Question about Qca Spas Dream Series Dream Master Hot Tub with Flex Cover
Just replaced the pump and now its reading fl and not heating up
  • 3,103 Answers
Are the connections tight? are they the same as the original one? some have to go through the same relay as the heater in order to operate with it..
Posted on Jan 10, 2014
Fl 7 code pump will not come on
make sure you dont have the heat maintain on
May 25, 2014 | Jandy Lite 2 Natural Gas Pilot Light...
Pump Problem with Calypso. I was getting the FL code on my washer so having read all the suggestions on the internet I removed the pump assembly and checked for obstructions, nada. Impeller is...
FL Flood Condition FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
Jun 04, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
What does the "FL" code
Fl stands for FLOW error code. This means that either the pump is not pushing enough water, or the pressure switch that senses water flow through the heater is not functioning. This are inexpensive and easy to fix yourself if it is just the pressure switch. Look on or near your heating element for a small disk switch with two wires coming out of it. Remove and replace this part.
Feb 15, 2011 | Qca Spas Dream Series Dream Master Hot Tub...
WHAT DOES FL MEAN AND HOW DO I FIX MY WASHER WHEN
The FL error code means:
Flood Condition:
This problem I see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
There is a check "valve" in the drain assembly that seems to sometimes cause problems with the FL error code. You can remove this piece, and might avoid changing the pump.
Calypso Service manual: https://docs.google.com/leaf?id=0B5If-wTgYWH5MTQ0OGIxZTAtZjQyMy00MzEzLWJkMzYtZTdmOTY2OTk3YTA4&hl=en
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 26, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Fl error on washer
Hello there :
I am hoping that i am reading this right it looks like you said a fl error right and if so please read this whole solution that i have provided below
If this condition continues have the machines water level switch replaced or repaired
Hope this is very helpful for you
Best regards Michael
Feb 11, 2010 | Maytag MAH6700AWW Neptune Front-Load...
Machine stoped after wash cycle tub did not drain and reads F L kenmore elite calypso model #22064 100 type 170 cannot get it to start at all it keeps beeping and reads FL
Flood Condition:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%#@$
Feb 09, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
My Calypso keeps reading "FL"?
Flood Condition:
Nov 04, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
My kenmore elite calypso washing lights on the front panel will not light up.i push the choice i want then it reads FL and all it does is hum and beep.even when off it will beep and read FL.i will turn it...
Flood Condition:
Oct 15, 2009 | Kenmore Washing Machines
Fl reading . cycle starts and stops within the first minute
Flood Condition:
Jul 11, 2009 | Kenmore Washing Machines
My kenmore elite reads fl and stops working,
Flood Condition:
Jun 16, 2009 | Kenmore Elite 45986 Front Load Washer
Qca Spas Dream Series Dream Master Hot Tub with Flex Cover Logo
42 people viewed this question
Top Qca Spas Pool & Spa Experts
john h
Ian Summerfield
Ian Summerfield
Are you a Qca Spas Pool and Spa Expert? Answer questions, earn points and help others
