Question about Mitsubishi WD-73642 - 73in Class 1080p 3dtv Dlp Hdtv
Mitsubishi 73642 input is not being read on my tv
My daughter somehow deleted the input for cable and ps3 how do i add them back to the input list
4 Suggested Answers
SOURCE: Hooking up my new PS3 to my five year old 55" Mitsubishi HDTV.
The Sony outputs 180P, not 1080i. There is a difference. I don't know what exactly, but Sony says 1080p is for superior.
Posted on Jan 16, 2008
  • 4 Answers
SOURCE: PS3 not recognized by Mitsubishi WD=52525 tv through HDMI
FYI,
PS3 has output settings and would need to be adjusted if you are coming from the RCA input. Check out www.sony.com/ps3 trouble shooting under display problems. I believe the solution is to turn on the PS3 unit and keep holding the I/O button for more than 5 seconds. I had the same issue going the other way.
Good Luck.
Posted on Jan 10, 2009
  • 44629 Answers
SOURCE: My Mitsubishi WD-73642 TV won't come on there's no power period no blinking light or anything what could be wrong
check for power at the wall outlet
Posted on Nov 04, 2015
I have a WD-73642 tv has no picture but has sound
I had this problem with a laptop of mine it's the led just replace the screen
Mar 21, 2016 | Mitsubishi Digital Television Mitsubishi...
Mitsubishi rear projection tv, model WS-48311 - Lost audio after moving tv and re-hooking up cables. How do I get it back?
It sounds like this TV is being used only for the PS3. We'll need to troubleshoot this through a process of elimination.
If you're using Component Input 1 and audio, try using Component Input 2 and audio instead. If this set of inputs provides working audio and video - you can stop. Or, try going back to Input 1 once more. If Input 1 now works - you may have simply made a better connection. If it doesn't - then there's probably an issue with input 1 on the TV.
If moving to Input 2 above still didn't solve the problem, you should try using a different set of audio cables between the HDFury and the TV. If it now works, the original audio cables are faulty.
You can check the HDfury setup on another HDTV with component inputs with it connected to an HDMI cable. if the HDFury wors, you know the device and all the cables work. If you do this test and it works with your PS3, then you know that the PS3 is providing good video and audio signals via HDMI. If the problem follows the PS3 - then it's the PS3 at fault. If everything works perfectly on the second TV, then there is some issue with the audio amplifier / inputs / speakers of the Mitsu TV. You could get a cheapo stereo amp and speakers - or a set of computer speakers for audio - it all depends on how much you want to spend for sound.
Good lcuk!
May 07, 2015 | Mitsubishi Televison & Video
Incompatible video signal has received check output device settings
My guess would be that your PS3 has somehow switched the output settings. You can reset the settings by pressing and holding down the power button till it starts blinking. Try connecting it with your RCA cables to a TV and if that works try going into your settings and setting the PS3 back to HDMI.
Jan 23, 2014 | Sharp Aquos Televison & Video
No color on my mitsubishi wd=73642
Check its picture settings. Especially to system settings.
Jan 16, 2014 | Mitsubishi WD-73642 3D DLP Home Cinema TV
My Mitsubishi WD-62627 has no pic/sound w/ PS3
you just have to keep switching the back button off and when u turn it back on hold the front power button till you get 2 beeps
Apr 18, 2010 | Sony Playstation 3 (PS3) Console
FYI,
Good Luck.
Sep 24, 2008 | Mitsubishi WD-52525 52" Rear Projection...
No picture
Somehow you have your inputs not on... but don't get ahead of ourselves. Check the cables in back... The video cable in... make sure it is fully connected from cable box / satellite box to input, then make sure the input is on where it is plugged in.
Feb 18, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Dec 31, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WD-73642 - 73in Class 1080p 3dtv Dlp Hdtv Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
