Question about Kenmore 62602 Electric Dryer
66831 kenmore dryer heats but no motor sound
Motor does not run but heat is on .no humming or buzz or any noise Fromm motor.was working fine yesterday
  • 91 Answers
SOURCE: kenmore dryer hums but will not rotate
PRETTY OBVIOUS REPL/ MOTOR
Posted on Jan 03, 2009
goofduck
  • 490 Answers
SOURCE: Kenmore Dryer 62802 Doesn't Heat
sounds like the heating element has gone south
if you open up the dryer you can check continuity across the element but make sure power is unplugged
Posted on Apr 13, 2009
tony2155
  • 64 Answers
SOURCE: Dryer runs fine but no heat
change the fuse in back of the dryer
Posted on Jun 23, 2009
  • 2696 Answers
SOURCE: Kenmore Dryer Mod. #110.68932792 Ser. MJ1907445
there is a motor relay in the consol part 3405281,there is also a heat relay too,you can swap em out to see if this is the problem, the one on right side with blue wires is the motor relay let me know how you make out
Posted on Nov 19, 2009
  • 311 Answers
SOURCE: I just replaced the motor in my Kenmore Series 90
It could be possibly your rear roller bearings expanding with heat causing them to not spin as freely? Im not really too sure but its an idea you dont have many moving parts on the unit. Just your idler pulley, blower wheel, and rollers. Hope this helps.
MJ
Posted on Feb 14, 2010
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
www.applianceblog.com/.../7655-Dryer-won-t-start-Makes-electrical-buz...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' PartSelect.com ...
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
DRYER BUZZING NOISE - Dryer For Sale
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
Dryer heats, and runs empty. Once even a small clothing item is added, when the start button is hit, there is a buzzing noise and it will not start. It then will also not run empty for a time. What could...
hum might check ur moister sensor? and also u may have bad motor windings try this If you hear a humming sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Mar 30, 2015 | Dryers
I have a kenmore model #66512694 electric dryer. It will heat up fine and tumble but makes a loud humming noise and cuts off.
Sounds like the motor is over heating. If you have to wait a long time for it to come back on. If so you may be able to clean it but more then likely need a new motor.
Nov 12, 2010 | Dryers
Kenmore 11066812694 dryer whirring noise in back
Could be the rollers holding up the drum, or the motor blower fan.
Jan 18, 2010 | Washing Machines
Whirlpool dryer WED5530SQ0, heats but does not run
So,. basically your drum doesnt turn. SO your getting heat still even though the drum isnt turning. Is this right? Sounds strange??? Do you hear any humming noise when you push the start button? I need to know a little more about the problem because im kinda confused as how you decribed the problem. Iv never seen a dryer heat but the drum not spinning. especially your model dryer. Its electric heat right? because if the drum doesnt spin, maybe your motor is bad. and if your motor is bad, then your heating element wont heat up because the centrifical switch in the motor is not switching to complete the circuit to the heating element. So this is why im confused when you said" Dryer heats when knob turned but when "push button" pressed, drum doesnt run." Because your belt wraps around the motor pully and the motor is what makes the drum turn. Like i said, i never seen this model dryer heat with out the motor operating. So if you can give me some more info, ill do my best to help you out....Thanks!!!!
Jul 30, 2009 | Whirlpool WED5500S Electric Dryer
Dryer won't start 7yr old dryer, was working fine yesterday, today was making strange buzzing noise while running, stopped it to check, and now won't turn back on.DEAD
Sounds like a defective motor starter contactor. DO NOT continue to try to use the dryer or you'll burn the motor out. The motor starter is built into the motor, but most are replaceable without replacing the entire motor.
Could also be the motor, but sounds like the motor is stuck in 'start' mode and never goes into 'run,' which would be the classic symptom of a stuck motor start contactor.
Jun 14, 2009 | Dryers
Dryer makes buzzing noise but will not run.
that is the sign of a bad dryer motor-sorry-mike
May 08, 2009 | Dryers
Loud buzz when starting, then shutting down after 10 min.
Yes, this sounds like the motor cutting out on thermal lockout.
Apr 10, 2009 | Kenmore 62602 Electric Dryer
Kenmore 80 series dryer
humming noise usually means a bad motor. how much did you disconnect when changing element?
Jun 14, 2008 | Kenmore 63942 Dryer
Kenmore 62602 Electric Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
