Question about Garden
My poulan woodshark model # p3314wsa bogs when I start to cut how do I fix it runs fine when not cutting
Remove the muffler, and check the spark arrestor to see if its clogged with Carbon. Clean it by either wire brushing the carbon, or heat the spark arrestor with a propane bottle torch, and the carbon will burn off.
Posted on Nov 19, 2013
2 Suggested Answers
dontbother10
  • 2220 Answers
SOURCE: disassembly of poulan woodshark model p3314wsa to
This is an IPL for a Poulan P3314 (may not be your saw), It seems there are 2 different size hoses, I suggest you disturb only what is necessary, take a digital photo, then a small sample of both sizes to a local saw outlet. 12" of both sizes should be ample, ask for his guidance before you order.
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best; components are listed but may be on different illustrations.
http://weborder.husqvarna.com/order_static/doc/NIUS/NIUS2008/NIUS2008-P3314-530165402-952802026.pdf
Many also find this helpful:
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
If not your saw try here (there are 3 "P3314WSA"s available):
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
The IPL can be used as a disassembly guide too, although you should not need disassembly beyond removing a cover or 2. Good luck with your project If I can be of more help you can reply below. HTH
Lou
Posted on Jan 28, 2010
What damage can i cause by hooking the fuel line up backwerds
None, it shouldn't run if your connect the two pipes wrong. I am thinking it is a simple carburetor, one flow pipe in and the other is a float bowl overflow.
Your manual isn't much help.
http://www.poulan.com/ddoc/POUO/POUO2010_USen/POUO2010_USen_545186804R2.pdf
and there is a zoomable exploded diagram here, but resolution isn't high enough.
Here is your carb connected to the filter in high res. And that carb doesn't have a bowl or overflow.
http://www.amazon.com/Carburetor-P3314WS-P3314WSA-P3516PR-C1M-W26/dp/B00SGLD8M2
Chainsaw Shed Poulan P3314WS WoodShark P3314WS Type 1 Parts List for...
Jan 31, 2016 | Poulan Garden
Wood shark p3314wsa wont idle
Carb rebuild time, you're on the right track.
Jun 30, 2014 | Poulan Garden
Need a gasket for a Poulan Woodshark model 1950
They taught us gasket making in grade 9 automotive class using sheet gasket material and a ball peen hammer. Sometimes putting some grease or other on the metal to make an imprint on the gasket material (or cardboard template) and cutting with scissors. It may be the only way for something that old.
Oct 22, 2013 | Garden
I have a poulan woodshark i traded for a old tv it has great compression and great spark but it wont start i think they might have messed with the carb what should i do thanks
Turn the carb adjustment screws all the way in and then turn them 1 full turn out and try that. If it starts it will probably require some fine tuning or some tweaking to get it to start. I also suggest you clean and kit the carb just to you know it has a good diaphragm and no clogs
Jan 17, 2013 | Poulan Garden
Chain saw starts fine, idles fine, and powers up fine when not cutting a long how when starting to cut a log it bogs down and dies. Does anyone know how to fix this problem or what’s wrong with the chain...
Two things that can cause this problem. 1. Your carburetor is not set properly and is not letting the engine get enough fuel under a load. 2. Your chain is binding when you put the chain bar down on the log. Make sure your front chain sproket is turning free and is not too sloppy.
Sep 12, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Disassembly of poulan woodshark model p3314wsa to
Poulan.com
Lou
Jan 28, 2010 | Poulan Garden
Woodshark poulan 14" slack chain
make sure the little tooth on the end of the adjuster for the chain is locked into the groove its supposed to go into and tighten it down.
Note: the chain is supposed to get loose on you but not as quickly as it is. maybe after an hour or so of cutting.
and as for it not cutting well, the chain may need sharpened.
if it has been sharpened once by someone than take it to someone esle if it is not satisfactory.
Jan 11, 2010 | Poulan 14 in. 2.0 Peak Horsepower Electric...
Bog when trying to mow
you are cutting to much grass & it isn't kicking it out fast enough out of deck which will bog it down it might help if you clean out the bottom of the deck & also dont cut really low if grass is really tall also cutting wet grass will aslo cause the bogging if i can further help e-mail me wade at wadembly@aol.com
Jun 26, 2009 | Garden
Idels good but when i start to cut it bogs doun
Either the spark arresting screen is clogged with carbon, or the carb is out of adjustment on the high speed jet.
Mar 31, 2009 | Poulan Weedeater/Electric Trimmer 4.1 Amp
Garden Logo
65 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
