Question about Acer Aspire 3820T 3820TZ 4251 4332 4336 4535G 4551 4551G 4553 4625 4625G 4732Z 4736 (30034017552)
Charging Acer Aspire 3820T
Hello My Acer Aspire 3820T, while being turned on and charged would repeatedly experience charger's connections/disconnections and a typical beeping for some reason. While being turned off it charges just fine(the battery indicator is still and does not twinkle or something), whats more when I turn it on and do not touch it at all but merely charge it, it would go just fine with it as well (Might experience just a couple of those charger's disconnections though) but whenever I start loading something or just intensively moving the mouse it starts disconnecting and beeping all over again. It has been like that for the past 2 week or so, it had been working fine before. I don't think it has anything to do with the cable as I touched it at different places and it just doesn't affect it in any way.. Is there anything I can do? Thank you in advance
panthers85
  • 54 Answers
SOURCE: Laptop battery won't charge - Acer Aspire 4520
Since is shows it as charging then your power cable should be working. So it looks like a battery issue but batteries just don't die unless a cell inside dies then they will stop working. Try taking the battery off and making sure that the connections are clean then put it back in. If that doesn't work give the battery a good full charge then bring the battery and laptop back to where you bought it and get them to test the battery to see if a cell died.
Posted on Jul 29, 2008
SOURCE: Battery not charging when Laptop powered on Acer Aspire 4520
replace the battery of lappy
Posted on Feb 09, 2009
RescueTechLA
  • 2653 Answers
SOURCE: My Acer Aspire 5920 won't turn on.
What happens when you use the computer with the battery out. Just running from the charger?
Posted on Jun 17, 2009
SOURCE: Got new battery for acer aspire 6920. not charging
You ordered the wrong battery, theres two types, your original would have been 11.1v if you check the new one it will be 14.8v. They are not compatable.
Posted on Nov 23, 2009
  • 79 Answers
SOURCE: My battery is not charging. I bought my Acer 5738g
Remove battery, replace and ensure contacts are clean. If wont charge then battery is dead. Get a new battery.
Posted on Dec 20, 2009
I used it the night before it was fine i plugged in the charge and it wont turn on at all
laptop charger for acer aspire 3600 3680 series 3650 3610
www.amazon.com/LAPTOP-CHARGER-ACER-ASPI...
Amazon.com, Inc.Amazon.com: LAPTOP CHARGER FOR ACER ASPIRE 3600 3680 SERIES 3650 ...When I was looking for a charger cable for my laptop, i was not sure whether I ... it was really good and worked, it heats up a little bit but for now its working ...
When your acer aspire 5738 z laptop adapter is not working ...
docslide.us > Business
Aug 18, 2015 - When Your Acer Aspire 5738Z Laptop Adapter is Not WorkingA ...Quicker Charging of Laptop Battery with an Acer Aspire 3600 AC Adapter ...
batteries-store.pblogs.gr/.../when-your-acer-aspire-5738z-laptop-adapter-...
Jan 14, 2016 | Acer Aspire 3600 Laptop Charger...
Acer Aspire 5315 charging circut fuse
So you have removed the battery from this laptop for at least 30secs - 1minute? Not really sure about a laptop fuse? Test your DC jack for continuity - with a volt meter - outside prong and inside stem. Those will be the first few steps to finding your issue.
Troubleshooting Laptop Adapter and DC Jack
Jun 02, 2014 | Acer Aspire 5315 Notebook
My acer aspire 7520-5185 will not turn on
Hello. There is a hardware failure with the laptop not the AC charger. AC chargers have some range of protections of their own. If the power requirements of the laptop are bigger then what the charger can handle, the charger will turn off. Also other parameters can bring the charger offline. In your case, you have a problem with a small chip, the battery charge controller unit, witch regulates the amount of current required to propperly charge the battery. When this thing fails, the charging requirements for the battery are reported rong and the AC charger is forced to give more power then necesary. This results in disconnection of the AC charger ( an internal fail safe of the
AC charger) and the laptop to swich back to battery power. When the laptop is turned off, it can charge the battery because the power requirements are low, having all processor, main board, hard disk etc turned off. Therefore the AC charger can handle the load. However you will need to have it checked by a service center as it is a hardware fault. Both AC charger and laptop needs that check.
The charge controll circuit needs to be replaced probably. It will be a somewhat expensive repair. Don't buy any other battery untill you have the laptop checked.
Acer Aspire 7520
Jan 13, 2013 | Acer Aspire 7520-5185 Laptop
Hello!!! I have acer 4810t, i would like to ask where is the problem if the battery is plug but no notification in charging but the lights turn orange signify that it is charging.
Hi
If its charging the battery and there's no notification that it is charging most of the time its a glitch inside of the Operating System (Windows 7 Vista or XP). Once you reinstall the Windows that should fix the problem but if the problem persists last thing culprit is the motherboard.Thanks
Feb 21, 2011 | Acer Aspire 4810TZ4969 Laptop Charger...
Hello , I have acer aspire one 751, with win
OK, it sounds like the acer aspire one 751 has a bad battery that will need to be replaced. It is not taking a charge, so it is not detected even though it is connected to the laptop. The 'plugged in' message shows that the charger is connected and detected by the computer, but the battery is 'not charging' due to the bad cells.
Good luck on finding a replacement battery.
Dec 18, 2010 | Acer Computers & Internet
Acer aspire 5520 wont power up.. no charging light when connected to mains
Try another charger. If it turns on and chargers the unit you are currently using needs to be replaced. Do not leave your charger plugged in after charging your battery as this will shorten its life.
Oct 31, 2009 | Acer Aspire 5500 5570-2609 Laptop
Power wont turn on acer aspire 5100
check 1st your charger if working.try other charger
Feb 21, 2009 | Acer Aspire 5100-3357 Notebook
Acer Aspire 3820T 3820TZ 4251 4332 4336 4535G 4551 4551G 4553 4625 4625G 4732Z 4736 (30034017552) Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
