Question about Dryers
Squeaky Utilitech pedistal fan....
I do not see an oil port.....any suggestions or is it a "disposable" fan???
How do I fix a Squeaky pedal on Roland digital grand rg1f
Squeaky usually means something needs oiling. If you have a long snout on an oil can, you may be able to reach the pivot on the pedal to oil it. If not, then you have to take the pedal apart to oil it
Aug 03, 2014 | Roland Music
Squeaky condenser fan motor on Carrier 3 ton central air. I oiled once 4 months ago and noise stopped but noise returned today. Is there a special oil for the berings?
Hello
Usually a light oil.Wd 40.
Most of these motors are sealed bearings,meaning they do not get oiled.When they start making noise it means the motor bearings are getting worn and the motor will need to be replaced soon.
I have got 5 to 6 months out of noisy motors using a light household oil or WD 40.
Sep 22, 2011 | Heating & Cooling
I have a Toshaba 3HL 67U I can-not get the pedistal stand off it. Can you help me please. I want to hang this tv on the wall.
Don't know why u have that much problems to take out the tv pedistal stand off it.Just check make sure u take out all the screws around tv back of the pedistal,make sure u take it all out.Used one hand hold the tv bazel frame tight and the other hand and jusy wiggle and push it in the pedistal and put it out.The pedistal should came right out.
Jul 31, 2011 | Toshiba REGZA 47HL167 TV
Utilitech high velocity 20" pedestal fan, no instructions, what do I do with the spring?
I would like to find an on/off/speed switch for my utilitech fan. Where can I find parts for my fan?
Jun 21, 2010 | Dryers
You make this way too complicated. I just want to know in general, where to put some oil to stop the dry rub noise that I'm getting after my concord fan runs for a couple of hours. KISS approach is best...
The "squeaky" wheel does not always get the grease (read on).
Have you reviewed these possibilities:
http://www.wikihow.com/Fix-a-Squeaking-Ceiling-Fan
I know - you said dry rub.
I don't work here, but I don't think they sell your information.
Mar 19, 2010 | Concord Fans 52NA5ORB NAUTIKA OIL RUBBED...
Squeaky noise from the motorafter running for
I would unplug the fan and clean off the motor shaft behind the fan and vaccum the motor housing and around the motor ends.
Once you've got as much dust and grime as possible removed, use some 3-in-1 oil and LIGHTLY oil each end of the motor shaft (behind the fan and next to the motor housing) and if possible, at the other end of the motor housing.
Make sure the fan is UNPLUGGED when you do this!!! Give the fan a slow spin by hand and hold upright to allow the oil to seep down the shaft into the bearings.
I usually do this once or twice a year on my portable fans and unless the bearing isn't completely worn out, it usually helps the fan spin more easily and keeps it running very well.
Hope you find this very helpful and best regards!
Aug 06, 2009 | Marvin W.B. 81400 14" HIGH VELOCITY FLOOR...
My central air also makes squeaky noise
All new blowers are sealed units you really can not oil them. By the time they start howling it is to late. Now some evap motros inside have two small plastic plugs on the motor. The outside one is easy to oil the inside one is blocked by the fan. Very hard to get to without pulling the fan. My suggestion calla service tech and ask for free estimate on motor service or replacement.Russ
Jul 23, 2009 | Heating & Cooling
AC unit in the attic is making a loud squeaky noise as it's going off
You may need to oil the fan motor. Most fan motors have an oil port at the shaft. It will be a yellow plastic cap that you pull out. once this cap is removed you need to oil the motor with an oiler that has a extending spout such as the ZoomOiler brand purchased at your local hardware store
Jul 08, 2009 | Heating & Cooling
Squeaky noise when turning
Check your power steering fluid level
Feb 14, 2009 | 1992 Daihatsu Charade
Dryers Logo
32 people viewed this question
Top Dryers Experts
