Im using micromax canvas 4, suddenly my sceen turned into vertical color lines. After switch on and off the mobile for two times. Then it become normal... It happened for three times... Im using a mobile wallet that having magnetic button. Im doubting that but i want to know proper reason... It is one month old mobile.....
    Top Expert:
  • Computers & ... Master
  • 25,694 Answers
It uses a magnet to determine whether or not the cover is on so that is possible.
Posted on Nov 17, 2013
5 Suggested Answers
Rick60639
  • 29 Answers
SOURCE: Vertical Lines in the Monitor
Unofortunatly your monitor is going going going and maybe gone. If you are still under warranty call Dell ASAP, but it turns out that this issue is very common. There have been lots of complaints of monitors only lasting as long as the warranty period.
The only real solution is to replace the LCD. It is any easy fix for a DIY project if you have a bit of time and patience, if you dont then you are looking at spending on anywhere from 200 - 500 on parts and labor.
Posted on Nov 12, 2008
Theknack
  • 144 Answers
SOURCE: Vertical lines in my laptop screen
what i recommend you to test is to press behind your monitor and see that the line goes off or not.If it does..that mean you have a loose connection,it can be fix.Incase no then you have problem with your LCD.Normally if its LCD problem then you fix this problem,all you have to do is change the LCD.
goodluck,takecare.
Posted on May 04, 2008
  • 18 Answers
My understanding is that you have 2 laptops with the same problem, if that is the case, you need to replace the lcd. When you have lines on lcd's, that is a sign of a bad lcd.
Posted on Jun 10, 2008
SOURCE: HP Pavillion zd8000 lines on monitor
To date, HP has refused to repair these defective laptops despite being fully aware that the problems do exist. The only real solution that I'm aware of is to write to the BBB (the one in California located near HP's Executive Offices). HP agreed to repair my laptop at no charge after I went this route. To the best of my knowledge, they replaced the display as I no longer have the vertical lines. It appears that they may have also reduced the processor speed as the computer runs much cooler than it ever did before HP made the repair. It's been several months since the repair was made and, so far, no problems whatsoever. Hopefully that will continue.
Posted on Dec 31, 2008
Micromax canvas a 101 pattern lock open
How to Unlock Micromax Phone Using Hard Reset Using stock recovery and wipe data. This method will result In a full factory reset of your phone . How to do this?
  1. Switch off, Pull battery.
  2. Insert battery and Press and Hold Power+Volume up+Volume down together (different phones might have a little different method of booting into recovery mode, but this is the most general one).
  3. You will then boot into recovery mode , use volume keys to navigate up and down and power key to choose.
  4. Choose Wipe DATA
  5. Choose wipe cache.
  6. Reboot device.
You are done and your lockscreen is gone and phone has been hard reset. Please not this leads to permanent removal of data.
Unlock Micromax Android Phone using Android Debug Bridge In this we will use ADB (Android Debug Bridge) to unlock the device without losing any data.
  1. First we need to set up ADB on device , you generally need these link of adbzip in the bottom or you can Google on how to install ADB in windows.
  2. Just make a folder adb in c/root and copy the files.
  3. Install drivers of your phone (Use PDAnet if you have problem with finding drivers).
  4. Turn on USB debugging on phone. Follow : Setting->Development->USB Debugging (Turn On)
  5. Open Command prompt in computer , and type cd C:/Android (Android here is the folder where my adb files are , change according to yours)
  6. Then you can try following sets of command
Adb files rar download 2shared
Jan 20, 2015 | Uniden DECT 6.0 Cordless Telephone...
Emergency calls only micromax Canvas A111
simply re-start the phone and check whether the problem persist .if so then use another network sim .And if the problem continuous take your mobile to a near by service center and get it fixed
Aug 06, 2014 | Micromax X265 Cellular Phone
Micromax master resetting code all
Hard Reset Micromax Canvas HD A116
  • Switch Off your phone.
  • Press and hold Power button together with 'volume +' and 'volume -' buttons on the side of phone until you get two options.
  • Now, press the 'volume +' button to enter into the recovery mode.
  • This will make a Android icon appears on screen, press power button.
  • This will get you the menu options, use the volume up and down button to choose the option.
  • To select the option, you needs to simultaneously press two touch sensitive buttons on the bottom of your device, left button which is for the Menu and right button which is for going into previous stage. You have to do this for about 3 seconds.
  • Choose the wipe data/factory reset then press the enter button (left button which is for the Menu and right button which is for going into previous stage). Now, phone will get switch off and brings to its initial stage.
Done! with this default way to factory reset you have successfully done with hard reset of your Micromax Canvas HD A116. The hard reset procedure is same for Micromax Canvas A110 also. If you have any questions regarding the procedure to hard reset Micromax Canvas HD A116.
OR
The Instructions
  • Turn Off your device
  • Press and hold the Volume up (+), volume down (-) and power keys at the same time until the screen show the two options
  • You will get the option Recovery mode and Factory mode , to select the Recovery mode press the volume up (+), for the Factory mode press the volume down (-).
  • If you want to hard reset your smartphone, you should select the recovery mode.
  • To navigate it, you can use volume up and down.
  • To select an option, you must press the Menu button.
  • After you hard reset the device, your smartphone will return to factory setting automatically.
OR
Hard Reset:
  • Press and Hold Volume Down + Power Key for 20-30 Seconds.
  • Now you See Warning Logo on screen.
  • Now Download Android Multi Tool
  • Download fastboot driver and install Drivers
  • now open tool and press "8" and enter to wipe data / factory reset.
  • after format remove battery and reinsert battery.
  • power on the handset.
  • Download Driver from Here
  • Download Android Multi Tool from Here
Nov 07, 2013 | Cell Phones
My micromax a87 was suddenly switched of and it is not getting on again what shal i do
Micromax A87 was suddenly switched off, it cab be the problem on hardware or may be virus problem, you need to show on this phone on a mobile shop.
Dec 12, 2012 | Cell Phones
How to install any softwares for micromax q5
Visit getjar.com and you can download the applications.
Cheers, The K.
Oct 28, 2010 | Health & Beauty
Horizontal white lines 27A43.
You have some bad capacitors. They are located very near and next to your vertical IC. I would guess you would have to replace maybe four of these! Thanks for asking!
Jun 12, 2010 | Toshiba 27A43 27" TV
Screen only showing vertical lines after being dropped
The damage could be either in the LCD screen or the connection cable. Open the screen assembly and check the connection cable first.
In case it doesn't work you can find replacement LCD screens here.
www.piezas.biz
Jul 02, 2008 | Toshiba Satellite M55-S135 Notebook
Computers & Internet Logo
59 people viewed this question
David Payne
David Payne
