Compaq desktop cq5107c yellow light stays on when started and fan starts for sec then stops. Keep trying to start by pushing on of button but yellow light stays on with blue power on, normally yellow only on when processing. PC will not start. HELP!
    Problem Solver:
  • 19 Answers
Hi, Could be several Things, But Sounds like a Power supply Problem. But TRy this:
Posted on Nov 17, 2013
kornho
  • 781 Answers
SOURCE: Orange Light permanently on motherboard. PC won't start
1. motherboards for atx form factor pc's are powered even when the computer is off, particularly if you leave the computer plugged in to wall outlet... you better do not work on you computer while power cable is still connected to both, your pc and the wall outlet..
2. I found this thread that may be helpful, it may be the motherboard may have gone bad, cmos is corrupted or something may not be seated properly...it could also be one of these: Bad CPU, BAD ram, Bad power supply.. read the thread for details:
http://www.dellcommunity.com/supportforums/board/message?board.id=oplex_other&message.id=23925&c=us&l=en&cs=&s=gen
Posted on Sep 25, 2008
deathraider
  • 64 Answers
SOURCE: gateway 505GR desktop...failure to start
when the power supply goes bad , that is the sign that it needs to be replaced . I would replace it first .
Posted on Mar 12, 2009
  • 4 Answers
SOURCE: resons why the hp DC5100 desktop will not start up
The first you need to do is remove the power cable to your Motherboard and back it again. If doesn't work , replace power supply, still not, replace motherboard
Posted on Jul 17, 2009
tbirdfan1
  • 3051 Answers
SOURCE: Emachine T6426 PC..I push power button and fans
Hello there:
If all of the fans come on, check to see if the fan is blowing on the power supply if it is not than you are going to have to replace the power supply. please keep me informed cause there is more that we can do if needed ok.
best regards mike
Posted on Aug 03, 2009
bob_computer
  • 3153 Answers
SOURCE: Compaq: CPU fan has failed PC will automatically power down
Your fan speeds up and slows down in response to temperature inside the computer. More so the CPU.
I would suggest getting a can of compressed air made for computers
take it outside, take of the side and blow all the gunk out of there, Really go to town around the fan (you might want to wear eye protection)
While you are in there just check that the CPU cooler itself is not loose
If it is it will have to be re-seated.
If it needs re-seating don't just take it off and put it back on as that might make things worse with your temperature problem they have to be cleaned and new thermal grease put on ($2-5)
DON'T remove the CPU just the fan/cooler assembly.
You must clean both the surfaces without scraping anything off. Use isopropynol alcohol and cotton bud sticks until both surfaces are clean, you can use your finger nail to scrape harder residue if you wish but nothing else.
DON'T pour the alcohol over the CPU
Now apply some new thermal grease (most computer shops have it)
Be careful about how much you put on
Here are
some basic instructions
Once you have re-assembled your cooler and re-connected it check everything is OK and power up the computer.
If everything went to plan you should now be back in business
Hope this gives you the information you need
Bob
Moderator
It would be very decent of you to consider the quality of our experts answers and judge them accordingly as you pass through fixYa.
Thank you
Posted on Nov 27, 2009
Computer will not start
Press power button down for 5seconds until the computer shuts down. Remove power cable, press power button down 10s. Connect cable, try to restart.
Aug 17, 2012 | Dell Computers & Internet
Push power button and the power light turns amber and lights up then shuts off. the light in back of the computer is light green and it starts to turn on then dies
The fact that ity is trying to start and shuts off after ..it seams that it is the CPU fan to blame ...If the fan fails to start the CPU will turn the computer down instantly due to the temperature limit ..(in 1 or 2 sec ) ..
so ...open it up ..and see if the fan is spinning ...on start ..and if it is not ...check the connection with the board or replace it ..
(by the way ..this may also be a CPU failure ..and need another one ) ..
Aug 31, 2011 | Dell Inspiron 518 Desktop Computer
System will not start. four green lights on solid. button light on solid yellow main board? cpu?
Hello
Could be a bad stick of memory,try taking one out then starting pc.
Do this to all sticks.If pc starts then keep that stick out.
Second,try to check that cpu is secure and fan is working.
Mar 21, 2010 | Dell Dimension E310 PC Desktop
Compaq Presario sr1000(sr1430NX) will not stay powered on
Hi!
Please check for the cables coming into the motherboard from the power supply. Also try and check for any loose cables.
If that doesn't help then please get your power supply changed as its faulty.
Please rate this solution.
Thanks
Rylee
Feb 11, 2009 | HP Compaq Presario SR1430NX (PS566AA) PC...
Hp530 Ultra Slim starts and stop after 3-20sec
I have had this once before, and then it was one of the hard disk cables which was interfering with the fans inside the case. In my PC it was the PSU fan which was being halted. Try moving the cables around inside the case and ensure none of the corners where they are folded are protruding into any of the fans.
Feb 03, 2009 | HP Compaq Business d530 Ultra-Slim PC...
Kenmore Dryer stop running when release the start button
I have whirlpool dryer, when i push the start button it will start but only stay on for part of the drying time. no the start button make noise when push and after keep trying it stop.
Dec 30, 2008 | Whirlpool LEQ9858P Electric Dryer
Pover up trouble
sounds like something is drawing down on your 12 volt supply drives or on board regulators. Try it without the drives connectged, and see if you can get the system to boot up(you'll just get a notice that your drives are unavailable, but you'll already know that, right?
got backup for your Dell?
Feb 15, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Computers & Internet Logo
192 people viewed this question
David Payne
David Payne
