Question about Samsung T24A350 FULL HD TV/MONITOR
Samsung T24a350 problem
Randomly switching off
TV just shuts off randomly. Any idea what the problem might be?
The door switch of some of these units caused that problem. see following web site: http://www.amazon.com/AA41-0756C-Switch-Sensor-SAMSUNG-HLP4663W/dp/B00NH49Y4E
May also be the lamp itself
Apr 09, 2015 | Samsung Televison & Video
Samsung turns off
It's faulty, buy an iPhone. You are not alone
How to fix Samsung Galaxy S4 that keeps turning off on its own ...
https://thedroidguy.com > Mailbag
Aug 24, 2015 - We received several emails from Samsung Galaxy S4 (#Samsung #GalaxyS4) owners whose phones are randomly rebooting. It may be ...
Fixing The Samsung Galaxy S4 Turns Off Does Not Turn Back On Issue
https://thedroidguy.com > Mailbag Jan 24, 2016 - The #Samsung Galaxy #S4 has established itself as one of the most dependable smartphones available in the market today. This device which ...
Samsung Galaxy S4 Randomly Shuts Down Issue & Other Related ...
https://thedroidguy.com > Mailbag Jan 10, 2016 - My Samsung s4 mini was switched off during an update and will not switch on now. ... Reinsert just the battery then check if the phone turns on.
samsung galaxy s4 turns off but still has 30% battery life ...
https://forums.androidcentral.com/samsung-galaxy-s4/303065-samsung-galaxy-s4-tur... Oct 12, 2016 - 25 posts - ‎22 authors
My s4 turns off at 30% battery life! ... note that, yesterday after the phone turned off by itself by showing battery critically low (in reality it had over ... Galaxy S4 shuts down randomly
8 Jan 2017
Galaxy S4: HELP with Hands Free
17 Dec 2016
Galaxy S4 Turns Off by itself sometimes
14 Apr 2016
S4 won't turn on unless replacing battery, then turns off ...
17 Jul 2014
More results from forums.androidcentral.com
Fix Randomly Shut Off Samsung Galaxy S4 Active Issue ' Technobezz
https://www.technobezz.com > Tech -How To's > Android Fix Randomly Shut Off Samsung Galaxy S4 Active Issue ... the battery. Now turn on the device to see if the sudden shut-off or reboot issue is resolved then. Samsung s4 mini turns itself off Google Search
Oct 28, 2017 | Samsung Galaxy S4 Mini Duos GT-I9192...
Samsung LE32R7 very low brightness, reddish, picture
Please check the ribbons between TCON and panel. There seems some loose connection problem.
Dec 20, 2013 | Samsung LE Televison & Video
I forget password for samsung sgh-m620 when i switch on
Keep spamming random passwords till it prompts you if you forgot the passcode, say yes and it will send one to your registered account e-mail
Jun 12, 2012 | Samsung UpStage SPH-m620 Cellular Phone
Samsung HL-T6187S SOUND DROPPING TO 0? By itself
If you can get at the controls again----undo or unsolder the micro switch for volume down! Remove it and see if set works.
A no brainer in that if that switch is bad and vol down still displays nothing else would work
Feb 21, 2012 | Samsung HL-T6187S Television
Randomly switching off and coming back on by itself.
power supply board may be failing or the power button may be sticking. If it is a Samsung, it is the power supply.
Nov 17, 2009 | Televison & Video
My Samsung HLP6163 tuns off randomly all evening
if you are able to simply turn it back on, then the problem is probably the lamp door cover switch. unplug the set, remove the lampdoor cover. the switch will be in the lower left of the opening. put the door back on while making sure that the switch lever goes down NOT UP. some of these sets came through with the switch up. it works for a while but then the little arm starts to warp and it causes your problem
Dec 14, 2008 | Samsung HLP6163W 61" Rear Projection...
Randomly printer stops printing - need switch off and on to restart printing
Sounds like you are just beginning to have problems with the paper feeding. Try cleaning the roller or applying rubber cement per my other post on the paper feed topic.
Apr 12, 2008 | Samsung ML 1210 Laser Printer
Tv switches itself off then back on again
Hi.
If the tv set is still under warantee get it sorted before gtee runs out.
The problem is caused by cummunication error between ATV Micom and DTV Micom.
To correct this problem requires going in to service mode to make changes & updating the DTV firmware.
This will need to be done by a proffesional.
http://dysonmanuals.llc.nu/
Chris.
Jan 02, 2008 | Samsung LE32R41BD 32 in. HD-Ready LCD...
TV switch off randomly
It is a Rely in the Power Supply. Need to have it changed out. Cheap part.
Dec 29, 2007 | Samsung HP-R4262 42 in. Plasma Television
Samsung T24A350 FULL HD TV/MONITOR Logo
42 people viewed this question
Jerry Greenberg
Jerry Greenberg
