Question about Casio Watches
Resestance knob broken on my Stamina #4755 silent magnetic is there a replacement for it ?
How to adjust hands with anolog time
pull the adjuster knob out and wind it around to move the hands
push back in when the time set is right
Dec 26, 2015 | Casio GA110GB-1A Black G-Shock Digital...
Found small spring when changing battery
This happened because the COIL SPRING was lost during the battery change. This happens quite often to DIYers, as they do not know how the watch is built and the coil spring itself is very small, so, it's easy to loose it without even noticing it. Coil spring transmits electrical signals/vibrations from watch's movement to the quartz membrane attached inside case back. Now you have to find yours or need to visit your nearest watch repair shop and ask for the new one to be fitted..
Oct 18, 2012 | Casio Watches
Where to buy a watch? thanks
internet, large box stores and sports stores like REI
Oct 11, 2012 | Nike Triax Stamina WR0050-302 Watch
The scond hand on my tag formula 1 has stopped and wont resest,but the watch still works with the time. What could the likely problem be? Could it be the battery? or could it need servicing?
Sean, This watch has a disposable movement(guts). That means the battery is the only part that can be replaced. The thing is glued together instead of screwed. Take it to a watchmaker that can get the replacement movement from Tag as the ordinary movements out there are different from the genuine Tag movements. Date wheels specifically are different. Anyway, a professional watchmaker, not a jeweler or store clerk please, will be able to tell you if that is the correct course of events to take. Probably looking at 200 to 250 Michael, Watchmaker to the Stars!
Mar 17, 2011 | Tag Heuer Formula 1 CAC1111.BA0850 Wrist...
I have no speed or trip distance showing, cadence is normally ok. also my watch strap has broken and because it is glued on i cant get it fixed!
Since your Cadence is working then there is a problem with the actual speed/ distance sensor. First make sure that in your settings you have speed turned on. If so then...
1) Your battery may be dead = Replace CS sensor
2) The distance of the sensor and magnet is not set correctly = make sure magnet on spokes and sensor are within 1-2mm of each other.
Polar can fix the strap, you need to send into an authorized service center. They replace the entire strap unit. If you send into Polar to get the strap fixed, then you can send in the sensor unit as well for diagnosis if you want. But if #2 doesn't fix, then it's #1 and they will just tell you to buy a new one anyway.
Nov 29, 2010 | Polar CS300 Cycling Computer and Heart...
Calibre S affected by magnetic field
All watches are affected by magnetic fields.
Yes, your Tag watch will be affected. If it has been in a magnetic field it will need to be serviced to remove the magnetization from the movement parts.
Hope this helps,
Ken
Yellowstone Watch Inc.
Oct 01, 2009 | Tag Heuer Link WJF2112.BA0570 Wrist Watch
Help with battery problem on Timex Ironman Data Link Wrist Watch and after installing a new battery the alarm is silent.
Help with battery problem on Timex Ironman Triathlon after installing a new battery and reset, displays the message 846010 1.0 P1and the alarm is silent.
Jul 08, 2009 | Timex Ironman Triathlon 50 Lap Digital...
Adjust the band links for Casio MTP4500D-1AV ( model #4755 )
You can tap out the pins in the band with a small punch. a ground off needle may do it
Jun 22, 2009 | Casio MTP4500D 1AV Analog with Chronograph...
Watches Logo
27 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
