Question about Garden
Will not stay on
The motor will turn over and run for a few seconds. It has a new battery and primium gas.
  • Garden Master
  • 2,478 Answers
Check the gas cap vent.
Posted on Nov 17, 2013
Nissan stays on for a few second then shuts off. all lights in dash are on.
Could be the spark plug wires, the mass air flow sensor, the fuel pump, or the fuel filter. Many things to check. Please be more specific. The car starts and the motor runs for a few seconds? Thank you.
Dec 19, 2015 | Nissan Cars & Trucks
2000 road king starts and runs for a few seconds will not stay running got new batterynew tank hoses fuel filter will not stay running also have a power commander
Hi Anonymous, and the usual suspects are:
1. Severely discharged or damaged battery.
2. Loose, corroded or broken battery cable.
3. Alternator not charging or below normal rates.
4. Failed ignition coil, ignition/electronic module.
5. Failed CKP, CPS, CMP, MAP, TPS, or BAS sensor.
6. Faulty ignition switch.
7. Water or dirt in fuel system, carburetor or filter.
8. Fuel tank vent system plugged or gas cap not venting.
9. Fuel tank empty.
10. Fuel valve vacuum line broken or carburator vent line closed off.
11. Restricted, blocked or kinked fuel line.
12. Failed fuel pump, pressure regulator and or fuel injectors.
For a prime suspect please visit website below and good luck:
Big Twin Carb EFI DTC Intructions codes Harley Davidson Forums Harley...
Dec 27, 2013 | 2003 Harley Davidson FLSTCI Heritage ...
Why wont My 2006 Suzuki boulevard won't stay running,? I bought a new battery and its not that. It turns on for a few seconds and idles real low then shuts off. The sound of the bike sounds like i
It sounds like it may not be getting enough fuel to the carb(s). Check to make sure that fuel is flowing from the tank. If not, it may be a problem with the petcock or the vents on the gas cap may be clogged.
Jan 28, 2013 | 2006 Suzuki Boulevard S50
1993 Grand Cherokee won't stay running or turn over
Sounds like a clogged fuel filter to me, maybe look into the TPS: throttle positioning sensor. Good luck
Feb 11, 2012 | 1993 Jeep Grand Cherokee
My car has trouble starting & staying started. Sometimes it does start & runs fine for a few seconds- a few minutes, Then it just suddenly cuts off. engine sounds very smooth when it is running. No...
this might well be the air flow valve it is located in the intake duct work. this works to control the air flow to your motor to optimize volumetric efficiency. when these stick its chiking out the motor this is a good place to start
Sep 04, 2010 | 1998 Honda Accord
Tiller will not stay running
The first thing I would check is the vent in the gas cap. If the vent gets blocked with dirt, a vacuum is formed in the gas tank; and gas will not get to the carburetor. There should be a tiny hole in the middle of the cap. Run a pin or needle down this hole and make sure it is not blocked.
There also could be a gas filter in the fuel line somewhere. This filter could be stopped up.
Apr 20, 2010 | Troy-Bilt Pony Garden Tiller
Mazda 6 '06 won't start
Well you are right, it does sound like it's just the battery. Since you can't get the car to stay running, take your battery to your local parts store and they will test the battery for free.
If it started like that but shut off right away it's probably cause the cells in the battery just can't hold the energy anymore.
If the battery tests bad get the new one and put it in, after that go back to the parts store and have them test your entire charging system, most parts stores do that free as well.
Dec 19, 2008 | 2003 Mazda Mazda6
Garden Logo
12 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
