Question about Freemake Video Downloader
File corrupt why it cannot open
Excel Corruption files
Without seeing the file, it is difficult to diagnose what is going on, but I will offer some ideas.
What version of Excel are you using? Are you using Excel 2003? Was the file you are trying to open created in Excel 2007 or Excel 2010. If so, it might be using the new format and therefore will not open in Excel 2003 and older.
It is possible the Excel file is data that was imported from a source in which Excel cannot import. Does the Excel spreadsheet contain any imported data?
Try to use: XLSX Viewer Tool here : http://www.xlsx.viewertool.com/
Those are the most likely causes of the corrupt data. Is every file you open in Excel corrupt, or just this one workbook? If it is just this one workbook, then, yes, it sounds like it is corrupted. If every file you open with Excel is corrupt, then your version of Excel could be corrupt, but that is unlikely.
Jul 10, 2015 | Microsoft Excel for PC
How to fix format Error: not a PDF or corrupted
What else do you think it could be but a corrupt file? Two programs say the file is corrupt....the file is corrupt. Have them resend the file if you can, otherwise it's lost.
Jun 17, 2015 | Databecker PDF Producer for PC
Winrar repair corrupted .Rar Files
Sounds like the rar file you got is corrupt.try downloading it again.
Mar 03, 2015 | RARLAB WinRAR
Corrupt excel 2010 file
1 - Using "Open and repair"
Microsoft Excel has a built-in repair tool for corrupted files. To access it, go to File and Open. A menu will pop up in which you'll have to select the file you want to fix and then choose "Open and repair" from the dropdown menu. This will open a dialogue box in which you can pick between the repair option (which will recover as much information as possible) and the extract option (that will copy values and formulas). The two alternatives combined should work fine to save your work.
2 - Saving the file to a different format
If you can open the file but you can't modify it or save the changes, you should use this method. You'll have to save the file to a different format (such as SYLK or HTML) via the "Save as" menu. Once you've done this, you'll have to open the recently saved file and then save it once again (but this time, you'll have to choose the Excel Workbook as the format). By doing this, you'll be creating a fresh new file with all the data from the corrupted file.
3 - Opening the file in Microsoft Word
This option is only available for the people that have the Microsoft Excel converter installed on their PC (it can be downloaded from the Microsoft website). You simply have to open the corrupted Excel file with Word. However, you should know that this method only works for retrieving data (all the structures from the sheet will be gone, such as formulas and macros).
4 - Altering the Calculation option
If your file isn't opening at all you can try to adjust the calculation option. Simply open Excel in a blank workbook, go to the "Tools" menu and look for "Options". There you'll find the "Calculation" tab in which you'll have to look for the "Calculation" section and set it to "Manual". Click OK and then try to open the corrupted file once again.
5 - Linking the corrupted file
In this method, you'll have to link one cell of a blank worksheet to the corrupted workbook. Be sure to create the new worksheet in the same location as the corrupted file. Once you've done this go to the blank worksheet and enter the following in the A1 cell: <Filename>!A1. This will copy the data from the A1 cell of the corrupted file to the new sheet. In case it works, simply click "Edit" on the cell and select an area like the one covers the cell that contain data in the damaged file, and then click Paste. Then (and with the cells still selected) click Copy on the Edit menu.
Jan 23, 2013 | Western Digital Corporation WD ShareSpace...
Corrupt excel sheet
MS Excel comes with an automatic recovery feature that attempt to reopen corrupt excel file along with repairing a file. If it fails to repair a corrupt excel file then try to open a file without repair. Sometimes this automatic recovery feature fails to open & repair corrupt excel files at this stage users can repair corrupt excel file manually.
To Manually Repair an Excel File: For manual repair of a corrupt excel file, you have to perform following steps:
  • Go-to the File Menu & click on 'Open'
  • Now select the file that you want to repair and click on the arrow next to 'open' button.
  • Click on 'Open & Repair' & any one method that you want to recover your data.
Source : Link
Jan 16, 2013 | PNY 8GB USB 2.0 Flash Drive - Blue/Black
Office word files in my pc become corrupted. I can't read them.
Try to repair your corrupt file with the help of Open & repair. You can do this by following below steps:
Start->File->Open->Select the corrupt file->Click arrow next to open button->select open & repair
If you are still facing the same problem then try to start MS word in safe mode.
If you will be able to open the file in safe mode then there is a problem with add-ins. Delete all the add-ins to fix the problem.
Nov 02, 2012 | Microsoft Office Word 2003 for PC
How can i recover a corrupted word document (.docx) file?
If you cannot find any of your Word, Excel, PPT or other Office files on your Mac, you might have met file loss situation. But don't lose your hope. Here comes an amazing solutions for Mac deleted Recovery to help.uFlysoft Mac Data Recovery Tool can help you to recover the lost files on your Mac, It is a professional Mac data recovery software which is powerful enough to retrieve unsaved, corrupted and deleted Word files easily.
Nov 03, 2010 | Microsoft Computers & Internet
Excel files couldnot opened
It is because your excel file is get corrupted. There are several reasons of excel file corruption; virus attack is main reason of corruption. You can fix this problem with the use of "open and repair" utility of MS excel or you can use Excel repair tool http://www.stellarinfo.com/excel-recovery.htm .
May 05, 2009 | Computers & Internet
Microsoft excel file crrupted
To open a corrupt file; you have to repair the file first.
MS Excel has a special feature to repair corrupt file that is Open & Repair.
Repair a corrupt excel file by following steps:
  • Open a blank wordbook.
  • Go-to the File menu and click on the open button.
  • Now select your corrupt file and click on the arrow next to open button.
  • Select Open & repair option and click on the open button.
  • Save as the file and give the new name.
Additionally you can try 3rd party excel repair software if Open & Repair fails to repair corrupt file.
Sep 13, 2007 | Microsoft Office Standard for PC
Computers & Internet Logo
Top Freemake Computers & Internet Experts
David Payne
David Payne
Are you a Freemake Computer and Internet Expert? Answer questions, earn points and help others
