Question about Oritron NPD3117 DVD Player
Won't play any dvd
Factory made movies or cleaning disc doesn't matter, won't play either. Reads disc then says "No Valid Disc"
Sony GDP s301 won't play any discs
see the cause and remedies:
Does not play disc
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
Finally the OPU, optical pickup unit contain too the lasser beam, NOT are reading the TOC of disk,+Syscon can be defective. You must go to the repair shop TV for fix it. this a complex equipment.
see tje block diagram.
God bless you
Jul 15, 2012 | Sony BDP-S300 Blu-Ray Disc Player
My dvd gaves me a bad disc
when you play nothing but bootlegs in a dvd player, they tend to burn out the eye inside the player to where it will only read bootlegs. the original movies capabilities won't work anymore. hope this is a help to you my friend.
Jun 21, 2012 | Cyberhome CH-DVD 300 DVD Player
Sony DCR-DVD403 C 13:02 Error Message so won't record movies.
Place an empty disc in, format the disc, record a little scene. Turn off camcorder. Place the error disc in the camcorder, turn on the camcorder all the way to play/edit. If this doesn't work turn it to record and try to record. Worked for some of my error disc
May 10, 2012 | Sony Handycam DCR-DVD403 DVD Camcorder
My Toshiba Blu-Ray player, BDX 2700, will start to load a movie but it stays at 00:00:00 and it won't continue or play. What's wrong?
either a mechanism problem---disc not turning etc or an electronic issue --someone would have to open the unit and insert a disc to see what is happening----also unlikely but possible the optical pickup that reads the discs is dirty or near failure---this will usually show up first on blu ray before a regular DVD.
Apr 23, 2012 | Toshiba Televison & Video
I downloaded a movie on my computer. I burnt the disc and when I put it in the dvd player it says cannot play disc. I have a sony DVD Player. Any thoughts?
The exact model of DVD player matters. Not all models can play a Computer burned disc.
There are several types of DVD
A factory type DVD in DVD format
A burned movie in MPEG format
a burned disc in DivX format.
Etc.
Try burning the disc with a DVD Creator program, not just 'Burn to DVD'. It's not the same thing.
Mar 19, 2010 | JVC XV-N320 DVD Player
MPIO dvd player reads "no valid disc"
Try cleaning the lens with a dab of rubbing alchohol and a q-tip. If error continues, throw unit in garbage.
Mar 02, 2009 | Televison & Video
No Valid Disc
Try cleaning the laser lens if this don't repair it ,is the flat cable connector between the laser lens and the main board.Good luck
Jul 25, 2008 | Durabrand Portable DVD
LAPTOP DVD DRIVE WONT PLAY DVDS ANYMORE
Drive is on its way. Typical behaviour. Try air dusting lens but unlikely to fix it. Very easy diy repair and cheap. EBay the new disc drive or refurbished. Then go to youtube. Nearly all laptop drives are the same to replace no matTerry brand. You could even get a faster drive.
Mar 05, 2017 | Televison & Video
I put the disc in the player ithen tries to play then it says disc not valid .
Same here!!! We've only used it maybe 8 or 9 times. And it's been worthless for the past month because of it. It reads everything "no valid disk" and nothing will work. And I tried e-mailing customer support several times, with no luck.
Nov 21, 2007 | Durabrand DUR7 Portable DVD Player
Oritron NPD3117 DVD Player Logo
22 people viewed this question
Top Oritron Televison & Video Experts
jairo sanchez
 Grubhead
Grubhead
Mikee
Are you an Oritron Televison and Video Expert? Answer questions, earn points and help others
