Question about Sunbeam Food Mixers
Can't eject beaters, button won't move - Sunbeam Food Mixers
    Master:
  • 966 Answers
Try light oil to the button. It might work.
Posted on Dec 01, 2013
The beaters will not stay up in my Oster stand mixmaster. The eject lever will not lock them in. Can it be fixed? Or could it be that I need new beaters because they are worn out and do not fit in
wild guess turn beater as you push in to allow the beater to engage the drive, a little like gears meshing. You should be able to feel it lock into the drive.
Dec 21, 2014 | Oster Food Mixers
Beaters will not stay up in my Oster stand mixmaster. The eject lever will not lock them in. Can it be fixed? Or could it be that I need new beaters because they are worn out and don't fit
They need to be replaced or the locking mechanism does, but in the meantime, wind some thread around the beater end and this may keep them in temporarily.
I have kitchen aid stand mixer and i can't get the beater to attach because the button is stuck??
The button doesn't move. You must push the beater up beyond th notch and turn it while pushing up.
Jan 14, 2013 | KitchenAid KITCHEN AID 5 Quart Artisan...
The top part of my mixer is sitting about 1/4 inch lower than it should. It's placing the beater too low in the bowl and therefore won't mix. (I tried to whip up some whipping cream but it pushes...
Get a copy of the Repair Part List for your model at Kitchenaid.com
Download the following Kitchenaid Service Manual:
http://www.kitchenaidparts.be/centers/servicemanual/mixer.pdf
It covers several models including yours.
1. Check/Adjust the Flat Beater to Bowl Clearance:
Turn screw (A) SLIGHTLY counter clockwise (left) to raise the flat
beater or clockwise (right) to lower the flat beater
2. Check the Beater Shaft (Agitator Shaft) making sure the Retaining ring
is flushed with the surface of the Planetary Assembly
Constant Pulling and Removal of the beaters can cause the Agitator shaft to move
3. If the above two still don't solve your problem, follow the service manual
directions to disassemble the Planetary Assembly and check for loose screws
Jul 04, 2011 | KitchenAid KSM150PS Artisan Series Stand...
Need interior diagram of Sunbeam MixMaster Model 2486
Here's the solution. The spring controls the beater eject button. The spring is mounted on the metal shaft and is oriented so that the straight side of the spring rests along the white plastic part adjacent to the shaft, and the curved side of the spring points outward and downward so that it will rest against the case when the unit is reassembled. See photo.
Dec 26, 2009 | Sunbeam Food Mixers
I need replacement beaters for a dough hook stand mixer
Information from manufacturer stating replacement parts have been exhausted.
Jan 30, 2009 | Food Mixers
Instructions for Sunbeam 2350 Heritage Series Mixmaster
Go to sunbeam.com, select "kitchen", then select "customer service", then "instruction manual", then "stand mixers", scroll down to model #
Nov 23, 2008 | Sunbeam 2350 Heritage Series Mixer
How to disassemble Black & Decker MX50 PowerPro Mixer
You can remove the handle-back by gently prying the rear clips down and away. But the problem is the power boost button; it has a fork that goes down the left side and snaps over a micro-switch. You need to get that off since there is not room for all 3 buttons (eject, variable speed, and boost) to slide through the handle. A small probe inserted from the top and pushing on the left side to the rear might do it. Or just pry the boost switch upwards; that's how I got mine apart. My problem was the boost microswitch was bad and provided a poor connection. As a result, the beater only ran intermittently on regular switch positions. I solved it by bypassing the boost micro switch. The beater now only runs on the regular speeds but that's fine by me.
Nov 10, 2008 | Black & Decker MX50 PowerPro® Mixer
Kenwood HM 220pk100/W
There are not any spare part more than Beaters, Kneaders and Beater gears to this machine.
Jul 06, 2008 | Kenwood 120 Watts HM200 Hand Mixer
Food Mixers Logo
77 people viewed this question
Top Sunbeam Food Mixers Experts
Oscar Netto
Oscar Netto
Jerry Greenberg
Jerry Greenberg
Are you a Sunbeam Food Mixer Expert? Answer questions, earn points and help others
