Question about Water Heaters
Envirotemp water heater
The overheat switch shut off the burner now i cannot get it to reset. where is the reset switch located.
3 Suggested Answers
  • 129 Answers
SOURCE: how do i reset safty switch on ge gas water heater
If your water heater has the flame lock system, there has been a recall and the whole burner assembly will have to be replaced. I recommend you call a plumber.
Posted on Sep 30, 2009
  • 518 Answers
SOURCE: I have a Bosch AquaStar AQ-125-BNG tankless water
there is a small dia copper pipe which has a thermal coupling on it the end of it sits in the flame of the pilot light,
if it fails which it does after about 25-15 months,it shuts down the gas burner
Posted on Jul 05, 2010
Marey tankless hot water heater 16ng
turn down gas and turn down pressure switch
Aug 02, 2017 | Water Water Heaters
How to change a envirotemp gas water heater into a.electric water heater
Dear Buffie,
You cannot change a gas water heater into an electric water heater, nor can you change them the other way around.
They are manufactured differently.
If, however, you are getting rid of the gas one and want to know how to hook up a electric water heater in it's place, please ask the question that way.
God bless your efforts.
May 09, 2016 | Water Water Heaters
Envirotemp hot water heater went out I can't get it relit
If it is a gas water heater put new batteries in it. They are usually D size.
Apr 24, 2016 | Water Water Heaters
Why is my envirotemp residential hot water heater creating black soot?
Because the burner is not adjusted correctly, you are waisting fuel.
Nov 18, 2014 | Water Heaters
you have electricity to the elements but have you tried testing the elements with a ohm meter to see if you have continuity. shut off power disconnect wires (shut off power) then test the elements for continuity. no continuity they are bad. will need to replace. Special socket cheep from the big box stores.
Jan 01, 2018 | Water Heaters
Propane water heater high limit switch keeps kicking out
1) What brand and model water heater?
Copy following link for troubleshoot by type of gas control valve.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
2) Clean air intake screen using compressed air or feather duster.
With AO Smith, craftmaster, state, reliance, american, kenmore, whirlpool, the air intake is located on bottom of heater. Rheem, richmond, ruud, GE, Bradford white, the air intake screen is located under combustion parts.
Water heaters today require plenty of fresh air. If air intake gets clogged with dust, then combustion byproduct moves up pipe too slowly for amount of fuel being burned, and this overheats combustion chamber.
http://www.thetankatwaterheaterrescue.com/forums/forum3/
3) Add a comment with more information
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Dec 13, 2012 | Water Heaters
I have a Bosch AquaStar AQ-125-BNG tankless water heater. It has worked very well until recently. The problem: The hot water at the tap is turned off, the flame on the main burner keeps burning and...
Jul 05, 2010 | Bosch AquaStar Indoor Natural Gas Tankless...
Light flashing - lockout condition - ECO failure
The ECO is designed to shut off the water heater in case of the water heater overheating. This is to prevent the water heater from exploding. I assume that you have a newer style residental water heater or a commerical boiler. The ECO is a fuseable link that is built into the control and located at the thermostat probe. If the water heater overheats then this link will melt cutting the circuit on the millivolt system(residential) or 24volt system(commercial boiler). If you look under the water heater control(where the temp adjustment is) there are usuall two wires that go from the control to the water heater. These are the ECO wires. Verify the wires have not been cut or damaged. If these wires are cut or damaged then the ECO circuit will be incomplete and you will get the ECO lockout failure. Also make sure that the flame lock-out switch is not tripped. It will be located at the burner compartment cover and have two wires going to it. Most have a little button in the center. These are to sense high heat and one might have tripped closing the circuit. You can push this little button to re-set the switch. If you feel a little "click" then the switch was probably tripped. If it does not have any button then it might be "self resetting". To test that switch use a continuity tester and the circuit should be closed. If these switches are working then the fusable link for the ECO is probably bad from the water heater temp getting too high or was defective and failed. This will require you to remove the water heater control valve and replace the fusable link. If you do not have experience with this I suggest you call a licensed plumber to make the repairs. If this repair is improperly done it could void the warranty on the water heater and/or cause property/personal damage or injury. There is a possiblilty that your water heater thermostat had failed causing the ECO to trip. If that is the case then the ECO safety did it's job.
Jun 26, 2010 | General Electric Water Heaters
AquaStar 125B NG continues heating water when no demand
I found the manufactures website and read this specific tech bulletin. I will be replacing or repairing my water value soon.
http://www.boschhotwater.com/Portals/7/TechBulletins/TWH-G1-25_Water_valve_rebuild_B.pdf
The bulletin said the following:
If the burners fail to go off immediately when the
water is turned off, usually due to mineralization in
the water valve on older heaters. To test for this
possiblilty, run hot water at a faucet, then shut off
the cold inlet supply and observe if the burners go
off immediately. If they do not the Aquastar will
overheat and shut down on safety depending on
the delay.
Jan 11, 2009 | Bosch & Tankless LP Hot Water Heater
Water Heaters Logo
107 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
