Question about Asko D1716 Built-in Dishwasher
Water not pumping
The d washer will not pump. last night i turned it on and it heated but know water. tried again and it worked. The wife tried and nothing. It makes noise like its trying but know water. Help I am now unemployed.
  • 1,338 Answers
The pump is plugged possibly, remove the hose from the drain at the sink and using a garden hose, back flush it and it might spark it back to life. help me help others, if this is what fixed you up, please tell me or tell me what you found was the problem. thanx Jay the pool pump motor repair guy longwood florida
Posted on Nov 18, 2013
2 Suggested Answers
  • 3247 Answers
SOURCE: Drain pump on 3250 runs
This could mean there is either a leak somewhere inside the unit or the float switch is triggering incorrectly if the dishwasher is empty of any water.
Do you have any of the lights on the panel flashing?
Posted on Dec 04, 2010
WHY DOES THE MOTOR ON MY SAMSUNG DISHWASHER RUN ALL THE TIME AND THE LIGHT ABOVE HEAVY BLINK?
Yes, you've got a leakage error, which means water has leaked down into the base of the dishwasher. The drain pump runs all the time, trying to get all the water out, but the drain pump can't get to the water down in the base. (Those North Korean engineers/designers aren't too bright.) You'll have to pull the dishwasher out, pull off the side panels, and dry up all the water before that drain pump will stop running. But you still have the problem of figuring out where the leak came from and fixing the problem before you can use the dishwasher. The most common source of leakage in a Samsung DW is the drain pump and/or drain hose.
Feb 24, 2015 | Samsung Dishwashers
Good morning. I have a GE Adora washer. Last night my wife let me know that it has not drained properly in the last two days. I removed and cleaned the lint trap. I then started the washer back up in the...
I see you have already attacked the filter! Were you able to test the motor in motion as well as checking if it was free? If not here are the last 2 paragraphs of my 'check drain filter and drain pump motor' guidance notes ;-0)
(REMOVE POWER)
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
John C
Mar 25, 2011 | GE WCVH6260FWW
1999 cadillac will not start, plugs are dry
yes a fuel pump can give out at any time to check put your head by the gas tank and have someone turn the key if you hear a buzzing from the tank then you know it works. if you here nothing its bad and will have to drop the gas tank to replace it.
May 04, 2010 | 1999 Cadillac DeVille
Clean pump
sometimes a sock or something small gets sucked into the pump that pumps out the water on some brands of washers (depending which washer you have) take the back off the back of the washer (after unpluging and turning off the water feeds) locate where the pump is and look to see if theres something inside the tube with a pair of pliers you can take the clamp off and exstract the blockage and replace the hose + clamp and after cleaning up the water try to run the washer again if things work finsh pulling the washer back together
Dec 09, 2009 | Washing Machines
Maytag washer leaks water from bottom
I would remove the hoses from the pump and use a flashlight to look into the suction port. Check for anything clogging the pump (like the occasional stray sock) and check the pump impeller. Make sure there are no blades missing or broken and that the impeller will spin freely. If any blades are broken/missing or if you cannot get the impeller to spin freely, the pump is defective. Hopefully it is just a clogged pump or jammed impeller. If you can find no fault with the pump, then it could be the tub seal, but I would check the pump first. Very sorry for your trouble and I hope this helped. Best wishes.
Sep 01, 2009 | Washing Machines
Maytag Performa will not drain
If this is a direct drive washer (no belts) you have a bad water pump or a sock has gotten sucked in to stop it up. get under it look for two hoses going to a white looking valve. If you pull the hoses look out for all the water to flood out so be preped. Pull the pump out and ck for sock or fuzz in it then try to turn to trun by hand if its hard its bad. repost if need more help.
Jul 02, 2009 | Maytag Washing Machines
Water won't pump
yes,,, it is the water fill valve,, when it started to go bad the noises where from the pump, then it got quite now it is gone,, make sure you turn off the water supply before removing the unit,, only reason I am saying this is that I have even seen plumbers not turn off the water supply because they don't have hater goning thru and forget that why they are taking it out lol
Feb 11, 2009 | KitchenAid 24 in. KUDP02FR Built-in...
My 1991 dodge caravan started having problems last night..
yes check belts ..and the cause .. a frozen water pump or other accessory that is turned by the belts frozen ... then advise me
Dec 08, 2008 | 1991 Dodge Caravan
Heat Pump was repaired and then went out again
Repairman fixed a wire? sounds a little vague. If the outside coil is covered with ice, then it may be the board. Most defrost boards have a test terminal on them. Touch something to the test posts and see if the reversing valve switches on and the unit starts defrosting. If nothing happens, then its the board. There could be much more things causing it not to work, but I need more info.
Feb 28, 2008 | Amana PTH123B25AJ Heat Pump Air...
Asko D1716 Built-in Dishwasher Logo
54 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Owen Barnes
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
