Question about HP Computers & Internet
Xplio XP19A Monitor Green light on monitor flashing, no display, worked fine last night, unplugged VGA and Power. It is being detected by computer.
    Top Expert:
  • HP Master
  • 21,354 Answers
Lamp issue.
Posted on Nov 17, 2013
Nothing displays on the monitor when I turn on the computer
is there power to the monitor? is the monitor in standby(yellow light on monitor)? is the monitor on (green light on monitor)? how is the monitor connected to the computer, VGA (square fat cable, the end may be blue) or HDMI cable? When you turn on the computer is the power light on and HDD light flashing / showing activity? this would indicate that the computer is booting up. If you have power light and activity on the computer, I would unplug the data cable to the monitor. If the monitor is plugged in, i would press the power button to try and turn on the monitor / take it out of standby. If the monitor is ok you should see a message like "no signal" or "no input". This would tell you that the monitor is fine, but you may have a problem with the video card or video port on the motherboard. If you have no activity light on the on the computer, you may have a problem with the OS not booting up. You really didn't provide much detail on what has been done, but this is how I troubleshoot out in the field when working on something like this.
Oct 09, 2013 | Computers & Internet
No display, light goes green but on screen says no connection then goes yellow for standby tried both DVI and VGA so now linked my pc to my tele via DVI to HDMI and works fine anyone know what this could...
here is the simple test to detect hardware malfunction.
on every monitor these days whether its CRT or LCD already programmed inside self test.
detach your cable data to CPU and power on your monitor. if its displayed self test on your screen mean its OK and something wrong with your CPU, could be VGA error.
if its just black display mean some is wrong with your monitor.
if you post more detail maybe we in FIXYA could help.
thanks.
Mar 11, 2011 | Hannspree HW191D LCD Monitor
I have a samsung syncmaster 204T monitor. Everything was fine until last night when i kept my system on standby for approx 5-6 hrs. Now whenever i start my system there is only a green led on front panel...
I just started having the same problem! The green light flashes, but the monitor is blank. None of the button work (menu, source, etc...) and nothing changes when I disconnect it from the computer. I was suspecting a bad graphics card at first, but now I'm thinking the monitor itself is bad?!
Jun 29, 2010 | Samsung SyncMaster 204T Monitor
Monitor problem
The power light is flashing green can indicate start/restart of the power supply due to shorts circuits or failing power supply due to bad caps, look for bad caps with bulging top first, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Post back what you see insdie so we can guide you furhter.
Feb 20, 2010 | Acer 17" AL1706B LCD Monitor
Monitor is black but power light is blinking green. Worked fine last night, but this morning screen was black and light was bliking. Suggestions? Thanks!
Firstly check the power cables nd VGA port is it proper or not nd then if this is proper then ur problem might be in RAM remove the ram and rub it with eraser nd insert it again nd check CMOS battery also ....u will surely get a positive result....
Aug 31, 2009 | Dell E173FP 17" LCD Flat Panel Monitor
Colored vertical lines on monitor
Have you unplugged the power cord to the LCD? Let it sit for a minute, then try it. ALWAYS buy a UPS and plug any computer devices into it. Doesn't have to be big, a $50 unit will protect it from dangerous voltage surges.
Jul 24, 2009 | Dell E171FPb 17" Flat Panel LCD Monitor
Envision EN7410e monitor
Just fixed mine. Maybe it's a few years late. Hope you guys still have the display. It's the power supply board. I've just replaced 4 bulge capacitors near one edge of the PS. They are 2x1000uF 10V, 1x470uF 25V & 1x470 10V. I salvaged my parts from an old CRT monitor. Hey you can go green with your repairs too!
Apr 25, 2008 | Envision EN7410 17" LCD Monitor
Flashing green power light - Black screen
I had the same problem with an AOPEN 17' lcd that was left behind at a rental property... I plugged it into my dell dimmension 4400 in place of my old analog. It worked fine the fist night, and got up and when turned it on again it had the famed green blinking power light. I switched back to the analog, and just disappointed I plugged in the AOPEN to another power source, and power came on a steady red light. I plugged it back into the puta and it came on again. I have not turned the monitor off again for fear of the blinks, and has been working great for close to a week now. Hope it helps someone else out there. Richard
Mar 27, 2008 | AOpen F75PS 17" Flat Panel LCD Monitor
Blinking green light with no display
Have you tried connecting this monitor to another computer?
Have you tried resetting the BIOS? That should reset any problem the video driver for the monitor maybe facing.
Oct 17, 2007 | Gateway FPD1530 15" Flat Panel LCD Monitor
Power light flashes with no display
That usually means that the connection between the PC and the monitor has been interupted- check that the cable (probably has blue ends) between the two is firmly connected, and power it back up. If that doesn't work, you have one of three problems; a broken VGA cable, a broken monitor, or a broken video card. Finding out which- you'll actually need someone tech-savvy there to help you figure that out. Try plugging the monitor into a different computer. If that fails, use a different VGA cable (cables are pretty cheap at monoprice.com), and if that fails, it's your video card.
May 23, 2007 | Mag Innovision InnoVision 786 PF 17" CRT...
Computers & Internet Logo
154 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
