Question about Honeywell Programmable Thermostat Heater
Just installed a honeywell programmable thermostat model 08161 TH110-DP-P TL8230, Dsplay is blank, power switch is on, power to the unit. appears not to work. what do i do?
    Master:
  • 571 Answers
Make sure you have 24 volts between the red & common wire
Posted on Dec 12, 2013
  • Brandon H
    Brandon H Dec 27, 2013
    This is bugus. There should not be 24 volts? Im just a homeowner and know that it shoul dbe more like 240V. Yes i have the same problem.
Thermostat is not coming on we are in san antonio is there help out there for us
Reasons for a Blank Screen on a Honeywell Thermostat ...
homeguides.sfgate.com > ... > Real Estate Rental & Lease Basics
Honeywell and other brands of programmable thermostats typically show a blank ...and the batteries can no longer provide power to the screen, it will go blank. ...electrical system, a blank screen indicates there is no power going to the unit, ...
programmable thermostat troubleshoot - YouTube
? 3:35
https://www.youtube.com/watch?v=pNVTAUcBx-U
Sep 26, 2011 - Uploaded by Maxxmentum
Programmable thermostat started to fail and behave erratically after being in service for a few ... My thermostat works but the remotes have stopped working. .... Honeywell CM907 Digital Programmable Room Thermostat user ...
HEAT WON'T TURN ON How Test if your Thermostat is ...
? 2:36
https://www.youtube.com/watch?v=lSJn69EAcAw
Nov 16, 2014 - Uploaded by You can Fix It!!!!
Heater fails to turn on it does not mean you have a faulty heating system ... 4th - Check programming on a programmable
Jan 10, 2016 | Honeywell Programmable Thermostat Heater
Honeywell Chronotherm iv Plus power cuts on and off
There's a trouble shooting guide here, you need to check for the presence of 24V when it goes blank, and trace back to where it's disappearing (I assume it is losing the 24v, if not you'll need to go through the installer setup or read on...
My first thought would be to check the wiring which has been touched last if it started doing that after you had coil replaced.
As an aside I'm not sure which model you have but if it has batteries you should replace them (I don't think it does have batteries but not seen a model iv so I'm unsure)
https://customer.honeywell.com/resources/techlit/TechLitDocuments/69-0000s/69-1410.pdf
May 12, 2014 | Honeywell Programmable Thermostat Heater
My Honeywell programmable thermostat's display is blank and I do not have any heat?
The thermostat, depending on the model, normally does not get powered by batteries, they are for backup power. You might be losing 24 volt from the furnace, causing the thermostat to run on batteries.
Apr 09, 2014 | Honeywell Programmable Thermostat Heater
I have a Honeywell Thermostat 32207445-001 and the screen is blank. The cover indicates it may be a security feature. How do I reset the unit?
Did you try turning off the power to the unit. Also is there a lock on the thermostat. Check manual maybe you need to hold certain buttons to unlock.
Feb 08, 2011 | Honeywell Electronic Programmable...
The thermostat worked correctly for months then
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need
May 10, 2010 | Honeywell Programmable Thermostat Heater
Honeywell thermostat t8400c intermittent blank screen
It actually sounds like the batteries are going dead if the 24v from the furnace are not providing the power to the thermostat.
Sep 28, 2009 | Honeywell Electronic Programmable...
New programmable thermostats will not operate the furnace or air
did u turn the power off to unit before installing t-stats,if not then mabe blown low voltage fuse
Mar 28, 2009 | Honeywell Programmable Thermostat Heater
T8411r1028 honeywell thermostat
Check in the heating unit itself for an automotive style fuse.
Dec 17, 2008 | Honeywell Programmable Thermostat Heater
Installing a honeywell CM900 wireless programmable thermostat
the analog unit uses just two wires for heat. red - white. there is a heat anticipator setting that must match the burner current. check your programmable specs and follow instructions.
Dec 04, 2007 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
163 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
