Question about Toshiba 62HMX95 62" HDTV
Best color calibration settings - Toshiba 62HMX95 62" HDTV
    Champion:
  • 213 Answers
Check the color wheel
Posted on Nov 21, 2013
What are the setting calibrations for the best picture
There should be a few preset choices for you under the display menu....ex. Cinema, sports, etc...
Nov 10, 2015 | Vizio VX32LHDTV10A 32 in. LCD HDTV
Best settings to calibrate my vizio550M tv
Every TV is different (even within a brand) so specific settings won't help you. A good place to start is with the Disney WOW: World of Wonder Blu-Ray. It has many helpful test patterns, plus a blue filter so that you can see if color and tint are at correct levels. Before starting calibration I would advise turning the backlight down as much as possible, turning the sharpness off, as well as all of the features in the "Advanced Video" menu. You can bring these features back on if you wish after your first pass at calibrating. I would also select "Computer" in the "Color Temperature" submenu, as this will give you a neutral white balance, as opposed to "normal/warm" (red) or "cool" (blue). Hope this helps.
Oct 22, 2014 | Vizio VF550M 55 in. LCD HDTV
How do I calibrate my Panasonic TC-P55ST50 for the best picture quality?
Tweak the factory default settings until you are satisfied with the results.
Oct 15, 2014 | Panasonic VIERA TC-P55ST50 55 in. 3D...
What is the best way to calibrate my rca led29b30rq picture settings?
Set the picture setting to its factory reset. With factory reset, the color intensity might be somewhat more than normal. Just reduce the color intensity, according to your viewing taste. Gopakumar Gopalan Google
Jun 30, 2014 | RCA LED29B30RQ 29" LED TV 1366x768, 60 Hz,...
To stop auto calibration in toshiba color mfd
Better not to turn off the calibration, otherwise it will cause other errors.
If your colour printing is less than 5% ration, perform following. Turn the code 08-2692 "Prevention of color toner low density / ON/OFF setting" to ON, and then set number of sheets to be judged at the code 08-2693 "Prevention of color toner low density / Judged
number of sheets setting".
08-2693 u can put higher value such as 20 or above to delay the colour calibration.
Mar 25, 2014 | Toshiba E-studio 2330c 2830c Color...
I have a 60 Inc LCD led 120 hertz . sharp aquos . And I want to know what is the best settings for the picture? I tried adjusting it but it looks like a normal tv want to know the beat settings for picture...
The best way to set up a TV such as yours without a calibration device is to get a high definition picture of someone's face on the screen and adjust the color, brightness and contrast until the face looks as life like as possible.
Feb 16, 2012 | Sharp Televison & Video
1080p lcd hdtv 50+ inch. picture getting darker
If no settings have been changed it means your backlight is dimming. This is a common issue with LCD TV's however it usually doesn't happen this soon. The best thing to slow down the dimming process is to lower your contrast settings, however what you really should do is calibrate your television either professionally or by using a calibration DVD or Blu-Ray with color filters.
http://tinyurl.com/Calibration-Discs-at-Amazon
May 06, 2011 | Samsung LN46B650 46/49.5 in. LCD HDTV
Best picture settings for toshiba regza 42RV500e
Go to menu on your remote control and select picture setting and try selecting "default" setting to seeif you like the color, if not adjust contrast to about two thirds of the way and brightness to your liking and color to about the middle.
Jan 17, 2010 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Need lg 32lh30 calibration specs
I think I have a solution involving far less effort. Have you tuned your picture settings? Out of the box, the settings are ok and the presets will do the trick for most. But if you're like myself, you want the best picture possible. Here are my settings:
Picture menu:
Aspect ratio: Just Size
Energy Saving: Off
Picture Mode: Expert 2
Backlight: 35
Contrast: 90
Brightness: 54
H Sharpness: 40
V Sharpness: 42
Color: 50
Tint: 0
--Expert control menu
Dynamic contrast: Off
Noise reduction: Off
Gamma: Medium
Black level: Low
Real Cinema: On [grayed out]
Color Standard: HD [grayed out]
Color Gamut: Standard
Edge Enhancer: Off
xvYCC: Auto [grayed out]
OPC: Off
Expert Pattern: Off[grayed out]
Color Filter: Off
White balance: Warm
Method: 10 point IRE
Pattern: Outer
IRE: [see below]
Luminance: 137
-- 10 point IRE calibration
IRE: [Red, Green, Blue results, respectively, for each IRE point]
100 [-8, 1, -40]
90 [-13, -5, -40]
80 [-20, -12, -40]
70 [-17, -14, -33]
60 [-17, -12, -31]
50 [-17, -13, -26]
40 [-13, -12, -19]
30 [-6, -4, -8]
20 [-6, -4, -10]
10 [2, 3, -1]
Color management system
Red color: 2
Red tint: 0
Green color: -1
Green tint: -7
Blue color: 2
Blue tint: 7
Yellow color: 0
Yellow tint: 1
Cyan color: 0
Cyan tint: 0
Magenta color: 0
Magenta tint: -2
These are taken from CNET.com
Nov 08, 2009 | LG 32LH30 32 in. LCD HDTV
Color problem with sanyo 37" tv
Look for a "reset" in the display settings. This should reset you back to factory or "out of the box" settings.
If this doesn't help, contact your local service provider and have them check out the set. May cost a small fee for a service call, but if the tech is knowledgable, he or she may give you enough insight or knowlege on how to set up your TV for your viewing environment. Those controls have a purpose that most people are uneducated about.
Check out http://www.imagingscience.com/ and if you can find a calibrator in your area, see if they will explain to you the benefits of a calibration. You might also be able to get some info from the site. Also, look at the bottom of the above web page. You will see that ISF is selling a disk that will guide you through a user menu calibraton.
I am an ISF certified calibrator, and I offer to my customers, a free user menu calibration, and yes, I use the afore-mentioned disk. Once you see the difference and are educated about what a calibration does for your perception of your set and how and why it operates the way it does, you will better understand.
Also keep in mind that ultimately there may be something wrong with your set. I am also a repair technician and I have seen countless issues when it comes to repair. Having said that, minor or slight color issues should be resolvable.
Best of luck.
Tim
Certified TV
Jan 12, 2009 | Sanyo DP32746 32 in. LCD Television
Toshiba 62HMX95 62" HDTV Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
