Question about Lite On LVW-5005 DVD Recorder
My liteon video rolls, sound is ok - Lite On LVW-5005 DVD Recorder
I need help finding out why my computer says no burner connected when ive burned disc from my liteon driver before from windows and now when i go to burn it say connect burner when ive checked the...
sounds like a faulty electrical connection check all connections that attach PSU to your burner or go into administrative tools,computer management, device manager if yellow? uninstall or roll back then once you uninstall diconect from PSU then re attach re-install
Jul 27, 2010 | Lite On SOHR-5238S CD-RW Burner
Liteon dvd recorder won't play or record from disk or cable tv
You should be able to connect with the AV input, Y, Video R, W. Audio, they go to same color on DVD & TV.
Feb 18, 2010 | Lite On LVW-5005 DVD Recorder
Sound is on, picture snowy, b/w and rolling to the left.
Ok, do a vibration test. shake it, hit it, shake the wire coming in and watch the screen. if it clears for a sec it is a bad connection. if not, let me know. When it is said that a picture is worth a thousand words they didn't realize how much truth was in the saying. it is closer to 100,000 to 1. sound is the 1. if you have sound and poor video it could be a lack of signal. The rolling part is a lack of the sync signal. Barn
Oct 25, 2009 | Televison & Video
Acer aspire one doesn't see liteon ez-dub
Linux operating systems may not support Liteon EZ-Dub External DVD Drive. Check on the Linux forums.
Jul 31, 2009 | Computers & Internet
Liteon LVW-5005 DVD Recorder. Disk drive door will not open.
give it a tap on the bottom as you press the button, this will force it to release the disc,
Jul 03, 2009 | Lite On LiteOn LH-20A1P - Disk drive -...
Liteon na115 mainboard can't display/load bios
1) Try re-seating the RAM
if it's still the same problem, then the power supply maybe bad.
Try with a good PS.
Jun 17, 2008 | Lite On NA115 Motherboard
Rolling picture
sounds like the update may have changed your video settings. Go to the settings tab and change your video settings to match your television, it will be 480p, 720p,1080i or 1080p I believe.
Apr 19, 2008 | Microsoft Xbox 360 Console
Lite On LVW-5005 DVD Recorder Logo
19 people viewed this question
Top Lite On Televison & Video Experts
Jaime Hernandez
jason
Are you a Lite On Televison and Video Expert? Answer questions, earn points and help others
