again, I didn't think anything of it, then it did it again last month, and about every 2 or 3 washes, it does it. It's NOT the weight of my clothes! I wash mini loads and it does it.
Posted on Dec 13, 2009
FAV6800AWDIY
  • 526 Answers
SOURCE: my maytag neptune washer model#FAV9800AWQ keeps
I’m an owner of the FAV6800A LED console display version. You have the LCD console.
This issue could be related to a failed Control Board a failed Motor Controller. It could be related to loss of signaling to and from the lid locks.
What is your skill set level can you use a DVM to measure D.C. voltages in the machine?
If not I would recommend a knowledgeable repair service to help resolve the issue and that may be a challenge. But read on and maybe we can get you to look at the Left Hand Lid Lock,
You can raise the washer lid from the base to remove your clothes from the wash basket with this process and the Service Manual . Don’t break the Left Hand Lid Lock latche if you do you will need to replace the Left Hand Lid Lock. The machine only needs that Lid Lock to operate as designed.
Raise the top of the machine. Insert a flat blade putty knife approximately 2.5” from the left and right sides of the washer top, depress the spring tabs securing machine top to the washer base. See page 33 of the SM for putty knife insertion point.
Diag code 4 for both machines = The lid fails to lock. Look on page 25 for the error code description in then points you to this “”Go to "Will not unlock" Troubleshooting Section””. Confusing right?
I think you could have corrosion issues with the Left Hand lid lock. If you want to DIY this part of the machine see this post for Left Hand Lid Lock Troubleshooting.
Take a look and see what direction you want to go…..Rich
Posted on Dec 31, 2009
trinhblue29t
SOURCE: the Maytag TL lid lock
Hi, I have a code-OD at washer Maytag FAV6800 . What this mean and how can solve? Thank You!
Posted on Mar 07, 2012
Washing machine makes loud noise when spinning
call out a repairman possibly the tub bearings have begun failing .
Mar 14, 2016 | Maytag Bravos MTW6600T Top Load Washer
How to run diagnostic
Maytag Bravos MTW6600T Top Load Washer Run ... - Fixya
www.fixya.com > ... > Maytag Bravos MTW6600T Top Load Washer
Maytag Bravos MTW6600T Top Load Washer, run diagnostic test cycle related issues. Get free help, solutions & advice from top Maytag experts.
Maytag Bravos MTW6600T Top Load Washer, run diagnostic test ccu related issues. Get free help, solutions & advice from top Maytag experts.
Maytag Bravos MTW6600T Top Load Washer Diagnostic ...
Dec 02, 2015 | Maytag Bravos MTW6600T Top Load Washer
Maytag bravos top loading washer; LD error and all lights blinking. It seems to be draining now after I turned off and tried rinse only
Why is my Maytag Bravo washer Model #MTW6600TBO ...
www.shopyourway.com > Manage My Life > Questions
May 12, 2010 - LD error please check for the following: Check for kinked or clogged Drain Hose: ... Bravos® Top Load Washer w/ PowerWash® System.
Aug 08, 2015 | Maytag Washing Machines
Water remains in the main tub of my GE washer and causes an odor
I myself would not run a minidisc in a GE washer. Only a Maytag.
Sep 08, 2012 | Audio Players & Recorders
Maytag bravos washer that sounds like airplane
u need to replace the tub. includes the bearings
Feb 11, 2010 | Maytag Bravos MTW6600T Top Load Washer
My Maytoag Bravos Top load washer drains really
Is the drain hose kinked or clogged? Is the drain hose installed properly? look in the installation Instructions, Press POWER/CANCEL to clear display........ hope this helps.....
Jul 09, 2009 | Maytag Bravos MTW6600T Top Load Washer
Makes scratching noise
A common problem with noises from washing machines has been the under wire that may come out of small clothes. In the washer they can get stuck in one of the inner basket holes and make a scrapping noise, they can actually make there way into the pump and jam the pump, or make a terrible noise when the pump is running. Grab a flash light and have a peek inside the washer for this. Front load washers seem very common to this happen! If the tiny cloth  is showing signs of fraying, may be best not to wash it in the washing machine, replace the cloth
Nov 19, 2008 | Maytag PAV2300 Top Load Washer
Maytag MVWX700XL Top Load Washer MVWX700XL Logo
52 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
