Question about Lite On LVW-5005 DVD Recorder
Video will not sync, audio is okay - Lite On LVW-5005 DVD Recorder
Audio is out of sync with people talking on television. Any suggestions?
It depends if this happens all the time, or on certain channels, or just on a digital TV, or in certain weather conditions. The audio and video are different data streams that have to synchronize. If your antenna blows in the wind, you could have the video lose sync and take a fraction of a second to get its act together, and by then the audio is on the next word. Some local broadcasts have intermittent sync problems. Sometimes just flipping between channels gets it back in sync.
Apr 06, 2017 | Televison & Video
Audio out of sync
Not much information is provided but generally speaking a sync problem when playing back is not a problem with the amp but a problem with the source file, especially if you are playing a downloaded file. If you are playing a DVD this should not happen. If it is happening with a DVD, please provide further information.
Cheers, Don.
Dec 08, 2013 | Denon AVR-1804 Receiver
Streaming video audio out of sync
There is no way to fix this, as the new netflix app for android is meant for android versions 4.0 and up, and the galaxy tab not only lacks that version, but does not have a fast enough processor to process the audio and video, causing lag in the sync.
Dec 01, 2013 | Samsung Galaxy Tab Tablet PC
Sync problem between the audio and video using 123 copy dvd gold
Try doing a batch conversion and lowering the audio bitrate to help the audio sync with the video.
Jun 06, 2010 | Navarre 123 Copy Dvd Gold for PC
Made an ipod video and after sending it to a friend to view. He is unable to watch
Can he sync it and does it display in the video items? Or can he only hear audio?
Could the the video format is not correct. Try converting it with handbrake.
It may be that the when it syncs it is not syncing to the video folder, and may only play as audio, which means the video format is incorrect.
Or "Video Out" could be turned on in video settings, go to video and settings and turn it off.
Mar 18, 2010 | Apple iPod nano
Guitar works but it dosen't when playing?
It could be that you just need to sync your video setting, possibly the audio too, although I have found that syncing the video alone is enough, which you can set up on the game. If you have a flat screen, they are notoriously known for processing induced lag. Just follow the syncing process they have you do (should be set in the upper 80's to lower 90's if you did it right), then you should be hitting notes in no time.
Aug 02, 2009 | Nintendo Guitar Hero Wireless Guitar - Wii...
Video and audio lose sync when disc is burned
If your video and audio is out of sync you need to repeat burned to your dvd disc again.
Insert your blank DVD disc and then after that do this.
Click on start button of your Studio>video and audio preferences>uncheck background rendering>check used this codec for background rendering>check the pull down arrow and choose MPEG2 for best out put tot disc. Click on prject preferences>look for delete button click it then delete aux file for all project then click okay. You may now try to burned to disc again.
Jun 01, 2009 | Pinnacle Studio Plus Version 11
Ipod nano
.mp3 for video music also...
Jun 17, 2008 | Apple iPod nano 3rd Generation
Audio out of sync
You may want to put the audio into the microphone-in of your laptop and make menu selections for audio via that line-in port when recording. I found as well that the audio sync was out of whack when trying to have it go with the video through the EasyCap..
Nov 24, 2007 | Ulead Videostudio 8 for PC
Problems with video types?
audio sync require resync with Windows Media Player, at least
Mar 19, 2007 | SanDisk Sansa e250 MP3 Player
Lite On LVW-5005 DVD Recorder Logo
22 people viewed this question
Top Lite On Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Lite On Televison and Video Expert? Answer questions, earn points and help others
