Question about RCA RT2390 System
What Sizes Fuses Needed?
The power fuse blew to pieces & i do not know what size fuse it needs. Does anyone know what amp fuse I need?
3 Suggested Answers
  • 1030 Answers
SOURCE: Me again TV is driving me crazy....
Ok let see what we can do. These rca can be trouble. Im a technician and i see these alot. I guess that a good recomendation for these set LOL. First question. I take it you had the FL231 fuse problem... YOu replaced the fuse did you do the most important step. RESOLDER the flyback connections. i beleve that is step 7 in the instruction. this is the main reson this fuse blows. i have run into only one other case ...out of the hundreds of fuses i have replaced where the small signal cuircit board cause it to blow. but like i said very rare. i used to just put that fuse in and not resolder... it would come back to me within a day. LEt me know what happens
Posted on Dec 06, 2008
  • 7 Answers
SOURCE: what is the W &
width and height
Posted on Dec 22, 2010
Gevalia cm650 termal fuse
You need to verify the size of thermal fuse. My cm-500 had 2 fuses, both 184 degrees C. I have also heard of there being 2 different sizes in some makers. Check out "goodmans.net" to order proper size. You can try Radio Shack but they very seldom have the needed fuse sizes(either too high or low). You will need crimping connectors that I did get from radio shack and a pair of pliers.
Jun 30, 2014 | Gevalia CM-500 12 Cup Coffee Maker
Need to know what order to hook up red,yellow,and black wire which to positive which to neg and what size inline fuse is needed for my mcd 5080
Red- power Yellow-Memory Black-Ground
Unless the yellow wire has a fuse built into it then....
Yellow- Power Red-Acc/Ign Black- Ground
If the fuse you are asking about is on the radio t s usually a 10 or 15 amp fuse but if you mean for the power wire for a amp then it depends on the power amount of the amp....look on the amp and find the sum of the fuses on the amp and use a inline fuse that is the next fuse size sum...
Ex. 2 40 watt fuses on the amp then 40+40=80 watts so you would want to get a 100 watt fuse. Also remember you can never go to big for your inline fuse with a amp
Aug 22, 2011 | Jensen Car Audio & Video
I need to know the fuse sizes for the fuse box, theres 5 places for fuses
run a 10 amp fuse, if it blows start looking for a short. do yourself a favor and rewire the fuse box to an up-dated box, glass fuses will only get harder to find.
Good luck
M.Woodring
Apr 18, 2011 | 1981 Suzuki GS 750 L
Hello i just bought a power acoustik cpt1-4000d amplifier and we and a friend of mine were hooking it up and he accidently blew the 4 30 amp fuses in the amp. so we replaced them with 4 40 amp fuses and...
You shouldn't have replaced 30 amp fuses with 40 amp fuses. The 30 amp fuses were in there for a reason. You'll probably find that if you put the correct sized fuses in then it will work. If it doesn't then you have burnt out or melted something and it will need repairing.
Nov 11, 2010 | Car Audio & Video
Hi there we have a la cimbali m30 dosatron and someone has pulled out all the fuses on the pc board and we need to know what sizes they are to replace them. Thanks Simon
There usually no fuses on a M30 dosatron unless it's the "L" shaped supplemental supply board which has a small 250V, 6 3/4 A fuse (half the size of a normal glass tube fuse). Most boards use a similar size but rated at 4 amps for the PC board power protection. The only other fuses (older models) have big 10 amp jobs for the main power to the heater elements. But this has been replace with safety relay and or high thermal limit breakers. you should be able to find both at a hardware store. The smaller fuses at Radio shack or electronic store.
Oct 21, 2009 | Espresso RMI La Cimbali Espresso Machine
Need fuse size for cobra cpi-850
80a fuse should work fine thats the size i have it installed with i used 4 ga. wire
Jan 08, 2009 | Cobra CPI-850 Car Audio Amplifier
Gen lee blowing fuses when keying
What size fuse are you using? If you have a different power cord than that which came with the radio, such as one from a regular cb radio like a cobra 29, it will only have a 2.5a to 3a fuse, which will blow everytime you key up, since it is pulling to many amps. You need to have at least a 7.5a to 10a fuse. I use 7.5 amp fuses, because I have a 100 count box, and have no problems. The Stryker radio I have in front of me has a 10a fuse in its power cord from the factory, though the cord on my bench only has a 7.5a and has not blown.
If your radio still blows fuses after this, please let me know. You can message me here or email me at rollincbmods@yahoo.com.
Dean Pitts
Rollin CBs
Aug 29, 2008 | Connex 3300 240-Channels Base CB Radio
RCA RT2390 System Logo
41 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
