Question about GE Profile PFSS6PKX Bottom Freezer French Door Refrigerator
PC ER flashes on display - GE Profile PFSS6PKX Bottom Freezer French Door Refrigerator
The code ER CO keeps coming on, on the display panel. The fridge and freezer still work but the code keeps coming up. Any info on that?
LG Bottom Freezer Refrigerator Error Codes Sears PartsDirect
Select
Use our model number finder
Choose your product type
Common model number plates
Close
LG Refrigerator Error Codes
These error code explanations can help you diagnose a problem with your LG bottom-freezer refrigerator. For repair how-to help, visit the PartsDirect repair help section, which includes repair help for washing machines, other major appliances, lawn and garden equipment, garage door openers, vacuum cleaners and more. You can also search for owner's manuals, get advice from an expert and find refrigerator replacement parts. Error Code
Er FS Error Code
Er rS Error Code
F dS Error Code
r dS Error Code
Er HS Error Code
Er IS Error Code
Er SS Error Code
Er rt Error Code
Er It Error Code
Er gF Error Code Error Code
r dH Error Code
Er IF Error Code
Er FF Error Code
Er CF Condition
Condenser fan motor is defective Check/Repair
Condenser fan motor, wiring or the control board Shop Parts
Condenser fan motor, Power control board, Wiring harness Error Code
Er CO Condition
Communication error Check/Repair
Communication error between main board and display board Shop Parts
Display control board, Power control board, Wiring harness
Jul 16, 2015 | LG LFX25974ST 24.7 cu. ft. French Door...
Have a Frigidaire Gallery dishwasher that is flashing ER
Good Morning Jimpat Holmes, thank you for your inquiry!
I understand that you are having an error code "ER" displayed on the panel of your Frigidaire dishwasher. Normally, "ER" stands for error code and that can be a miscommunication within the board. I would perform a reset on your dishwasher and you can do that by disconnecting power from your dishwasher for ten minutes. If you continue to receive an error code you could be experiencing an issue within the control panel or faulty wiring harness. I hope this information is helpful. -Matt
Oct 30, 2014 | Dishwashers
Pc Er Error code
Jim, Pc Er is a Communication circuit failure on main board or
Communication circuit failure on control panel board
Could be a loose or corroded connection, a bad mother board or a bad display board. Before doing anything, unplug the refrigerator for 5 min and plug it back in. This may reset the motherboard. If not, check the comm cable at the display and the motherboard. if ok, then you will need to replace either the motherboard or the display board. There is no way of determining which one to replace.
Apr 10, 2014 | GE (PSS26MSRSS) Side by Side Refrigerator
Is it possible that the keys can lock on a sam4s er-5200m electronic cash register if so how can u unlock them
Did you sort out this problem? Usually it is caused by a cashier logon problem. Especially if you see 'CLOSED' on the display.
For those who have asked for a Sam4s ER-5200 or ER-5200M manual, one of the users has it here:
http://the-checkout-tech.com/manuals/cashregisters/Samsung2.php
Jul 29, 2013 | Computers & Internet
Sharp ER 1075 LED light not working
This model uses a florescent display. It may have a dry solder joint or power supply problem. The Sharp ER-1075 service manual is here:
http://the-checkout-tech.com/manuals/cashregisters/Sharp_ER-1074_and_ER-1075_service_manual.html
Oct 28, 2011 | Casio Parts Cash Register PC Desktop
Flashing temperature control for freezer setting
There is no problem for that, as long as the temperature control is functioning well and it display the temperature degrees number. You vary it, hi or low and the unit still cold or freezing.
Sometimes the liquid crystal display of the electronic control module become loosen 'cause it to display in a flash manner. Unless it display "ER" it means there's something wrong with your unit. But so far it operate normally.
Thanks for asking.
Jul 04, 2011 | Refrigerators
There is an ER message flashing.we tried pressing cancel but nothing happens. it's like all the settings are frozen
This is a Common Error Message. Try to Disconnect the Power Supply, and wait for few minutes, say 30 minutes to Turn it ON.
If still ER message is displayed, you need to Replace either Touchpad or Control Board.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jan 08, 2010 | Frigidaire Dishwashers
The display will stay on normal for about 5 min and then give me a Er FF. What to do?
problem may be the main pcb or evaporator fan motor. this unit has several problems. if the model# starts with a 795 it was made by LG. the er ff code is caused most of the time from frost building up around fan motor. this can also be caused by freezer liner sagging at the top of freezer causing frost build up, sears has a service flash for this that is covered by the manufacture. service flash sf46-512. iwould call sears and find out if your model is on this service flash.
Nov 13, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Projector on acer
Windows is problably exptending your desktop to the projector, like a dual montiro display. Try moving the mouse to the right, outside the laptop/computer screen and see if it appears on the projector.
If that's the case, go to advanced display properties and set the output to clone instead of extend desktop.
Jun 18, 2009 | Acer PD523 Multimedia Projector
GE Profile PFSS6PKX Bottom Freezer French Door Refrigerator Logo
60 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
